Old 09-07-2005, 08:38 PM   #1
72 longhorn BB
72 longhorn BB's Avatar
Will new Chevrolet 8-bolt rims fit on a 72 3/4 ton
Just wondering if new (2004) Chevrolet 8-bolt rims fit on a 72 3/4 ton?
72 longhorn BB is offline   Reply With Quote
Old 09-07-2005, 08:39 PM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Bolt pattern for all 8 bolts are the same. You may want to check back spacing however just to make sure.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 09-07-2005, 08:41 PM   #3
acloco
Check the inner diameter as well...hub size may be a problem.
acloco is offline   Reply With Quote
Old 09-07-2005, 10:05 PM   #4
hilljob26
hilljob26's Avatar
ive seen others due it,i know hummer wheels fit,so i wouldn't doubt that the others would
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 09-07-2005, 10:07 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Good info above. I *think* that if anything, our trucks may have smaller diameter axle stubs than some others, should be no problem. All (GM, Dodge, Ford) 8-lugs were the same until recently; Ford changed to an oddball pattern. Kinda makes sense!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 09-07-2005, 10:44 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Stocker, i think it is just the 70 and older with the small lugs, I think the 9/16ths lug is about the same as modern day....I am 99% sure they are all 15mm which is as close as you'll get to 9/16ths.
The back spacing will be a major issue. They will be tucked in way too much, esp if the wheels are off a 4X4. Bolt them on and go around the block before spending any cash.
It'll look like a real fat guy on a kids bike from the front or rear.
Last edited by Longhorn Man; 09-07-2005 at 10:45 PM. Reason: must....ignore....the voices.....
Old 09-07-2005, 10:58 PM   #7
jostrans68
Jostrans68
jostrans68's Avatar
Check Wes's site he has them on his garden truck and another
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 09-07-2005, 11:47 PM   #8
Russell
Professional Grade
Russell's Avatar
I've got a set on my 80, and the backspacing is perfect all around. The tires are flush with the fender wells, and go in a fair ways. They don't rub at all, and look great. I don't have center caps on mine though, because it is a 4x4 with a big set of manual hubs sticking out up front, and a bit 14 bolt axle sticking out the back. I just painted the hubs nicely, and used some black lug nuts, looks real good!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-08-2005, 12:52 AM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Andy, I was talking about the axle stubs (hubs), not lug studs. I seem to recall that our oem whhels would not fit over some Ford hubs, for instance, because the Fords had a larger diameter hub - but if we wanted to, we could put oem Ford wheels on our rigs, as their axle holes were a larger diameter.
- Mike -
RIP El Jay
Old 09-08-2005, 02:19 AM   #10
jsbgump
Gone Fishing
jsbgump's Avatar
I know that if you try to run the 99+ 6 lugs you have to waller out the center hub a bit to fit 70- trucks. It might be the same for the 8 luggers. Just my 2 cents.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 09-08-2005, 06:54 AM   #11
Blazer1970
Blazer1970's Avatar
This is not an issue with the 8 lug wheels.
Blazer1970 is offline   Reply With Quote
Old 09-08-2005, 07:39 AM   #12
The `92 steel wheels from my K3500 would not fit over the hubs on my`72 K/20.That 72blu396 guy had them on his,but not sure if he had original axle,as other things on the truck weren`t.I asked ,but never got an answer about this.And,never saw a picture of the VIN-spec sheet.
Old 09-08-2005, 08:27 AM   #13
72gord
Never enough time!!
72gord's Avatar
I've got a set of the aluminum wheels off of an 03 2500HD on my 72...fit fine, just have to buy the lug nuts (new ones are metric) I have a set of 285/75-16 on there with no lift and have no problems, but I don't off road it
72gord is offline   Reply With Quote
Old 09-08-2005, 09:05 AM   #14
72 longhorn BB
Thanks for the info. what do you mean about new metric lig nuts though. My 72 has standard threads, right?
