Old 08-03-2024, 02:13 PM   #51
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Bought My Uncles '69 Chevy 1/2 Ton Today
Originally Posted by LockDoc View Post
No problem. Thanks.
There aren't any other holes in the panel around the mirror so I would guess it would be original to this truck anyway.
Thanks. I will need to go over it again with the wash mitt but I can do that here at home.
Thanks!
First actual tow job for the Dually...
Not sure what the official name is for the paint but I am going to need to find out for sure.
If the paint code is 517, It's Maroon Metallic.
~Steven
Simi Valley, CA
Last edited by Steeveedee; 08-04-2024 at 03:53 PM. Reason: Was 527, corrected to 517.
Old 08-03-2024, 02:36 PM   #52
slikside
slikside's Avatar
Oh. My. Gosh!
I had a feeling it was gonna clean up well, but not THAT good!
What a stunner! Congrats!
EDIT: Best looking “saved” farm truck Ive seen. Most are beat to a pulp…
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 08-03-2024, 02:56 PM   #53
Rust_never_sleeps
Rust_never_sleeps's Avatar
I watch enough Junkyard Digs and Thunderhead289 videos to know what an Iowa farm truck can look like, that one's a pearl
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 08-03-2024, 05:18 PM   #54
54blackhornet
54blackhornet's Avatar
Always nice to see his work. Leon is a perfectionist ! Congratulations on another fine job…
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 08-03-2024, 11:05 PM   #55
leddzepp
Moderator
leddzepp's Avatar
Beautiful truck Leon!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-03-2024, 11:41 PM   #56
LockDoc
The Older Generation
LockDoc's Avatar
Thanks Gentlemen.
The paint doesn't look to me like it has any metallic in it. It looks like it's listed as 4517AA on the SPID. I will have to double check it in the morning.
Leon
Old 08-04-2024, 01:03 AM   #57
PowerdbyChevy79
PowerdbyChevy79's Avatar
Looks great .. solid truck. Looking forward to seeing the progress.
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 08-04-2024, 01:04 AM   #58
Steeveedee
Who Changed This?
Steeveedee's Avatar
That would make it a special order color. Maybe compare it to #67 Burgundy Poly from the '69 car line?
https://www.pinterest.com/pin/paint-...0286355039858/
~Steven
Simi Valley, CA
Old 08-04-2024, 02:04 AM   #59
68bowtie
68bowtie's Avatar
Subscribbity-doo!
517 is definitely maroon metallic.
Old 08-04-2024, 07:18 AM   #60
72 tigger
72 tigger's Avatar
Looking forward to the pics after detailing it!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 08-04-2024, 12:04 PM   #61
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Very nice! Subbed...
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-04-2024, 04:36 PM   #62
old51sedan
old51sedan's Avatar
Beautiful Truck, same color as the one I bought new in the fall of 68, mine was pretty low optioned with just gauges , step bumper, with the 250 and 3 on the tree. You don't get much for $2160.00 out the door, as I remember those 68.00 a month payments weren't always easy back then. I understand that was low option color also..
old51sedan is offline   Reply With Quote
Old 08-07-2024, 09:48 PM   #63
LockDoc
LockDoc's Avatar
Thanks. We will see how fast it progresses.
Originally Posted by Steeveedee View Post
That would make it a special order color. Maybe compare it to #67 Burgundy Poly from the '69 car line?]
It may be the same.
Originally Posted by 68bowtie View Post
Subscribbity-doo!
I know my eyes aren't the best any more but if it has metallic in it it must be really fine. I polished a couple of places and I will check them out in the sun in the morning.
Thanks!
Thanks Dale.
I hear you on the payments. I bought a new Buick in 1965. I was making $1.75 an hour. Luckily the wife was working at that time too.
The paint was one of the reasons I wanted this truck so bad. I have always wanted a maroon one.
Leon
Old 08-07-2024, 10:09 PM   #64
LockDoc
LockDoc's Avatar
The carb was leaking gas pretty bad so I decided to pull it off and see what was going on with it. None of the bolts or assembly screws were tight on it. I was glad the nuts on the mounting bolts were not tight because this is what I found when I removed the carburetor from the manifold.
I cleaned everything up and went ahead and mounted an old carburetor that I had on it. I gently tightened the mounting nuts up just enough so that the gasket would seal. The goal at this time is to just get it running good enough to be able to move it around the yard. I put the clear filter on it temporarily so I could see if I did a good job cleaning the tank out. So far, so good. It idles really good and makes no strange noises.... .. I will go ahead and rebuild the original two barrel, and I have another manifold if I need it.
I am going to swap out the wheels/tires tomorrow with some 17" ones I have so that I can get the stock wheels blasted, primed, & painted and get some new tires mounted on them.
Leon
Old 08-08-2024, 03:49 PM   #65
RenoKeene
Florida Edition
RenoKeene's Avatar
Congrats Leon! Good things happen to good people.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 08-08-2024, 04:56 PM   #66
68Gold/white
Leon,
I have successfully removed many of those "skinny" studs, never broke one..
I used vice grips, patience, and penetrant oil.
I always tapped those blasted holes that carbon up and installed set screws...
This carb heating technology went away in the early 70's, thankfully!!!
68Gold/white is offline   Reply With Quote
Old 08-08-2024, 05:55 PM   #67
dagnabbitt
dagnabbitt's Avatar
Wow, what a nice truck.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 08-08-2024, 09:07 PM   #68
LockDoc
LockDoc's Avatar
Thanks.
Originally Posted by 68Gold/white View Post
Leon,
I hope I have as good of luck as you do. I ordered a kit for the original carb today
Thanks Dave.
Leon
Old 11-27-2024, 01:59 AM   #69
68bowtie
68bowtie's Avatar
Any updates on the royal red beauty?
Old 11-27-2024, 12:15 PM   #70
MikeB
MikeB's Avatar
Amazing that it started right up!. I had no idea that was a factory color, or even close to one. I like the blackwalls and hubcaps.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 11-27-2024, 04:57 PM   #71
LockDoc
LockDoc's Avatar
I have had some delays but I am pretty much ready to put it in the shop for the winter and get serious about it. I bought an '04 big block Suburban to put my snow plow on and I have spent quite a bit of time updating it and getting it ready. Also getting everything around the place ready for winter.
Also had a 1/2 ton LWB frame that I needed to shorten so I could put the short bed box on it that I have. I just finished that up yesterday.
I was kind of surprised at that too. It will be put back together just like I got it. It won't be a show truck but it will be a nice driver....
Leon
Old 11-27-2024, 05:50 PM   #72
MikeB
MikeB's Avatar
Lots of near show trucks out there anyway. Even mine's a little too nice to use as a truck. Have to be careful with anything I haul in the bed. But for the first 20+ years I had it, I'd just throw all kinds of stuff back there, and not worry about bed floor, bed sides, and tailgate scrapes and dings.
Mike
Old 11-27-2024, 05:53 PM   #73
LockDoc
LockDoc's Avatar
Yeah, that is why I built the Black Dually as a work truck. I have hauled all kinds of stuff in it already.
Leon
Old 11-29-2024, 10:39 PM   #74
BIG ORANGE
BIG ORANGE's Avatar
I haven't been on here in some time, but wow love the truck and the story, congrats on it al working out in yr favor, nice family truck, so blessed to have it still.
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 11-29-2024, 11:32 PM   #75
LockDoc
LockDoc's Avatar
Thanks Donnie. I am so glad I ended up with it. Now I need to get busy on it....
Leon
