Old 02-15-2005, 12:07 AM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
look at these plugs
a while back my motor started running like garbage and then blew the lower rad hose off. i was told blown head gasket. everyone i talked to said if it was blown a spark plug would get steam cleaned by the antifreeze. so i took my plugs out and here are the results.
1 caked with crud
2 wet with gas
3 wet with gas
4 nasty but dry
5 black
6 nasty
7 black
8 smells like gas
it's a wonder this thing even runs.....
i was told by a couple people to replace them with autolite 25s. are these good plugs?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 02-15-2005, 12:08 AM   #2
67ChevyC10Stepside
the one facing you above there was 3 the double here is #8
Old 02-15-2005, 12:14 AM   #3
454_72_4X4
454_72_4X4's Avatar
Autolites are good plugs but I'd put AC's in it myself.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 02-15-2005, 12:49 AM   #4
Blue_71
Bloo
Blue_71's Avatar
i personally dont like autolite plugs, i wont even run them in a ford unless im strapped and have to. i would defintly put in AC Delcos
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 02-15-2005, 12:54 AM   #5
67ChevyC10Stepside
is there some kind of reason? the guy who told me to run them owns a auto repair shop and has a truck he calls hammer....it has a 400 SB in it that is supposedly real nasty. what kind of delcos you run?
Old 02-15-2005, 01:09 AM   #6
454_72_4X4
454_72_4X4's Avatar
Ac's are just "factory" plugs for Chevy's. I've had decent luck with Autolite but almost always run AC's unless I just can't find them.
you'll just have to look up a number for your engine to get ya started and then work your way from there. AC heat ranges are smaller number/cooler plug, bigger number/hotter plug. Ya wanna run a cooler plug in a "hotter" motor.hat's not carved in stone though.
Stock are usually in the 45-44 range.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 02-15-2005, 01:28 AM   #7
67ChevyC10Stepside
i dont know what that hotter cooler stuff means......the ones that are fouled to crap in these pics are acs.......i dont know what part number i need is what i was asking.
Old 02-15-2005, 01:51 AM   #8
454_72_4X4
454_72_4X4's Avatar
Do you know what the motor came out of originally? Or is it the original motor for the truck? Is it the 400 in your sig?
The plugs in your pic are tapered seat plugs so that pretty much eliminates the "original" motor from your 67. A 67 motor would have crush washers to sal to the head.
Is it stock? Mild performance? High Performance?
I can't tell you an exact number but if it's a stock motor it will more than likely be a 45 plug. Something like R45TS or R45TSX "R" stands for resistor, "45" is the heat range, not sure about the other numbers. "X" usually means extended tip.
Heat range example;
A stock motor would use a 45 (hot) where a high performance motor would use a 43 (cooler). Hotter plugs don't transfer as much heat to the head therefor retaining the heat in the plug which helps burn off carbon deposits.
Are ya confused yet, Or should I go on?!!! LOL
Your best bet is go to a parts store and have them look up the plug number for the engine you have, (or as close as you can get to the engine you have).
I use #FR3LS in my S-10! DON'T get those. (They wont fit)
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 02-15-2005, 01:56 AM   #9
67ChevyC10Stepside
it's the one in my sig.....77 truck 400 2 bolt main...has a cam and will have intake and carb....and sometime hopefully soon aftermarket heads.....
Old 02-15-2005, 02:05 AM   #10
454_72_4X4
454_72_4X4's Avatar
Just tell them that at the parts store and they'll get ya the right plug. Just the cam, intake, and carb shouldn't make much difference in the heat range. Whatever they come up with for stock should be good. When ya get those aftermarket heads ya might have to drop down to a cooler plug.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 02-15-2005, 02:30 AM   #11
67ChevyC10Stepside
well i think for now im gonna passify tim and give the autolite 25s a try.....i was talking to him some more here and he swears by them....if they dont work it aint like they are expensive to replace...
Old 02-17-2005, 05:59 PM   #12
Blue_71
Bloo
Blue_71's Avatar
my personal reason fo rrefusing to use autolites is ive never had any luck with them. i fouled out four sets in my 327 i used to have in the k20 in under two weeks, then i put in a set of AC delco and didnt change them again untill i pulled the engine and broke one off about a year later. i didnt do anything to anythign else in the engine other then the plugs when that happened.
