Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 07-02-2005, 11:39 AM   #1
Rokcrln
Rokcrln's Avatar
New to the board, thought I'd say hi.
Hi guys~ I just found out about this site from the Pirates of the Rubicon site yesterday. I have had my 71 SWB for about 5-6yrs now and it has been in project stage for about 4yrs. I tour it apart the weekend before I found my first house so it got trailered and burried in the garage. I did alot of work to it and then just found a new (1928) house we just bought so it trailered once again. I now have a 25x45 shop to work on it and all my other toys. I live in Northern Cali near Sacramento in a small town called Winters. Population is about 6k and I am 15 min from Lake Berriessa. I work in the bay area as a superintendant for a metal framming co.
The truck started off stock but in real great shape. I then found some rust under the floor and covered up in the rain gutters so I found a new cab that is rust free. The truck sits on 335/35/17's in the back and 245/40/17's up front for now. I will end up with 18's and 20's when finished. It has an old kit from air ride tech I put on 5yrs ago and that is going to get replaced with their ride tech pro kit. The frame has been Z'ed 4" behind the cab. The truck has a 2" body drop done to it so the front and rear sections of the frame have been stepted to match things up. I moved the motor back in the frame 2" to make a bit more room in front for a super charger and the motor is a 93 vett LT1 so their is not a dist. to worry about. The tranny is a built up 700R4 with a custom tube cross member to allow the exhaust to run above the frame. The rear is a 12 bolt with 3.43's and an eaton posi. The truck is 4 wheel disk, PS, PW, CC, and A/C from vintage air. The bed has had the most work done to it so far. I have sectioned the inside 6" to make up for the 4" Z and the 2" body drop. At the tail gate floor it is stock height and 6" in it angles up at a 45 and then flatens out to the lifted bed floor. The bed ribs needed for this ramp came from the mini tub I did to tuck those 335's so all the bed ribs line up from tail to head. I used two sets of fender wells to build the tubs and keep all the lines looking stock through out the bed. The truck is ready to have the body shimmed on the frame to the correct height so I can check for body allignment prior to finishing the body work and paint. The frame is ready for sand blasting and powder coating then I will run all my lines and it will be ready for a painted body.
Well this is as far as things have gotten so far. I will be a bit before I can get back on it due to I have another project I need to finish first. It is a rock crawler I am building for the rubicon. It is almost ready for testing and then Paint and PDR coating. Then the 71 chevy will get finished and after that I have a real clean 71 Ford bronco I am going to build a 2wd street rod out of. Well here are a few pics of my toys. I need to find the box with my build up pics of the truck so I can share more detailed shots of what I listed above. Well thanks for letting me rant on about my sh!t and I hope to meet as meany of you as I can here in the future.
Kevin
Winters 95694
Rokcrln is offline   Reply With Quote
Old 07-02-2005, 12:12 PM   #2
Hunter
Lovin' Arizona Since 1961
Hunter's Avatar
Welcome from Arizona. Nice Chevy! H.
"Religion is like a toothbrush: Everybody should have one, but I don't want yours" - Will Rogers
Hunter is offline   Reply With Quote
Old 07-02-2005, 12:31 PM   #3
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi! Looks like you have some cool toys.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 07-02-2005, 12:56 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Hi from western Michigan==Fun toys nice shop, what more can a guy ask.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-02-2005, 01:02 PM   #5
dtlilly
dtlilly's Avatar
Welcome
dtlilly is offline   Reply With Quote
Old 07-02-2005, 01:12 PM   #6
68cajun
68 C/10
68cajun's Avatar
Nice projects you have there, and welcome from south Louisiana.
(2009) GMC Sierra Denali 6.2 AWD
(67 C/10 fleetside SWB)
(2018GMC Yukon Denali) Wifes Car
68cajun is offline   Reply With Quote
Old 07-02-2005, 01:17 PM   #7
Rokcrln
Rokcrln's Avatar
Thanks Guys!
Yeh I am a fabricating nut. It is my drug of choice. I build everything from roll cages to full rolling chassies. Everything from rock crawlers to mall crawlers. I like to do all my own work so when we came accross this shop it had a house and granny unit that came with it. The lot is 10k sq/ft and the shop is 25x45 full concrete construction with an in ground pit ( soon to be filled in once the 4 post lift gets installed). The granny unit is small at 12x20 and 2 story. The house is a 1928 craftsman bungalow 1700 sq/ft and in need of alot of work. I have already put on a new roof, added two dormer on the front of the house to give more room in the attic for a future home theator. I am now re-wiring the whole property. It only has a 60amp service for all three buildings and it is all knob and tube construction. I am installing a 400amp service with a 200amp panel in the basement of the house and a 200amp panel for the shop that will feed a 100amp sub panel to the granny unit. Then the next big job is adding a second floor to the shop for a bar/ pool room that will be 25x30 leaving the other 15' open to the shop for the lift to have room for car stacking. I had a 1300 sq/ft home before w/a small 2 car garage that you could not park in with all my fab tools. Now I can set up my shop and be able to build almost anything I can think up. Once the buggy is done then I will be back on the chevy hard untill it is screeming down the road. I will try and find some pics of the work on the truck. Here is a before and after pic of my latest work on the house.
