Old 07-30-2005, 05:18 PM   #1
MikeS
Active Member
MikeS's Avatar
TPI done....It Runs!!!
Finally finished up the TPI install today....and it actually runs! Pretty well in fact
I started it July 4th weekend and worked on it on and off. Installing the in tank fuel pump and plumbing the lines was probably the worst of it. I made LOTS of trips to the local parts stores for all sorts of little bits and pieces. If I ever do this again I'm buying a trashed Z28 or TransAm and pulling the whole thing myself. I got about a 90% complete system off of an '87 Trans Am but it was a 305 so I ended up swapping in bigger injectors and getting the chip reprogrammed. The chip still needs some tweaking (idles way too high) and I need to clean up some wiring but it works!! The throttle response is awesome.
Here are some pics of it and the Tanks Inc. fuel pump.
The rides:
'72 Blazer 350/4spd/Tuned Port Injection
'69 Firebird 400/4 speed
2001 Dodge Dakota Sport 4X4/4.7L V8/5 spd/Headers/Jet Chip, etc. Daily Driver
2002 Airborne Zeppelin (roadbike) Titanium frame/Campy Chorus
2004 Filippi Italia S (rowing shell)
MikeS is offline   Reply With Quote
Old 07-30-2005, 05:19 PM   #2
MikeS
Active Member
MikeS's Avatar
Got a few parts leftover. Anybody need anything
The rides:
Old 07-30-2005, 05:38 PM   #3
71RestoRod
71RestoRod's Avatar
Congrats, Mike! That looks like a really clean install
How does the fuel get into the Tanks Inc. pump well? Is there a trap door or opening that I can't see?
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 07-30-2005, 05:44 PM   #4
MikeS
Active Member
MikeS's Avatar
There is just a little hole on the side of it. It was sort of annoying, the whole thing was about 2" to short so I had to fab up an extension to get the well into the bottom of the tank. The fittings just cleared the crossmember on the bed...I was sweating that one a bit.
The rides:
Old 07-30-2005, 06:00 PM   #5
Jimmy72custom
Jimmy72custom's Avatar
Nice job!! I can see allot of work went into the conversion.
Jimmy72custom is offline   Reply With Quote
Old 07-30-2005, 06:01 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-30-2005, 11:27 PM   #7
jakeslim
Premium Level Member
jakeslim's Avatar
looks insane! Why did you choose not to set upt the fuel pump externally? Either way, looks too cool
69 K5 CST stock- 350, 4speed
77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's,
jakeslim is offline   Reply With Quote
Old 07-31-2005, 12:47 AM   #8
71swb4x4
71swb4x4's Avatar
Looks really good.
What did you do for the thermostat housing? That was one of my biggest problems. I ended up going with a Buick housing and enlarging the holes. It comes off in the right direction now.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-31-2005, 07:25 AM   #9
vtblazer
vtblazer's Avatar
Looks great!
So I guess there's still hope for my TBI that's been sitting here in the box for the last 4 years.
Nice work in a cool blazer.
vtblazer is offline   Reply With Quote
Old 07-31-2005, 08:41 AM   #10
MikeS
Active Member
MikeS's Avatar
From everything I read, the pumps are designed to go inside the tanks. They are pushers, not pullers, and it also helps keep them cool. The other issue was with the fuel pickup. Since these old tanks aren't baffled if you aren't careful you can run the pump dry on turns or angles. That wouldn't be a good thing. This also gave me the chance to clean out the tank, paint it, and the underside of the bed at the same time.
The rides:
Old 07-31-2005, 08:57 AM   #11
MikeS
Active Member
MikeS's Avatar
Originally Posted by 71swb4x4
Looks really good.
Yeah, that was one of the setbacks in putting this thing together. I originally bought one for a Chevy van that points straight up. It looked good until I tried to put the intake plenum on.
So then I took the orginal one from the truck and turned it 180-degrees and it looked like it would work until I cracked it installing the temperature sensor.
I finally got a Transdapt housing from Summit for $10. http://store.summitracing.com/defaul...2D9468&FROM=MG
It's got the 1/2" hole in it for the stock temperature sending unit.
