08-26-2005, 11:42 AM | #1 |
www.73-87chevytrucks.com
TPI Conversion Progress/Process
This past weekend I started working on the pieces required to convert my '78 Jimmy to TPI. I had purchased an SLP TPI harness back in '95 that they were clearing out and had it sitting around for a while. A while back I picked up a TPI intake, MAP setup and Distributor. Well plans have started moving forward to convert the truck (I HATE carbs..)
Wednesday: recieved the new Blazer EFI sending unit from GM Thursday: ordered fuel lines for a '90 Blazer -not here YET Friday: ordered: Sensor kit, 127749 ecm (turbo app ECM), 350 TPI prom, stainless steel bolt kit, and throttle body gasket kit and it arrived on Wednesday. Saturday: started laying out the TPI pieces and started cleaning them up. Now that the ECM is here I can start repinning the MAP harness from SLP so it can plug into the 7749 ECM and function properly. This should be fun. There are a few other odds/ends that I need, but progress has started.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 08-26-2005 at 12:31 PM. |
08-26-2005, 12:02 PM | #2 |
looks like a lot of fun.good luck cant wait to see it done
08-26-2005, 12:02 PM | #3 |
good good i see those pictures and i see a lot of beer intake b/c i would get mad and quit obviously you see something else. good luck and have fun maybe on of these days i will put up for a motel and you come here and do this for me b/c it would be sweet to not have to pump the hell out of the truck to get it to start in mornings of winter. and the remote start options you can buy be kick a$$ also
square body trucks an addiction or an investment either way they consume all my extra time and money |
08-26-2005, 12:19 PM | #4 | |
yeller
Good luck on the swap CHris, and keep of posted for sure!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
08-26-2005, 02:17 PM | #5 |
Slots go on anything!
If you are going to run a MAP sensor and all, why not use the 730 (speed density) ECM? Or do you mean MAF? It seems like that would simplify things a lot if your harness is a SD harness.
1974 Jimmy- 5.3/4L80e/NP241 |
08-26-2005, 02:19 PM | #6 |
Professional Grade
Just think, I did all of those wires by hand! lol
Actually, they are pretty simple, Either go from ECM to ECM, or from 12 volts to ECM. Just a whole lotta little individual circuits Turbo app eh? I can't wait to see that engine run with a turbo on it! I am very seriously considering turbocharging mine too
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
08-26-2005, 04:19 PM | #7 | ||
This engine won't get alot of boost because it is completely stock, but I got the ECM for when the Jimmy gets an inline6 with Twin Turbos. I am planning on integrating one of my brothers STS systems on the Jimmy with the 350.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
08-26-2005, 04:28 PM | #8 |
That makes a whole lot more sense. I didn't catch the boosted part.
08-26-2005, 05:30 PM | #9 |
Be sure to do a good write-up with alot of pics.
Looks awesome Capt!
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
08-26-2005, 05:51 PM | #10 |
Happy to be here
Hey, I'm impressed already. You got all the parts out and took pictures. That in itself is a good start....
08-26-2005, 09:32 PM | #11 |
man, those pictures just make my head hurt
1987 350 TBI lowered 5/7 |
08-26-2005, 10:49 PM | #12 |
its just $$$$$
I've been there, it should be pretty straight forward. I can see where it would be kind of intimidating for someone who is not "electronically inclined". Should be a sweet set-up with a little boost.
08-27-2005, 01:30 AM | #13 |
Professional Grade
Well, I discovered the problem with mine tonight. Napa sent me the wrong gaskets for my truck, and I never noticed the difference, so they leak terribly bad on the lower runner to intake connections. I'm gonna buy a tube of 02 sensor safe high temp RTV, and use that rather than paying for more gaskets. Should run a heck of a lot better after that!
08-27-2005, 11:54 AM | #14 |
Thanks for the props. There will be a write-up of all the steps involved from start to finish. I may even try a video of the instalation process.
Wrong gaskets. That sucks! BTW, I forgot to tell you your 73-87chevytrucks.com T-shirt is on its way to you.
08-29-2005, 08:45 PM | #15 |
Since i have converted both my K5's to tbi i'll be waiting on progress reports for this tpi conversion....the turbo part of the equasion has really got my interest piqued...
Are you going to mount the turbo on the drivers side exhaust manifold like i have seen before...and since you are going speed density who's going to reburn the chip for your mods? Doug W.
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
09-12-2005, 03:00 PM | #16 |
Update as of Sep. 2nd:
I recieved the EFI stainless fuel lines from Classic Tube. They apparently sent me more than what I needed/wanted though, but... Anyways, here is the latest pic: The plans for the turbo is it will be mounted under the truck where the current muffler resides. This is simular to the setup on my brothers 2000 Silverado that is running an STS Turbo kit. (where the turbo and other pieces will come from) http://www.gracemotorsports.com/current.html It has put down 400hp (8lbs of boost) to the rear tires on a stock 5.3L with over 120K miles on it and climbing. The 749 ECM runs a 2 bar MAP setup and it has the capability to run up to 14.7lbs of boost. I don't plan on going over this on the current motor, but in the future any chips will be reburnt by me.
09-12-2005, 03:34 PM | #17 |
Professional Grade
Man, those are nice fuel lines! I just bent my own for my truck. Ain't pretty, but they work real well
09-12-2005, 05:00 PM | #18 |
Yeah, I am taking the simplified route on this one. They are really nice though.
09-12-2005, 05:24 PM | #19 |
You get what you pay for
You lost me at ECM.
Glad to see you getting back into hot rodding/working on something. I'm with Ken on this, it's a big step in it's self just to see pics of the parts. LOL Now don't do like you did about 5 years ago and shove everything in a box somewhere and forget about it. Oh yeah, did I mention carbs rule.
Mike 1985 Chevy C-10 |
09-12-2005, 05:59 PM | #20 |
Sorry Mike, the Computer should allow me to do this with no problems (brothers pickup):
http://www.gracemotorsports.com/video/STStruckPull2.wmv Yeah. I sold the Jeep, so that money pit has died. The money from its sell is going to the pickup. Hopefully progress pics on it will be coming up soon also. I am trying to get the Jimmy fixed first though. I hope it won't last 5 years until progress, but..... Oh yeah, life is better when injected
11-07-2005, 01:26 PM | #21 |
Re: TPI Conversion Progress/Process
Update: Wifes foot surgery has taken up most of my time the last couple weeks, but...
3 weeks ago I sandblasted the upper intake plenum and tubes. This weekend I started repinning the ECM 7730 wiring harness to work the the 7749 ECM. PICS to come:
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 11-08-2005 at 11:56 AM. |
11-07-2005, 01:41 PM | #22 |
glad to her the wife's foot is doing better tell her that before long she will be back in the kitchen cooking, cleaning, and pampering to your every need. this will alow you a lot of time in the garage/shop if you need a hamic just call me i will loan you mine so you can sleep out there also.
11-07-2005, 04:34 PM | #23 |
I'm back with 2nd truck!
Glad to hear your wife doing better Chris. With all the work you have done on that I'll keep my carb. I'm a better plumber than electrician.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
11-07-2005, 05:55 PM | #24 |
Thanks for the kind thoughts.
Brandon, If I wasn't adding the Turbo ECM, there I would be done. It isn't as bad as it looks, seriously. 86 GMG, she isn't that kind of wife, it would be closer to say get back to helping with the wire mapping on the harness. We eat out A LOT.
11-07-2005, 08:35 PM | #25 |
Professional Grade
Chris -- Have you still got the 730 ecm?
I need one to convert my truck to speed density, and I am having a hard time finiding one in the local junkyards...