Do you have any pictures of it?
Old 09-08-2005, 09:16 AM   #15
FormerMember
FYI and not being a smart a$$.
This is true of all the chevies, gmc's and dodges.
Furd went metric in 97 on most trucks.
FormerMember is offline   Reply With Quote
Old 09-08-2005, 09:41 AM   #16
72gord
Never enough time!!
72gord's Avatar
You can't use the lug nuts off a newer truck, they have metric threads. To install the center caps you have to buy 9/16 internal thread nuts with the external threads to hold on the caps, I got mine at a swap for a $1 a piece...have also seen them on e-bay.
Old 09-08-2005, 09:42 AM   #17
72gord
Never enough time!!
72gord's Avatar
No pics right now...will try to get one up later
Old 09-08-2005, 10:12 AM   #18
I think any tire place should be able to get you the 9/16" Duplex lugs.The`88-up type trucks(8 lug)used 14mm,I`m pretty sure.
Old 09-08-2005, 11:25 AM   #19
Scrubby
Check out GMTrucks.org
Here is a writeup I did on putting these wheels on my burb:
http://www.gmtrucks.org/wiki/faq/8_lug_wheels
Scrubby is offline   Reply With Quote
Old 09-09-2005, 08:57 AM   #20
72gord
Never enough time!!
72gord's Avatar
Scrubby...good idea on the rear caps, I'll give it a shot. That was one problem I hadn't solved yet, planning on cutting my front caps so my lock outs stick out through them. Also considered getting one ton caps for the rear, not sure, but assume they would be deeper.
Old 09-09-2005, 10:36 AM   #21
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
I've got em on my 72 c-20. Got the double lug idea from another board member. Forgot who so can't give credit due. I would like about a 1/2" wheel spacer though. Truck looks like a kids wagon from the rear. Not bad at all up front.
chickenwing is offline   Reply With Quote
Old 09-09-2005, 11:05 AM   #22
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
The newer 8 lug wheels fit 3/4 ton 2X4s without any issues. You will however have to buy new lug nuts. The newer wheels bolt holes are cut at 60 degrees requiring a 60 degree lug nut. Here is a link to where I found some on the web: http://www.ezaccessory.com/.sc/ms/ca...y%20Lug%20Nuts
They have them in 7/16", 1/2", and 9/16" with external threads for the center caps.
I found that on the "Garden Truck" that the front wheels I had to sand the centers out slightly in order for the wheels to slip over the hubs without getting stuck on. No problems with the rears though.
My solution for the center cap problem was to break out the ole "Roto Zip". Since the front hubs, and back axles stick out too far to be able to install them, I used the roto zip with a circle cutting atachment to cut out 4 3/8" holes for the axle and hub to stick through. I painted the rear axles with ceramic aluminum color paint to clean up the look. I think that it turned out great. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 09-09-2005, 11:56 AM   #23
72 longhorn BB
So what you'r saying is there are sme changes needed?
It sounds by what you are saying is that I will have to cut the center out of the caps on my new 8 luggers, right?
thanks for the link for getting the new lugs.
can you clarify what you mean about spacers, and the truck looking like the kids wagon?
Old 09-09-2005, 11:59 AM   #24
Classic Heartbeat
For the rear yes, but not for the front if you have a 2 wheel drive. WES www.ClassicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 09-09-2005, 12:48 PM   #25
cheyenne10
cheyenne10's Avatar
Hole cutting
I did the hole cutting on a pair of rear caps and painted the axle ends just like Wes suggested Thanks again for advise). Turned out great and got a new Roto-zip too! Only problem I had with Roto-zip was the need to go real slow on cut. Broke a couple of bits and smelled a lot of melting plastic. I could not find a bit rated to cut better, just take your time and watch for the bit comming loose. I am running the 245's that came on these wheels alot. I might upgrade to larger tire if they fit wheels some day. Truck looks nice right now though.
Bob
cheyenne10 is offline   Reply With Quote
