Old 09-21-2004, 01:42 AM   #1
meathead95
computer illiterate
meathead95's Avatar
cam advice please
would this be any good for a street engine. occasional drive and weekend car shows. its for my 72 2wd blazer 454 i was just wondering it seems like a lot of lift to me and the engine just has stock oval port heads. plus i have never had a solid lift cam before. ill get roller lifters and rockers also. i just want it to have a real good lope to it and smoke the **** out of the 20's
Camshaft, Solid Roller Tappet, Advertised Duration 295/305, Lift .670/.670
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 09-21-2004, 01:47 AM   #2
cableguy0
you cannot run that cam on stock heads you would be best to go with something smaller and not a roller. the roller cam requires much heavier springs will require screw in studs and guideplates. those stock heads wouldnt begin to flow enough to bother with that cam. your gonna have to steer away from the roller cams to use your stock heads
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-21-2004, 03:39 AM   #3
browndawg71
there is alot of information missing to try to answer this question absolutly right, but it does sound to big. the duration @0.50 would be a good start.it is my opinion that for the amount of $$$ it cost to run a roller cam, a solid will suffice and is a hell of alot cheaper.but if you want to set it on kill , go with the roller.the oval ports need to be the 781s or the 049s these are good streetheads. there is a lot of factors in making a good combo.
browndawg71 is offline   Reply With Quote
Old 09-21-2004, 04:48 AM   #4
meathead95
computer illiterate
meathead95's Avatar
i have the 781's
72 2wd blazer
72 swb 4x4
Old 09-21-2004, 05:02 AM   #5
meathead95
computer illiterate
meathead95's Avatar
anyone have any advice for a cam for this beast. not sure what the bottom end is i took it in on a trade it is very clean inside like its a new rebuild so im not tearin it apart it was supposed to of had a flat lobe on the cam but it actually has a pushrod that barely pushed through the rocker arm. any way it has the good oval port 781 heads on it and an air gap intake with a performer 800cfm carb and ceramic coated headers. it will also have a 700r4 behind it i am wanting a nice lopey tire burnin bbc. all reccomendations are welcome
thanks
keith
72 2wd blazer
72 swb 4x4
Old 09-21-2004, 11:54 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Meathead, call your favorite cam company. They will be able to steer you right on selection. Answer their questions honestly for best results.
Cableguy, you have small blocks on the brain. He already has screw in studs and guideplates stock.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 09-21-2004, 12:26 PM   #7
meathead95
computer illiterate
meathead95's Avatar
yeah, i figured on calling a cam company i mainly started this because i found this cam above with roller lifters, guide plates and roller rockers for 200$ which is a smokin deal it just sounded like it had too much lift to me. i have never had a bb before so i wasnt sure how much lift those heads would take before i started floating the valves
later
keith
72 2wd blazer
72 swb 4x4
Old 09-21-2004, 02:16 PM   #8
stepside454
stepside454's Avatar
you can use a roller cam with stock big block heads, hell, they already have screw in studs & guid plates. That one there is a bit rowdy for the street though
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 09-22-2004, 04:14 AM   #9
ftsmoot
my opinion
you can always have that big a!! cam reground to a liveable spec since you got such a good deal on it
ftsmoot is offline   Reply With Quote
Old 09-22-2004, 04:34 AM   #10
cableguy0
yea firefighter your right had a brain fart for a moment when i typed my original message lol. thats still quite a bit lumpy even for a big block though being a roller it will have a bit more manners than and equal sized cam that was flat tappet
Old 09-22-2004, 08:32 AM   #11
67shortie
Green club
67shortie's Avatar
Excellent idea
But for his street engine, a solid roller is a bit over the top even tamed down. A HYD roller would be better for his application. BUT since he can get the remaing parts at a low cost it may be worth it. Keep in mind though solid rollers are not all the same, standard roller lifters were not made for low rpm use and will wear quickly because of lack of oil on the bearing that rpm from the engine provides from crank throw. Iski makes a 'red line' lifter with an extra hole spesifically for this problem, this lifter will live on the street. I would imagine if these are older style lifters and have seen alot of street use they may be worn already. Inspect them closely.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 09-22-2004, 12:44 PM   #12
meathead95
computer illiterate
meathead95's Avatar
thanks for the advice fellas i didnt know about the low rpm lifter thing
72 2wd blazer
72 swb 4x4
Old 09-22-2004, 06:06 PM   #13
browndawg71
a stock cam in this motor should smoke em, but more is better. i would go with around 230 degrees@ .050 duration on a hydraulic and more if you run a solid.if the compression a little lower i would go loweron the cam. the heads you have are good heads they can be also improved a little by pocket porting and bigger valves if it has not been done already.