1989 Chevy K2500
Old 02-17-2005, 06:19 PM   #13
GreyHoundSteve
Im not as experienced as some of these guys but ive always had good luck with ngk's. Ive ran them on my Vette,supra TT, Z tt and TA and have always gotten good performance from them. My mechanic first turned me on to them when i was trying to bring my tpi vette motor back to life. He races sb chevys and runs them on every motor he build. I figure if they can handle nos and 26lbs of boost they must be pretty decent plugs.
GreyHoundSteve is offline   Reply With Quote
Old 02-17-2005, 09:52 PM   #14
purple gas
A few mechanic freinds of mine who are also into racing swear by NGK's too. my opinion ain't worth nuts, but these guys build motors for a living. But if you get enough mechanics in a room, there gonna disagree on just about everything.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 02-17-2005, 10:46 PM   #15
J Y Dog
What were the results of your compression test?
J Y Dog is offline   Reply With Quote
Old 02-17-2005, 10:55 PM   #16
arkracing
Weekend Warrior
Not to Hijack but can you get AC's @ the regular parts store or do i have to get them from a GM dealer?
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 02-17-2005, 11:02 PM   #17
tnblazerk5
User #12137
tnblazerk5's Avatar
advance auto has them around here
tnblazerk5 is offline   Reply With Quote
Old 02-17-2005, 11:17 PM   #18
onetoncrewcab
One of my kids. Cute eh?
onetoncrewcab's Avatar
LOL. Reminds me of my Dad. When I was a kid, he owned his own shop and I ran parts for him on Saturdays. Whenever I went to get plugs, he always said not to get autolite. I never did. I always suspected if I had screwed up, there would have been a whoopin' for Mikey. LOL
Really funny what can trigger a memory from 35 years ago.
Mike
If a kid asks where rain comes from, I think a cute thing to tell him is “God is crying.” And if he asks why God is crying, another cute thing to tell him is “Probably because of something you did.
John 3:16
2006 Chevy HHR
2000 Dodge Durango
1985 Jeep CJ-7
1970 Chevy Pickup
onetoncrewcab is offline   Reply With Quote
Old 02-17-2005, 11:17 PM   #19
67ChevyC10Stepside
i didnt do a compression test....
Old 02-18-2005, 04:33 AM   #20
OhioDan
OhioDan's Avatar
Thumbs up
As for blowing your lower rad hose off, check your thermostat. A lot of times if they stick closed, your motor will overheat, and the hot fluid has to go somewhere, so it tries to get to the rad from the lower hose. It's coming onto spring, and your coolant probably needs changed anyhow. I know that I'm guilty of not changing mine every 2-3 years like it should be. Put in new therm., lower hose, and coolant. Tune engine, and you should be good to go. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 02-18-2005, 06:58 AM   #21
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Suprised no one has mentioned Champion plugs. They seem to burn OK, but they like to break off.
I've run NGKs in the past and they ran great, but in all reality, I think BOSH has to be my favorite.
Old 02-18-2005, 08:45 AM   #22
superchevy
Got big-block?
superchevy's Avatar
I've run Autolite 25's in my big blocks for about 8 years now...after I was tipped to them by a drag racer who runs only big blocks. Before that I was an AC only guy. I like the 25's. Just my 2 cents.
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 02-18-2005, 12:12 PM   #23
67ChevyC10Stepside
there was no thermostat in it at the time of the blowoff........i put a superstat in it now.
Old 02-18-2005, 12:41 PM   #24
Maximum Overdrive
December 21, 2012
Personally I run whatever is on sale for the most part. I have never had a problem with any of them. For the most part I tend to use Autolite. Change them once a year and always buy them on sale anywhere from .69 to.99 cents each on sale. Cheap enough that a aperson can change them twice a year for sh*ts and giggles if need be.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 02-18-2005, 12:57 PM   #25
busterwivell
Welllllll............here's another opinion. I never will run Chanpions, only Autolite. I run #26 in my small blocks, #404 in my 402.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
