Old 03-31-2005, 04:59 PM   #1
valleycustom
Custom Chassis with canti setup
Here are a couple of pictures of a 69 i'm currently working on. It's going to lay rocker with 22x10's and still run a/c. I also changed over the C10 spindles to work with the mustang ball joints so I can run 6 lug.
Enjoy
Jr
valleycustom is offline   Reply With Quote
Old 03-31-2005, 05:38 PM   #2
DM310
VERY NICE........ oh and welcome. more details
DM310 is offline   Reply With Quote
Old 03-31-2005, 06:29 PM   #3
72BLAZERDUDE
72BLAZERDUDE's Avatar
Being the semi old guy that I am would somebody explain how this rear suspension works.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 03-31-2005, 06:48 PM   #4
valleycustom
I wish I had more pictures to show right now. The rear is going to use a cantilever system which will change the lift ratio. This setup is going to be a 3 to 1. The lift at the shockwave will be tripled at the axle. This setup will have 12" once it's finished. The shockwave will be attached to the arms inside the frame. There's a shaft that goes through the frame and connects to another arm that will connect to the rear end. I'm not finished yet because I'm waiting on the correct shockwaves because they sent me ones that only had 3" of travel.
Old 03-31-2005, 10:29 PM   #5
Izzy
Trucker.
Izzy's Avatar
Looks badazz.
Izzy is offline   Reply With Quote
Old 04-01-2005, 02:21 AM   #6
smbrouss70
smbrouss70's Avatar
Looks Sweet, What kind of wheels are those? Are those 22's up front, too?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 04-01-2005, 03:16 AM   #7
valleycustom
Yeah those are 22x10 and are coddington's, but i'm not sure what kind. I'm just using those to setup the suspension. I have a set of 22X10 viper 6 coddingtons that are going on it once it's finished.
Old 04-01-2005, 10:50 AM   #8
smbrouss70
smbrouss70's Avatar
All I can say is DAMN!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 04-01-2005, 05:43 PM   #9
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
How much lift will you have in the front? I have 10" of front lift. If I took my upper bump stops out or put thinner ones in I may get another 1" or so. They are limiting downward travel.
I like the idea of the rear cantilever. I'm going to try some bags with more stroke first.
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 04-02-2005, 04:20 AM   #10
PRUNEDA
'87
PRUNEDA's Avatar
Looks awesome
PRUNEDA is offline   Reply With Quote
Old 04-02-2005, 06:17 AM   #11
Portmod7
Portmod7's Avatar
NICE work man. All that stuff looks choice!
Portmod7 is offline   Reply With Quote
Old 04-02-2005, 10:28 AM   #12
XXL
Seņor Member
XXL's Avatar
You have 10" of lift with airbags in a stock-like (stock w/aftermarket arms) dual control arm setup? Are you sure about that figure?
XXL is offline   Reply With Quote
Old 04-02-2005, 01:29 PM   #13
valleycustom
I will only get 8" in the front due to the balljoins binding up.
Old 04-02-2005, 06:00 PM   #14
bagged72blaz
Got L.E.D.s
XXL
I'm positive. I measured it last month. I have airlift bags on the front stock spindles and SoLo lower a-arms. I get only 7 1/2" in the rear with firstones. I'll take pictures soon. Sort of waiting on my new RH mirrior, and my diamond cut headlights, and clear parking lenses. When I get all my stuff installed I'll take full raise, and dumped pics, Side to side, front up rear down, rear up front down, all at 145 psi
valleycustom
you'll have the opposite problem I have, not the same lift front and rear. It bugs me. It wouldn't be bad if I had a programable electric leveling set-up of some kind. That way one button you could come full up, by setting your height to the lowest level be it front or rear.
Old 04-02-2005, 11:39 PM   #15
fastbagged68
fastbagged68's Avatar
XXL
Its called AccuAir! Check it out!
fastbagged68 is offline   Reply With Quote
Old 04-03-2005, 08:19 PM   #16
pbmcauliffe
pbmcauliffe's Avatar
And the Dakota Digital controller for existing systems, and the new Select-a-ride from Easy Street/Airlift.
I received three of them Friday at my shop and they are very well put together kits, I will be putting on on my truck this next week.
pbmcauliffe is offline   Reply With Quote
Old 04-04-2005, 04:46 PM   #17
bagged72blaz
Got L.E.D.s
pbmcauliffe
How much for the Easy Street/Airlift Select a ride? All the others are pretty spendy. But to tell you the truth I like the set-up on Chassis Techs Touch Screen Controller way more functions and doubles as a DVD screen.
Old 04-04-2005, 08:31 PM   #18
72MARIO
72MARIO's Avatar
Wow.
There is alot of work involved in that frame.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-04-2005, 02:58 PM   #19
valleycustom
I received one of the wheels yesterday for a test fit. For future reference for anyone running 22x10's you will need to run a 7" bs to clear the fenders if your bagged and bd. Here are some pictures.
jr
Old 05-06-2005, 10:43 AM   #20
laid67c10
laid67c10's Avatar
nice work cant wait to see it finished , looks sic already!!!
49 Chevy - currently under construction being bagged and hunting for a LS drivetrain!!!
09 - Harley nighttrain on air ride!
laid67c10 is offline   Reply With Quote
Old 05-08-2005, 01:19 AM   #21
BK
BK Built
BK's Avatar
curious as to how much you have to cut into the hood supports or whatnot, are those wheels gonna clear the hood? Bye the way, looks awesome.
BK is offline   Reply With Quote
Old 05-10-2005, 02:52 PM   #22
cojnit
Nothing clever
cojnit's Avatar
wow the LA crowd is really getting down. I think I am the only one that doesn't have air yet.
Got "the Midas Touch!"
cojnit is offline   Reply With Quote
Old 05-26-2005, 03:57 PM   #23
valleycustom
I'll have to cut the whole side of the inner fender out. I have some ideas for new hood hinges that mount on the firewall. The wheels will clear the hood by a 1/4" when it's all the way down.
Old 05-26-2005, 10:24 PM   #24
valleycustom
More Pictures
Here are some more pictures of the progress.
Old 05-26-2005, 11:12 PM   #25
jlaird
jlaird's Avatar
dude, that's incredible. I don't know what to say except, how the hell does it work?? What are those arms on the outside of the notch?
jlaird is offline   Reply With Quote
