Old 12-31-2005, 10:46 PM   #1
matthufham
tell me if this is safe
when i bought the truck the p/o had put a keg in the bed used for a gas tank. it had 3/8 hose to the fuel pump and worked fine. i now have a blazer tank but i still want to keep the keg. the blazer thanks has 5 fittings on it, here's what i have.
1)filler 1 1/4"
2)vent 5/8"
3)open 3/8"
4)charcoal canister (capped)
5)sending unit to pump
i was thinking i could use that 3/8 fitting by running hose to the keg and then i can use it as an auxilary tank. what i want to be able to do is fill the blazer tank and fill the keg with gas. the keg will gravity drain into the tank until all it's gas is gone, then the blazer tank's gas will be used. i can then go twice as far without filling up.
Is this safe? the keg is way stronger and better fit to hold gas than the blazer tank and i don't think it'll leak at all, so it seems safe but my dad says it's dangerous. i'm pretty sure he just doesn't want the keg to go back in the truck when all is said and done though.
so i ask the experts. or
i found a pic
matthufham is offline   Reply With Quote
Old 12-31-2005, 11:01 PM   #2
Green Machine
Green Machine's Avatar
Re: tell me if this is safe
The gas level in the full keg will likely be much higher than the fill neck on the blazer tank, unless you have a completely sealed cap on that, gas will leak out around the fill neck. Or if you happen to remove blazer cap before keg is empty, you will have a big mess. Listen to your father
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 12-31-2005, 11:04 PM   #3
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Listen to dad
I would have prefered the keg when it was full of coors
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 12-31-2005, 11:24 PM   #4
matthufham
hmm ok i can see that happening, pulling the fill cap and releasing gas everywhere. i have a 77 c10 filler with a locking/vented cap but it would make no difference if i remove it with a full keg, unless i have some sort of 1 way filter something on it. anybody else?
possibly put a valve on the keg to control when it flows, or maybe an electric pump.
Old 12-31-2005, 11:25 PM   #5
Americanrider
Reading this made me think of Hank Hill....lol Just install a selector switch that will shut off the gravity drain to the blazer tank. When the blazer tank is empty flip the switch and run the keg tank. Everything you need you can find on a camper special truck in a wrecking yard. I found an electric tank switch in a 76 with dual tanks, it mounts to the frame rail and it works great.
Americanrider is offline   Reply With Quote
Old 12-31-2005, 11:35 PM   #6
matthufham
i actually had a selector switch, but i think i threw it away. the 77 it came from had 1 tank but used to have 2 so it had the swith but that's all that remained except a vacent fuel door. i'm thinking of an electric fuel pump on a switch, and a fuel pressure gauge so i know when to shut it off. then as you said when the tank is low, fill it up, and no gravity feed.
Old 01-01-2006, 12:14 AM   #7
matthufham
ok here's another idea to make this silly thing work. when at the gas station, if the fuel gauge says full, fill up the keg, if it's half empty, fill the blazer tank til it's full, and then cap and fill the keg. this is using the gravity feed system.
Old 01-01-2006, 12:43 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Personally, I'd forget the whole thing.
Go down to your corner inspection station and see what they have to say.
Old 01-01-2006, 12:52 AM   #9
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Thats part of the reson I bought a 70.
When the manager comes out intyroduces himself and says there is no way were even looking at this vheicle you know life is good
Old 01-01-2006, 01:25 AM   #10
70short/step
70short/step's Avatar
The Keg will work and is safe with the ideas that were offered here, Just mount it without using those 2X4s that are in the pic!
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 01-01-2006, 01:27 AM   #11
Longhorn Man
Come to Columbus...no inspection at all.
Old 01-01-2006, 08:42 AM   #12
Blazer1970
Blazer1970's Avatar
I don't know why you would want that keg taking up space in your bed. It will be in the way all the time. Just stop at the gas station more often. They are always open and willing to sell you fuel. If you have to keep the keg, plumb it like a normal dual tank set-up with a selector.
Blazer1970 is offline   Reply With Quote
Old 01-01-2006, 09:05 AM   #13
I wouldn`t put beer in a gas tank.So,I wouldn`t put gas in a keg.I put cargo in the bed and install auxilary tanks for extra fuel under the truck.I`d rather have the original gas tank.I would definately use a tranfer switch for more than one tank.
