Old 03-11-2005, 04:28 PM   #1
muddpile
muddpile's Avatar
Custom Autosound opinions?
Has anyone ever used this setup? I don't want to cut the dash and reaching to the glovebox is also an inconvenience, so I figured if these things are decent, I'd try one out. I could run the speaker wires into LOC's and then into amps, so nothing would be run off the head unit itself. I would only use their radio and CD changer, the rest would be high end aftermarket. Is this idea worth exploring, or should I just live with reaching across the truck into the glovebox?
muddpile is offline   Reply With Quote
Old 03-11-2005, 05:11 PM   #2
shifty
Questionable
shifty's Avatar
Can you link up to the product? I'd like to look at it.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-11-2005, 05:13 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
As you wish
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-11-2005, 05:27 PM   #4
shifty
Questionable
shifty's Avatar
I have been thinking about the audio thing also. Mainly because I have $3,000 in stereo stuff sitting on the floor of my shop that I had to yank back out of my '03 Sierra when I traded it in.
I think I'm going to do something similar to that - except I plan on getting a shaft radio (like the ones at that site) with CD/MD changer controls. I'll run out of the RCA's on that unit out to my crossover and amps.
Whatever you do, I would avoid the line-level to low-level passive devices that convert the speaker wires to RCA outputs. Those are bad news. They never do a clean conversion. I used to work at a custom car audio shop down in Florida and people always bought the PAC units to do that conversion and the audio always sounded like ass.
I would probably do one of two things (rather, I *will* do one of them ):
1) Get a factory delete panel and fabricate something to mount my CD player radio under the dash, then run the RCA's out to my other equipment
2) Get a shaft radio with RCA outputs and CD/MD changer control, then run the RCA's out to my other equipment.
Whatever you do, just be sure to isolate your ground for the stereo within 18 inches of the unit, always scrape plenty of paint away from the grounding area to ensure a good ground and *never* run your RCA cables over a power source (or in parallel to power wires). These are three of the most common causes for alternator whine and other noise.
Old 03-11-2005, 06:57 PM   #5
tom hand
CCRider
tom hand's Avatar
I have one...it's ok quality and has RCA outs so you run any amps you want. Having the CD changer controls right in reach is nice and it looks like an AM radio when it is off
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 03-11-2005, 07:09 PM   #6
farside847
farside847's Avatar
I did something a little odd that one of these days I will post some pics. I bought a marine radio and put it in the glovebox. The cool thing about it was it had all the rca/video ins and outs I wanted, plus a small wired remote with a digital readout that fit perfectly inside the ashtray. It is like this but black...
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 03-11-2005, 08:06 PM   #7
aitch
aitch's Avatar
Does this installation require cutting the dash?
69 GMC 3/4 ton LWB
383 TH400 Dana 60
'84 300ZX
'79 Nova (for sale)
aitch is offline   Reply With Quote
Old 03-11-2005, 08:22 PM   #8
muddpile
muddpile's Avatar
Those custom autosound units look really good. I am looking into the USA-6 model with the optional 10 disc changer. I have a few questions though.
1. How many pairs of RCA cables are there?
2. Can I plug a standard radio antenna into the new head unit
3. Is the sound as good as the look.
For the package I want, it is 480 bucks, which isn't too bad if it means good sound, a stock look, an uncut dash and not having to drive with the glove box open all the time and reaching over to change CD's. If I want to add satellite radio, that shouldn't be too hard with the use of an FM modulator. Is there any disadvantage to my plan?
Old 03-11-2005, 09:50 PM   #9
Kid
Kid's Avatar
I've had for about a year now, their "hidden" stereo, display unit mounted in the back of the glove box, and the actual box under the seat. Quality seems to be very good. Sound is excellent, running thru a Precision Power amp, and JL Audio 12" sub & MB Quart 6.5's
Kid is offline   Reply With Quote
Old 03-11-2005, 11:02 PM   #10
gator2511
gator2511's Avatar
I just put one in my 72 K10. It fits the dash and looks sorta stock. The radio will not drive the rear speakers without an amp. The sound quality is poor. The average factory radio will out perform this one hands down. The am band has too much static to make it good. For the money I think I paid too much for too little. The good thing is at least it fits the dash. If I had it to do over I would go for a good radio and made an adapter plate for the dash.
gator2511 is offline   Reply With Quote
Old 03-11-2005, 11:56 PM   #11
shifty
Questionable
shifty's Avatar
I have a Pioneer radio that fits wonderfully in my dash.
I haven't pulled it out to see if it has RCA outs.
Here's a picture: http://www.shifty.org/pics/68chevy/i...0_SB%20002.jpg
I wish it was easier to find manufacturers of shaft-style radios. I searched at CarDomain and Crutchfield, neither one was a go.
