Thats the Hillbilly way
Here are some picturs of a year old chrome thermostate housing it sprung a pin hole leak on Saturday and when I took it off the neck that the hose was clamped too was so thin my thumb made a hole in it .
Don't know what caused it ? Bill ![]()
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
Another shot of the neck.
And the inside
its all about the +6 inches
Wow..huge bummer, they will also cause corrosion on the alluminum intake. THe anti-freeze turns to battery acid frim the dis-simalar metals.
Chainge your coolant EVEY year. |
Andy; What blew me away I've changed the coolant several time when I was experimenting with different Degree Thermostats.
I went back to a stock housing ,not taking any chances. Bill ![]()
I've heard of this hapening, and I have no idea what did it if you have flushed your system.
I know I check mine every 6 months or so when i chainge from coolant to water or vise-versa. So far, so good. |
![]() Join Date: Mar 2001
Anti-freeze for the most part will turn acidic over time, if your using the green stuff, change it every year. As far as the
chrome pieces go, most makers sacrafic quality for the shiny look...knowing it will fail...thermostat housings, chrome pulleys... etc, all fall into this catagory. What ever you decide to use, try to select a metal that is the same as the intake, ie, if you run an aluminum intake, get an aluminum t-stat housing. If you have a stock cast iron, go scoutin the junk yards for an iron t-stat housing, (most of them if even remotely protected from the weather will still be usable) Good LUck.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
I say beware of any chrome!! I am ainti chrome! I guess a air cleaner is ok, but that's about it.
Sucks to hear about that, i have one now and it seems to be ok,its the kind with the o-ring ,no gasket. PS nice camera
Super chevy ; sounds like the same one I had .
Bill ![]()
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
I bought one of those once and when I went to put it on the bolt holes were off by about a half an inch
68 short fleet with 71 front clip 2wd jaguar blue ![]() 99 chevy ext cab shrtbed z71 loaded ![]() 99 chevy swb fleetside(daily driver) ![]() Sparks, Nevada |
I dont even think the air cleaner should be chrome.......go adhead and spend the extra few bucks and get aluminum......Everything should be aluminum or stainless. Unless you are just building a old beater.........My bolts are even polished stainless with logo engravings.
My other Love
i had one of those chrome therm housings. damn thing corroded on me too. not maiking that mistake twice
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
#15 |
Between Trucks...
that's bizarre...
i've been running a chrome one for a couple years with no problem, i'm using that orange long life prestone...
Beat it to fit, Paint it to match... ![]() |
#16 |
Strongman Garage
![]() Join Date: Apr 2000
ive heard of this happening to a bunch of diffrent people who run chrome thermo housings......... this looks like a good topic for the review board...... so im moving it there
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
#17 |
Cowboy Fan for Life!!!!!!
Go Billet.............JB
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
#18 |
Well, my chrome one (with O-ring) has been in use since '98 when i bought the first Longhorn...no tellin how long it was on that truck before I got it. So far so good, and I really like the O-ring too.
On the one that the holes did not line up on, it was probably a pontiac one, thy look the same, but the holes don't quite match up. Pontiac and caddy have the same hole spacing too just in case any one was losing sleep with that question. |
#19 |
Same thing happened to me. Except my pin hole was located on the round part directly above the thermostat. I threw it out and bought a cast iron one from NAPA. Those things are junk, not worth risking your engine over.
1971 Shortbed 350/350 w/ Posi-traction 3:73's 1996 Chevy Silverado TJ in Springfield, Virginia Likes old Chevy trucks Drinks Miller MGD ![]() |
#20 |
no problems here
I have had one with a temp sender hole on top for oh 10 years or so and no problems. Used to be my daily driver not as much now. Just pulled the engine and took that off still looks good?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#21 |
![]() Join Date: Sep 2001
The chrome ones corrode, and the pot metal stock ones warp.
I finally went to Napa and got a cast iron one. Haven't had problems since, but the key is a good gasket and flat clean surfaces. Fel-Pro #35562T. It's a reusable gasket, and you don't use tack or gasket sealer to put it in. Just shove it in and tighen it down. Done.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
#22 |
If you can buy the part at O'Rielly's or Autozone in the "Dress Up" area, don't buy it. (Hell if it is from Autozone, don't buy it no matter what it is.) I've had problems with them not leaking, but when I go to flush the system and I change the hose, the damn neck on it will break off. I went back to the cast iron one.
Nathan Vice President Texas Truck Association |
#23 |
Count me in too.I used one before and it was crap.I think more
than type of coolant, is country of orgin of those damn chrome pieces.I went to Napa to get a cast one with the little carb return spring hole cast into it.Guess where it come from? Yeah,china too. But yeah keep your green coolant fresh.I have heard too many negative stories about the orange GM death-cool on a 90's Suburban forum.I also flushed that stuff out and replaced it with green coolant on my 98 Suburban. |
#24 |
What does it do to the aluminum intakes? Are the only thermo housings that corrode are made of Steel, metal, what? Yeah, what about billet specialties billet ones? Would they corrode? Are there any complaints about these? Nice bolts too, Themattman, where did you get hooked up with those, i've seen em before, did you get a whole set for your motor?
Brandon |
#25 |
THE QUICKER FIXERUPER
I had a problem with chromed heater hose fittings the only ones i could find were chrome cost 11.99!!! got them home and one was steel and one not a few months it split all down one side found one for 2.99 and it works great.