Old 01-01-2006, 09:12 AM   #14
68C15
blood type; Retumbo
68C15's Avatar
if you have to ask then it probably isnt safe. whats gonna keep the keg in place in an accident?
not being mean, just giving my .02
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 01-01-2006, 11:48 AM   #15
LSGarage
LSGarage's Avatar
Like special-K said, beer, gas and truck beds have their own places in this world.
67 GMC 4x4, 305 V-6, 4-spd
86 S-10, 2.8 2WD LWB
01 Suburban (family hauler)
13 Honda CRV (wife's wheels)
03 Malibu (daughter’s car)
LSGarage is offline   Reply With Quote
Old 01-01-2006, 08:33 PM   #16
matthufham
to clear things up and continue the thread...
1) i have a spare tire on the right side of the bed, and i want the keg on the left
2)no inspection for antique vehicles registered vehicles in texas
3)if i get t-boned where i plan to mount the keg, i've got more problems than an explosion or rupture.
4)if i run a fuel tank selector, the keg has no sending unit and i'll never know when to fill up. That's why i wanted to plumb it into the blazer tank.
5) the 2X4's raise the keg, so the drain fitting doesn't touch the floor. it's lower than the mounting flange, but overall, a sturdy package with the 2X4's.
so even though today isn't the thinking man's day to be thinking, anybody else got an idea.
Old 01-01-2006, 08:40 PM   #17
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
No reason to have a sending unit. If you're determined to run the thing. Just run it dry and switch to the other tank. Myself, I think I'd listen to the majority on this thread.
low'n slow is offline   Reply With Quote
Old 01-01-2006, 08:53 PM   #18
matthufham
yea that's how old farmer ricky ran it, the truck came with a fuel gauge about 4 feet long (a wooden dipstick).
i'm destined to not use it as an auxilary tank, but i'm putting it in the truck no matter what, it might as well have a function.
Old 01-01-2006, 09:10 PM   #19
70short/step
Use something else besides wood 2X4's to space it above the floor. Make some steel brackets, but I would not use wood!
70 Short/Step
Old 01-01-2006, 09:18 PM   #20
krue
Designated A-hole!
krue's Avatar
Properly mounted I don't see a problem. BTW I've got one just like that I'm gonna use for a gas tank for my rail buggy. Seen them used for years, never heard of a problem.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 01-01-2006, 09:18 PM   #21
FormerMember
People have done this for years. "Rat Rod" is function over form. I don't have a problem with the keg's strength, take a look at most of the gas tanks out there {plastic}. If it's mounted sturdily, then a vehicle impact has a ton of frame to go through to get to it.
My only issue would be abraision on the rubber fuel lines causing a leak.
My last diesel truck had a 55 gallon home fabricated tank in the bed that would trickle into the fill neck of my main tank. Perhaps you could do that, with a cut off /check valve?
FormerMember is offline   Reply With Quote
Old 01-02-2006, 08:45 AM   #22
dwaite72lnghrn
Personally I think it's a bomb just waiting to go off... The gas tanks made of plastic and tin are ment to expand and it ruptured they will leak yes and spill gas but that tank will hold and violently explode. Yes they used them in the old dune buggies and rat rods but today there is better things to use. You as the driver/owner are responsible for any damage done by your not complying with federal transportation laws.
You lend your truck to someone or sell it and they do something stupid and it blows up you have to live with and pay for it. If you want it be aware just because you have no inspections you are still required to obey the laws governing these things. be safe disconnect it, polish it make it look good but don't put fuel in it.
My opinion. Better to be SAFE than SORRY.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 01-02-2006, 08:51 AM   #23
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Wow, as usual, opinions are like you know what, everyone's got em
I say run it if that's what you want, but I also agree with the majority.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-02-2006, 11:56 AM   #24
Longhorn Man
I say look into the legality. If Tx says go for it and tells you to use a fuel tank that is not D.O.T. aproved, then when something happens, you can file charges again's the state after the victoms of the accudent get you for all you are worth.
Old 01-03-2006, 11:44 AM   #25
matthufham
ttt