I basically put it on backwards so it points about 45-degrees towards the valve cover. Then I got a piece of radiator hose with a 90-degree bend in it and cut it down to size. It rubs up against the valve cover so I still need to see if I can find a way to protect it.
The rides:
Old 07-31-2005, 10:02 AM   #12
Mike C
Mike C's Avatar
Looks great! Makes me want to get mine installed. But other projects beckon...
Keep us updated on your progress.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-31-2005, 10:50 AM   #13
2wdBlazer
The Blazer King
2wdBlazer's Avatar
How much for the carb? What size and condition? Are those true HEI wires? How much?
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 07-31-2005, 12:25 PM   #14
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Very nice work....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 07-31-2005, 03:31 PM   #15
c-1072
carb and parts
Put me in line for those parts . I need some stuff for a stock 350 and i think that would work fine . got a price ?
c-1072 is offline   Reply With Quote
Old 08-02-2005, 11:45 PM   #16
smokekiki
Mike
smokekiki's Avatar
here is a thread on tstat housing for a tpi.....http://67-72chevytrucks.com/vboard/s....php3?t=107057
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 08-04-2005, 08:21 PM   #17
hilljob26
hilljob26's Avatar
what about the wiring,isn't there a computer of some sort you need,what exactly did you have to splice into to get it to work,this is one mod that i am really considering,but really need alot more input before going that way,any wise words would help
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 08-06-2005, 05:00 PM   #18
MikeS
Active Member
MikeS's Avatar
Actually, the computer and splicing into the wiring is the easy part of the whole conversion. There are only like 5 wires that actually need to be connected to your truck. But the wiring harness is huge with lots of connections to many different sensors.
This is not something that you want to jump into without doing a lot of research first. It's not all that complicated but you've really got to plan it out and understand how the TPI works and what mods are necessary. There are lots of great resources out there that I turned to before starting this project. I spent about a month reading and researching, another 2 months gathering all the parts, and a few more weekends doing the install (which also included more part gathering).
The best places to start are: www.chevythunder.com and www.thirdgen.org. There are also a couple of good books out there that you should get. One is sort of the standard on TPI (I don't have it in front of me so I can't remember the name) and the other is from Stealthconversions.com.
The easiest way to do this conversion is to buy an entire Z-28 or TransAm, pull the engine and all the associated wiring intact, then part out the rest of it. But I don't usually do things the easy way
If after doing all the research you still want to go through with the conversion, there are a bunch of us here that have done it and we're all more than happy to put our 2 cents in.
Mike
The rides:
Old 08-06-2005, 05:07 PM   #19
saulgoode
saulgoode's Avatar
What kind of MPG are you getting out of your set up?
saulgoode is offline   Reply With Quote
Old 08-06-2005, 05:11 PM   #20
MikeS
Active Member
MikeS's Avatar
No idea. I've only got about 20 miles on it so far. It's going to be tough to figure for a while because I'll probably be a little heavy on the pedal testing it out From what I've heard, the increases in MPG aren't very big though.
The rides:
Old 08-06-2005, 05:30 PM   #21
saulgoode
saulgoode's Avatar
So what are the advantages: horse power, throttle response, electronic control?
Old 08-06-2005, 11:05 PM   #22
71swb4x4
71swb4x4's Avatar
I added TPI to my truck, and I would answer yes, yes, and yes. I would also say that it starts a lot easier and quicker.
Old 08-07-2005, 10:47 AM   #23
EFI is great for off-road.Won`t starve-out on inclines,no float.
Old 08-07-2005, 02:48 PM   #24
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Extra parts?
Old 08-18-2005, 11:34 PM   #25
jimmydean
jimmydean's Avatar
Ok, I have a few questions. But first, I have to say WOW, that looks GREAT!
Did you do or do you plan to do any changes to the engine? I ask because I'm about to have mine rebuilt and I'm thinking about starting the conversion while it's out.
How much have you spent and where did you get the main parts? (ebay, parts yard, garage sale?)
I have been looking at parts yards and ebay, then run the TPI harness from Painless unless I can get a complete setup somewhere.
jimmydean is offline   Reply With Quote
