Old 01-01-2006, 03:46 PM   #1
aitch
aitch's Avatar
S-10 door seals?
Recent comments by Putter and Yukon Jack indicated that they were using S-10 seals on their trucks doors. There was also an indication that the fit was tight, making the doors hard to close.
I plan on replacing my door seals soon and wonder if the S-10 seals are a good idea.
Is this a worthwhile modification? Better than aftermarket rubber?
69 GMC 3/4 ton LWB
383 TH400 Dana 60
'84 300ZX
'79 Nova (for sale)
aitch is offline   Reply With Quote
Old 01-01-2006, 04:30 PM   #2
70short
Re: S-10 door seals?
I too am using S-10 door seals. They are tight, however getting better. I would not go back to the original seals myself. Talk about ease of installation!
Gary
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 01-01-2006, 06:55 PM   #3
zeeklu
What makes the S10 seals better? Chris
zeeklu is offline   Reply With Quote
Old 01-01-2006, 07:01 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Can some one enlighten us on this?
Why?
How?
Pics?
Old 01-01-2006, 07:01 PM   #5
tnblazerk5
User #12137
tnblazerk5's Avatar
they just slip on instead of glue and there alittle thicker i think
tnblazerk5 is offline   Reply With Quote
Old 01-01-2006, 07:03 PM   #6
70c10
67-72 Addict!
70c10's Avatar
I think the rubber is better. NO glue needed and easily removed for paint jobs. If you want to try them out before buying, go to a junk yard and get one off a S-10, take it home and install it on your truck and you will see for yourself. (This is only to give you a general idea of how they fit and look). I agree with 71swb4x4 about probably being too short overall.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-01-2006, 07:19 PM   #7
71swb4x4
71swb4x4's Avatar
Here are pictures of mine
http://67-72chevytrucks.com/vboard/s...d.php?t=122688
If you get seals from the junkyard they will probably be too short. When you order the weatherstripping they give you extra, but on our trucks it's only a couple inches.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-01-2006, 10:24 PM   #8
68 short step
how hard is HARD (closing the door)? is it a good pull, or put your weight into it, or slam the poop out of it? 1 to 10, 10 being the hardest with the s10 and also with the stock weather strip
68 short step is offline   Reply With Quote
Old 01-01-2006, 10:48 PM   #9
70c10
67-72 Addict!
70c10's Avatar
I would say close to 10 either way.
Jim
Old 01-02-2006, 12:37 PM   #10
JDL
JDL's Avatar
Cant you ajust the door so it don't close so tight?
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 01-02-2006, 02:27 PM   #11
ed455
Captain Ed
What years? Are they all the same? I was just at my local GM dealer and I used '89 for a year (just out of thin air) and was quoted $89 per door and they were NOT cut to fit. I noticed on the other thread mentioned above, that it was noted that the S-10 wether stripping was "cut to fit". So, again, the question is: what years do we look for?
If you ain't bleedin', you ain't workin'!
1999 C3500 LS 7.4L
ed455 is offline   Reply With Quote
Old 01-02-2006, 05:30 PM   #12
71swb4x4
71swb4x4's Avatar
82-93 S10&15 Door Opening Weatherstrip
When he mentions "cut to fit" he is saying that you cut it to fit. It's not the exact length out of the box. That is GMC Paul's weatherstripping, and I am not sure if the dealers is the same.
Old 01-02-2006, 05:55 PM   #13
Myself
I grabbed some seals at the junkyard off a 80ish fullsize chevy and put on my wife's '68. They work fine with no door slamming.
Myself is online now   Reply With Quote
Old 01-02-2006, 06:52 PM   #14
BowTieMan
BowTieMan's Avatar
I bought brand new weatherstiping for an s-10 from lmc and at first they were stiff but after about a month I can close my doors with a slit push.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 01-02-2006, 08:21 PM   #15
ed455
Captain Ed
What do you do at the bottom? There's no lip at the bottom. Sorry if I soung ignorant but when I go this truck it had no weatherstripping at all. It was a basket case,
1999 C3500 LS 7.4L
Old 01-02-2006, 08:27 PM   #16
mocwon
Keep On Truckin'
mocwon's Avatar
GMC Paul's sell Precision (or Precise) brand door gasket seals for the S-10s for about $50-60/pr and they work great. Yeah, they're a little stiffer than the stock glue-on gaskets but they loosen up over time. IMO they are the only way to fly. Plus, they have a lifetime warranty.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 01-02-2006, 08:29 PM   #17
71swb4x4
71swb4x4's Avatar
There's supposed to be a lip at the bottom!
It is under the sill plates.
Old 01-02-2006, 08:37 PM   #18
crazy longhorn
Fabricate till you "puke"
Umh...I thought it was 2 lips on the bottom L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-02-2006, 08:49 PM   #19
ed455
Captain Ed
I want to keep water from splashing up out of the gutter, you guys are familiar with the gutter, right?
1999 C3500 LS 7.4L
Old 01-02-2006, 10:22 PM   #20
ed455
Captain Ed
Great. The PO was a friggin IDIOT! He put in new rockers (poorly) and shaved the bottom lip needed for the weather stripping. There is NOTHING under the sill plates. The lip just abruptly ends after making the turn about an inch at the bottom. Moron!
1999 C3500 LS 7.4L
Old 01-02-2006, 10:27 PM   #21
tnblazerk5
User #12137
tnblazerk5's Avatar
just lay the seals on the rocker and put the sill plates over them
or do ya mean theres a big hole there ya can see though to the ground ?
Old 01-02-2006, 10:46 PM   #22
ed455
Captain Ed
LOL! No, I can't see the ground. The floor there is just smooth. I am thinking about welding in piece of 1/8"x1/2" piece of steel on it's edge.
The PO fancied himself a body man. His "work" has caused me more time and energy than I he'd never touched the thing. I am DEFINITELY no body man, but many times I have fantasized about beating the PO to death with his welding gun. I'm sure my congregation and God would frown on that, though.
1999 C3500 LS 7.4L
Old 01-02-2006, 10:57 PM   #23
tnblazerk5
User #12137
tnblazerk5's Avatar
yup i would say you would get frownd on
Old 01-03-2006, 12:59 PM   #24
Yukon Jack
Yukon Jack's Avatar
Here are the S-10 seals I'm using. Pretty sure I bought these from GMCPauls - they are listed on his site.
They fit extremely easily and there is maybe a 1/2" to 3/4" gap on the bottom where there seal ends just about meet.
Mine have been installed about 3 months now and they have broken in nicely. Still need to close the door firmly, but that is fine with me.
I'd do these again in a heartbeat.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-03-2006, 07:12 PM   #25
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
I welded a piece of 1/2" X 1/2" 20 (?) guage angle where my lip had rusted away.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
