Im needin to put a lift in my 70 K15 and I cant decide on how much to lift it. It needs new springs so I figured this would kill two birds etc...
I dont want a monster but something that will look tough. Im considering a superlift 2.5" or 4". Can you guys post some pics of your lifts so I can get some ideas. I dont think that I'll go any bigger than 33" tires, probably stay with 31's. Im actually running 16" wheels from my 98 on it with the standard Z71 size of 265/75R16. Any help would be fantastic ![]() Thanks. Gator
1970 GMC K15 - Canadian built 2nd Owner truck 68k miles ![]() 2014 Denali 1500 6.2L ![]() ![]() |
Guess I should have put some more info in. Any problems driveline angles etc with 4" would I be wasting money on a 2.5" when I should have gone 4. Brakeline extensions, steering stabilizer add-ons ????
Lift
You can run 33's with a 2" lift very comfortably but I like 33's with a 4" lift myself.
![]() All these trucks should have steering stabalizer's on them, they did from the factory. With a 4" you'll want a dropped arm and a longer drive shaft's and of course will need longer shocks. Someone will get on and tell you, "it all depends on what your doing with it" and that's a fair question. What are you expecting? Last edited by vtblazer; 12-03-2004 at 08:01 PM. |
Lift
My 70 has a 2" lift on it.
Here it's sitting next to the blazer that has a 4" spring lift. Last edited by vtblazer; 12-04-2004 at 03:59 PM. |
user # 2756
![]() Join Date: Jun 2001
Look at the pics in the link in my signature.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
![]() Join Date: Feb 2001
Myself, if youre gonna go to all the trouble to put a lift kit on you may as well go with a 4 inch. A raised steering arm. Re adjust you brake lines and maybe lower your TC, you'll be good to go.
By chance, can you post a pic of your rig? Either lift should have extended brake hoses. I'm about to put extended SS braided hoses on my K10 because the orig rubber hoses need replacement and I figured the next owner would appreciate the longer hoses in case he wants to lift it. Mine looked like they could give out any moment. One had a chunk of outer sheath missing.
![]() vtblazer, nice rig and great stance. ![]()
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
![]() Join Date: Feb 2000
The first pic you see here is my 69 with 4" of lift. All the pics have the same 35" tires on the truck.
![]() Next is when I added a little more lift to about 6" of lift. ![]() And here it is with about 10" ![]()
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#9 | |
WTB this ad
#10 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
4" kits are very popular though, so it really depends on your preference.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#11 | |
Thanks for the input guys. Ill try to muster up a pic of my truck. I basically just want the lift for a tougher stance. This truck will never see any serious off roading. It was purchased new by my Grandad in the fall of '69 and only has 58K miles. This will be my keeper truck.
#13 | |
user # 2756
I have the p/n for longer brake lines I put on my 71. Got them from autozone, I'll post them when I find what I did with the packages. Dean has them also on both his 3/4 tons.
#15 |
If your gonna take the time and take the truck apart, go with the 4in. I have 4 on my 71 with 33`s. The only thing I had to change is the drop steering arm, and shocks(but most kits come with shocks anyway). If your going with 33in tires your not gonna notice any less gas or performance with the 4 as comparede to the 2.5. Here is a pic of my 71 with 4 and 33`s....Good luck
71 chevy 4x4 ,np205 transfer case, 3 speed tranny, sjs 283, 4in suspension lift, and 71 hugger orange paint,33x12.5 parnelli jones on 15x10 m/t classicII, cowl hood,new bed painted, linex liner. Truck has been completed since 2005.... 2003 Chevy Avalanche Z71, on 6in super lift w/ 35in tires RNG4x4 aka the "Redneck Roller" words to live by "If it fits, it fits" "friends help you move, real friends help you move bodies..." Sponsored by "Kick Ass Kustom" |
#16 |
Now there's your "tougher stance"
Nice truck bodazpa. |
#17 |
Thanks, hay vt did you ever do any thing with the shortbed 4by you bought...
#18 |
That is one fine truck, bodazpa!
![]() And I say that not liking orange paint colors. ![]()
#19 |
call skyjacker or rancho,trailblazer,i think that's it.i had a 75 blazer with 8'' of lift bought everything from skyjacker. my kit cost rite at $2,000 with everything.shocks springs,brake lines,steering stablizer,steering arm.they come with all your blocks,ubolts,
etc. |
#20 |
I notice the common wisdom seems to be that with 4" of lift you MUST do the steering arm.
Years ago a buddy lifted his mid 70's 3/4 ton chevy 4" and installed the arm and the bump steer was flat out dangerous ! He took the drop arm back off re installed the stock arm and it handled great no bump steer. With this in mind when I did my 4" I decided to test drive w/o the arm first (kit came with the arm) and what do you know no bump steer... am I a disaster waiting to happen ? lucky, or what ?
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes. My lame K20 page My lame Eaton disc brake page ![]() Last edited by RainFade; 12-05-2004 at 10:38 PM. |
#21 |
I have a four inch raised and I can take my hands off the wheel going down straight highway. I've never had any problems with bump steer.
#22 |
My 69 was without the dropped drag link for a few months and definitely needed it. Much nicer to drive with it.
#23 |
Bodazpa nailed it. That is a very nice ride. especially with the cowl hood. Im on the path to greatness now. I appreciate all of your guys' input. It helps when someone has done it before and knows the ins and outs of the task.
#24 |
glad i could help.........good luck.....john
#25 |
![]() Join Date: Apr 2003
Thanks bodazpa, i now have a new background for my computer.
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