Kevin
Old 07-02-2005, 01:48 PM   #8
Rokcrln
Rokcrln's Avatar
Here is a pic from 5yrs ago befoer tear down. I had put in a 65 vett 327 and added air ride to it. The pic is at peir 23 in San Francisco. The other pis is a week later and one week prior to finding my last house. I have always had great timing
Old 07-02-2005, 01:58 PM   #9
71HUGGER396
Confirmed Truckaholic
71HUGGER396's Avatar
Welcome to the board. Nice toys you have there.
1968 50th STEP SIDE SHORTY, 350/350, a/c, ps, p,b
Daily Driver, 1970 Cst short fleet, all black, 350/350,
1970 2wd Blazer, 2wd, 6 cyl. 3 spd, original, now a 454, 350turbo, 3.73 posi, on the road
1971 2wd fleet shorty, 454, 700r4, 3.73 posi, SOLD to 67OLDSTYLE72
"My rig's a little old but that don't mean she's slow" - SAWYER BROWN's Six Days On The Road
SEMPER FI "I use to be a lean mean fighting machine, but now I'm a huffin, puffin, over stuffin love muffin"
71HUGGER396 is offline   Reply With Quote
Old 07-02-2005, 02:54 PM   #10
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Welcome To The Board From The Great White North! Nice Truck(s) Too!
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 07-02-2005, 02:59 PM   #11
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
Welcome from SoCal
Nice truck.
Have a good friend who just moved from Winter's to Utah .
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 07-02-2005, 03:12 PM   #12
armyavncowgirl
C10 Junkie
armyavncowgirl's Avatar
nice truck!
ROCKS! like the other toys but the is what really tugs on my heart strings. I'm working on my 67 at the moment. Hereis a sample: check out my links if you wanna see more
Keep up the good work on that beauty! She'll be HOT!!!!!
09 Chevrolet HHR --- Cruck --- cross between a Car and a Truck
Former rides:
1967 C10 LWB
1972 C10 LWB
1969 C10 LWB (parts truck)
armyavncowgirl is offline   Reply With Quote
Old 07-02-2005, 05:02 PM   #13
Randy70C-10
Randy70C-10's Avatar
Welcome to the board bud, your truck is sweet!! Can you get any lower??
Randy70C-10 is offline   Reply With Quote
Old 07-02-2005, 06:36 PM   #14
You've done a lot of nice work to your truck and love those old Broncos. WElcome to the board.
Old 07-02-2005, 08:08 PM   #15
Long Roof
Old School, New Style
Long Roof's Avatar
Welcome from Ohio
Aaron
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 07-02-2005, 08:23 PM   #16
tomatocity
tomatocity's Avatar
Hi Kevin,
Welcome to the board from Sacramento. Very, very nice truck. Heck it was nice before it got low.
Winters is one of my favorite places for breakfast whether it be by car or bicycle. Give me a holler some day and we can go to the Putah Creek Cafe at 2 Main Street.
Sacramento
Kevin
Winters 95694
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 07-03-2005, 12:45 AM   #17
Rokcrln
Rokcrln's Avatar
Thanks to all for the welcome. And tomatocity I don't know where 2 main is but the putah is right behind my house!! Give my a shot next time you come this way. And yes by bike is ok only if you are out of gas!!!
Kevin
Old 07-03-2005, 02:17 AM   #18
Ray_71Chev_in_PA
Ray_71Chev_in_PA's Avatar
Kevin,
Welcome aboard! Look what lives in the corner of my garage as well!
Ray
1971 C10/350/Blue/White/Blue in Boyertown, PA
Ray_71Chev_in_PA is offline   Reply With Quote
Old 07-03-2005, 02:59 AM   #19
tomatocity
tomatocity's Avatar
Kevin
Putah Creek Cafe is 2 Main Street and the restaurant (across the street) is 1 Main Street.
Will do next time I am in Winters. Your house is probably easy to find. I might even bring my rough truck. Sunday going to Lucerne to see two project C10's, 1969 & 1972. Monday going to Pittsburg to get some parts and tell some lies with Green Horn.
Old 07-03-2005, 08:05 AM   #20
panhandler62
Java Mechanic
panhandler62's Avatar
Welcome. ... nice bunch of steel ya got there.
panhandler62 is offline   Reply With Quote
Old 08-26-2005, 08:08 AM   #21
86swb
Born a Chevy Man
86swb's Avatar
That second picture looks like you parked your truck in a bad section of LA. and came back and that is what you had left of your truck. Welcome to the board from Kentucky.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 08-26-2005, 09:24 AM   #22
Matt67C10
Matt67C10's Avatar
Nice toys you got there. Welcome to the board from PA.
67 C10 LWB Stepside- 250cid 6, 3speed
Matt67C10 is offline   Reply With Quote
Old 08-26-2005, 10:44 AM   #23
redhead69
fugedaboutit
redhead69's Avatar
That rock crawler is sick!!
Currently truckless
redhead69 is offline   Reply With Quote
Old 08-26-2005, 02:35 PM   #24
bowtie
bowtie's Avatar
Welcome to the board from Saskatchewan.
I wish I had half your talent and skills. Nice PU's....
~70 GMCprostreet swb 396/700r NOS 575 hp "the Brick"
~72 chev swb w/68 front clip "GM Millenium corvette yellow"
I use and accept Paypal
bowtie is offline   Reply With Quote
Old 08-26-2005, 03:29 PM   #25
Yukon Jack
Yukon Jack's Avatar
I don't know how I missed this post originally. Welcome and those are some sweet trucks!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
