Old 11-23-2005, 09:22 PM   #1
mike nutt
69fatmotor
mike nutt's Avatar
progress pictures
heres a few pictures of the latest progression my '69
mike nutt is offline   Reply With Quote
Old 11-23-2005, 09:30 PM   #2
mike nutt
69fatmotor
mike nutt's Avatar
Re: progress pictures
Originally Posted by mike nutt
heres a few pictures of the latest progresson my '69
more pics
Old 11-23-2005, 09:48 PM   #3
68 short step
nice..... something has been done to your inner fenders, but what? how much of a chop did ya go? looks real good so far. what engine are ya planning to go with?
68 short step is offline   Reply With Quote
Old 11-23-2005, 09:55 PM   #4
subtle71
Granddad's Ol' Truck
subtle71's Avatar
Some serious work done in those pics! Nice job. Keep 'em coming!
1971 Chevrolet Custom 10 short step-side
2005 GMC Sierra SLT 2500HD crew cab 2wd
[I]1971 Chevrolet Custom 10 Deluxe lwb fleet-side
subtle71 is offline   Reply With Quote
Old 11-23-2005, 10:08 PM   #5
djracer
djracer's Avatar
he has done lots more than the pics show! Grafted on a new top fixed hacked up rockers, and firewall, z'd the frame swapped to 85 running gear and brakes he hasn't been working on this truck long at all for the amout of progress! He is putting in a wide motor!
Hope you didn't mind me filling in some blanks Mike!
Kevin
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 11-23-2005, 10:17 PM   #6
roj2323
is the trailing arm crossmember flipped like i think it is?
looks awsome! i actuly didin't realize the the frame was Z'ed at first. nice work.
ondrew
roj2323 is offline   Reply With Quote
Old 11-23-2005, 10:22 PM   #7
djracer
djracer's Avatar
yup!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 11-23-2005, 11:02 PM   #8
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Very nice work!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 11-23-2005, 11:29 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
What kind of panard bar set-up is that?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-23-2005, 11:34 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
What does flipping the crossmember like that do? I have never heard of doing that. Very nice progress so far keep us posted..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-24-2005, 12:29 AM   #11
Striker169
Car O'Holic
Striker169's Avatar
nice
Striker169 is offline   Reply With Quote
Old 11-24-2005, 12:50 AM   #12
67cst
i love summertime
67cst's Avatar
might be a stupid question but when you z the frame like that what do you do with the trans x member? wouldnt that make for some strange angles?
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 11-24-2005, 12:55 AM   #13
djracer
djracer's Avatar
I think he made a newcrossmember and raised it up!
I think flipping the xmember allows for more ground clearance!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 11-24-2005, 09:05 AM   #14
mike nutt
69fatmotor
mike nutt's Avatar
maybe this will answer a few questions,the reason this truck is so heavily modified, the only thing left of the original truck once i got ride of the rotten body and the worn out and hacked up suspension, all i had left was frame so i decided to build a custom truck. the two cabs i used came from djracer and the rest from from '69 long stepside(have great set of stepside fenders and useable tailgate left over)and the complete suspension from '85.for the questions, the inner fenders were trimmed to clear the 3" z'd frame, the trailing x-member was flipped to less'in the angle of the axle end of the trailing arm with the 6" drop in the rear, not nessicary but looks better to me. worked out fine just had to redrill a few holes.also added 4" rings to run exaust trough.the panard bar came in a kit from early classic enterprice,awsome stuff. as far as the engine it is a hot little 396 backed by th400 with 2800 stall rear gears 411. i had to custom build motor mounts to lower engine almost 2"and fabbed trans mount to raise trans 1.5" ,the motor and trans has been in the truck fits great. with all the changes, i am mocking every thing up to make sure there are no problems later. comments and sugestions welcome. i'll post more pics with more progress. thanks.
Old 11-24-2005, 09:14 AM   #15
FormerMember
How tough was the 4" holes? I assume it was done while you had the cross member out of the truck?
I am quasi thinking of doing the same thing.
FormerMember is offline   Reply With Quote
Old 11-24-2005, 10:35 AM   #16
mike nutt
69fatmotor
mike nutt's Avatar
it was done with x-member out, just cutt some 1/2" wide pieces of 4" pipe ,took the plazma cut the holes ,test the pieces , bolted x-member back in , tacked the pipe in , removed x-member and welded up. could be done in the truck i guess.
Old 11-24-2005, 11:14 AM   #17
Jimbotronics
YA YA
Jimbotronics's Avatar
Kick a$$ work my friend!
Jimbo
'72 SWB - 350 (frame-off resto in progress - donations accepted)
'04 Chevy Avalanche
'03 Cadillac CTS (wife's ride)
Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707
Jimbotronics is offline   Reply With Quote
Old 11-24-2005, 11:18 AM   #18
SOON2BLAZE
SOON2BLAZE's Avatar
Tight!
SOON2BLAZE is offline   Reply With Quote
Old 11-24-2005, 11:42 AM   #19
72MARIO
72MARIO's Avatar
What are you going to do for carpet to cover the new trans tunnel ?
Your truck reminds me of what mine looked like 3 years ago. Same yellow and I even found a green rust free door too.
Nice work.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-24-2005, 11:52 AM   #20
72MARIO
72MARIO's Avatar
Nice progress
2005 TAHOE DD
Old 11-24-2005, 11:56 AM   #21
djracer
djracer's Avatar
all he'll need is high hump carpet!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 11-24-2005, 12:30 PM   #22
mike nutt
69fatmotor
mike nutt's Avatar
it's gonna have custom center console to cover any problems there.
Old 11-24-2005, 12:31 PM   #23
djracer
djracer's Avatar
Mike got any pics of the speaker box you did for the other truck? It was too sweet!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 11-24-2005, 12:53 PM   #24
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
wow....nice progress
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 11-25-2005, 05:35 PM   #25
mike nutt
69fatmotor
mike nutt's Avatar
ok kevin, here are some pictures of the speaker box in my red 86.
