08-20-2005, 02:40 PM | #1 |
New Project! 67 Extended cab...
This was just droped off at my shop for a few repairs before the board member starts body work and motor swaps.
I will be doing a fire wall smothing job that will blend in the new A/C plate he has as well as just general filling. The stock engine mounts were welded in so they will be replaced with 73 up front mounts. The floor has the typical rust holes above the front cab mounts. The drivers side rocker and inner panel will be replaced. The floor will be built up to handle the new seats he has for the truck(2000 or so front and rear seats) as well as building reart seat hangers off the back of the cab. The frame has a few spots thet got the torch treatment over the years that need to be repaired. Filling the four stake pockets(a long bed was used for the convertion). And a few more items wil be addressed. I will post pics of the before and after work as things progress. Kevin |
08-20-2005, 02:46 PM | #2 |
longbed's have 6 stakepockets. whoever modded the truck so that it's a extended cab couldn't shave a firewall, fix rust, etc.. ?
that's going to look good when it's done. Last edited by matthufham; 08-20-2005 at 02:47 PM. |
08-20-2005, 03:09 PM | #3 |
From what I was told this truck was built in 67 as an extended cab for PG&E or somthing like that. I has not been modified since then. The last owner started to paint it but started out not very good. The new owner is going to have it media blasted once the work is done.
Kevin |
08-20-2005, 03:25 PM | #4 |
nice, so if the body work is that old, you know there's not going to be much bondo around the cab.
08-20-2005, 04:26 PM | #5 |
Chevy Nuttttt
if the truck was done for pg&e how far are you from santa maria?
67' Chev swb step side 69' SS elky 03' Chev ext cab 4X4 hey who lernt me to spell is there anything else? |
08-20-2005, 04:54 PM | #6 |
The guy I am doing the work for is from Vacaville and he bought it from Sacramento I think.
Kevin |
08-20-2005, 06:15 PM | #7 |
Car O'Holic
wow this is going to be cool I can tell already
08-20-2005, 06:15 PM | #8 |
The original build sheet that I found in the back seat says that the truck was built in Fremont Ca and was then shipped to Portland Oregon and from there I don't know, it could have been a forestry truck too or use your imagination as to the original owners and purpose. It originally had a GMC V-6 motor with a 4 speed manual trans. It also came with power steering and power brakes. I have updated the front suspension with suspension from a 1977 Chevy truck to get the disc brakes. The rear will probably be 1979 Cadillac with the disc brake setup. The Cadillac uses the same bolt pattern as a Chevy truck.
08-20-2005, 06:23 PM | #9 |
A few pictures before I started taking it apart
08-20-2005, 07:19 PM | #10 |
Happy to be here
Cool project. Are you going to leave it a GMC or put a Chevy clip on it?
08-20-2005, 07:23 PM | #11 |
Gmc!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
08-20-2005, 08:04 PM | #12 |
I am partial to Chevy so Chevy it must go. All of the GMC stuff is for sale, just don't like the 4 headlights.
08-20-2005, 08:29 PM | #13 |
Designated A-hole!
Another GMC raped! I wish I had the money for the GMC stuff off of it, I have a blazer that's dying to be a Jimmy!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
08-20-2005, 08:31 PM | #14 |
The 69 GMC grill was a nice driver and as I recall the radiator support did not have any rust, have 2 of them too.
08-20-2005, 11:24 PM | #15 |
Kevin and extd56. Can I come by and drool? Really just to see it and meet you. Next week I am going to Pleasanton an could stop by on th return trip.
Ever since I saw a drawing of one I have decided to be on the lookout for one. One commissioned by GM would be my choice.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
08-21-2005, 03:07 AM | #16 |
Send me a PM with time and day!
Kevin |
08-21-2005, 04:44 PM | #17 |
looks cool ... me personally, I would put one piece glass in the rear side windows and lose the sliders ... but that's just me.
08-21-2005, 05:43 PM | #18 |
The rear sliders are already history, I am going to a fixed 1 piece window or a pop out window like on late model extended cabs like I used on my 56 extended cab. The air conditioning will help keep the rear passengers cool I hope.
08-21-2005, 10:51 PM | #19 |
Well I hit it hard tody and made good progress. I filled the A/C hole with the supplied cover the owner gave me. It is intended to just mount over the factory hole but we decided this would look alot better, and it does. I also filled the fresh air vent hole and removed all the rust in the upper corner. Before I closed it off I sprayed the entire cavity with Eastwoods rust encapsolater and then the welded areas were covered with weld thru primer prior to welding. Then I hit all the misc holes left behind form all the years, 20 of them to be exact. For each hole over an 1/8" I cut a filler plate to fit inside the hole. Next was the clutch rod hole. It was a mess but now looks like it never happened. Last thing for tonight was the tranny cover.
Kevin |
08-21-2005, 10:52 PM | #20 |
Then the air vent.
08-21-2005, 10:54 PM | #21 |
Clutch rod hole!
08-21-2005, 11:36 PM | #22 |
Kevin,
Looking good, looks like there is some good metal lurking behind all that paint. I am still thinking on my options for a motor and which way to go either with a carb or fuel injection. |
08-22-2005, 12:04 AM | #23 |
Here is the tranny cover. also since I fit a metal disk into each hole I weld up they look as good on the back sideas the front. This is not a big deal on these areas since carpet or get under coating. But in alot of work that I do they are exposed on both sides. Also this is a much better job then just slaping a chunk on the back and welding in place.
Kevin |
08-22-2005, 12:06 AM | #24 |
Here is the before and after.
Kevin |
08-22-2005, 12:08 AM | #25 | |
Kevin Last edited by Rokcrln; 08-22-2005 at 12:10 AM. |