Old 03-12-2005, 02:41 AM   #12
muddpile
muddpile's Avatar
Another potential problem I just thought of. Will the custom autosound CD changer handle CD-R's that I burn off the computer? I realize it likely won't do MP3, but just a plain old burned CD, is that an option?
Old 03-12-2005, 03:01 AM   #13
4x4Poet
If you still hang on to ancient hifi technologies, note that the CAS cassette decks don't play Dolby recorded tapes. Bummer if you recorded all your tapes that way. No need to ask how I know.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 03-12-2005, 08:08 AM   #14
tom hand
CCRider
tom hand's Avatar
Yes it will play CD-Rs...thats all I play in mine and MP3s can easily be converted with windows media player
Olive Branch MS
Old 03-12-2005, 08:12 AM   #15
tom hand
CCRider
tom hand's Avatar
Originally Posted by 4x4Poet
If you still hang on to ancient hifi technologies, .
What's a cassette?...lol
Olive Branch MS
Old 03-12-2005, 09:10 AM   #16
seacrow
seacrow's Avatar
I have custon autosound, the sound quality flat out sucks, and I mean it sucks big time. It looks good but it sounds even worse than the factory AM radios. I even upgraded the speaker. It is also very difficult to use, the buttons are tiny and it has very limited features. The bass and treble adjustments are a PITA and they don't have much adjustment. I am disappointed.
71 GMC Custom. 350, 4bbl., auto. Restored in memory of my grandfather.
2008 Ford F-250 Super Duty CC King Ranch, moonroof, heated captains chairs, 6.4 PowerStroke.
2007 Suzuki Hayabusa, all black
1985 Mustang GT T-top, 5 spd. 54K orig miles.
seacrow is offline   Reply With Quote
Old 03-12-2005, 04:25 PM   #17
neonlarry
neonlarry's Avatar
I can't comment on the sound quality of their head units but if its anything like their speakers I would look elsewhere.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-12-2005, 10:05 PM   #18
Gary Lee
fixer of 72 GMC LWB
shaft radio/cass
I have been looking and found this one at crutchfield...Sanyo radio Sanyo isn't that high end but it does have one set of RCA out plugs... none for subwoofer... however crutchfield says its a modify fit... That doesn't seem right... shaft style is shaft style right? I figured this would be as good as those you see in the classic truck catalogs and $200 plus cheaper...
Gary Lee is offline   Reply With Quote
Old 03-12-2005, 11:00 PM   #19
4tiresngas
An American Soldier
4tiresngas's Avatar
Now, if ya'll find one that is XM Satellite Radio ready....I'm all over that. I don't know how we lived before XM.
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 03-13-2005, 12:11 AM   #20
shifty
Questionable
shifty's Avatar
Gary Lee - I think some shaft styles have larger center boxes or the posts are sometimes spaced farther apart on diff't models, so it might still be a "modify" install.
4tires - I have XM radio in my new honda. It came with the car and a 3 months free subscription. I LOVE IT. I could live with that and a single disc CD player (I have 200GB of mp3's at home) and be happy forever.
XM ROCKS!
Old 03-13-2005, 01:57 AM   #21
muddpile
muddpile's Avatar
Seems I'm getting mixed reviews on this product. Does anyone know how many RCA cables there are? I want to run 2 amps, a sub amp and a component amp.
Old 03-13-2005, 04:55 AM   #22
4x4Poet
Originally Posted by muddpile
Seems I'm getting mixed reviews on this product....
CAS units have been routinely trashed on this forum. Note what those who stated they have actually owned CAS units have said.
Old 03-13-2005, 07:26 AM   #23
NPilot1975
NPilot1975's Avatar
Don't know if they are still making them, but Kenwood used to offer a shaft style cassette deck with CD charger controls. I still have the CD Changer that I never installed if you can find the head unit, I can give you the CD changer at a really good price.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 03-14-2005, 12:56 AM   #24
muddpile
muddpile's Avatar
I'll have to keep my eyes open for a nice shaft style unit that will bolt right in with changer controls. I checked on a vette forum and they get trashed there too, so I guess custom autosound isn't a good solution to not cutting my dash.
Old 03-14-2005, 01:33 PM   #25
Johnny05
Johnny05's Avatar
I have a CAS system setup like the one you're wanting to get and it sounds better than what was in my truck before. The PO put in a generic am/fm cassette unit that only had one channel working. The CAS system has RCA outputs which is what I used to run my amp and speakers (I only ran 4 spkrs). For I paid it's a GREAT system but than again being older than dirt I really don't need a 20,000 watt thumper either.. AND it fits in the dash really well.
Oh yeah... my 4yr old son thinks it sounds good too!
Johnny05 is offline   Reply With Quote
