02-11-2006, 12:12 AM | #1 |
Project Penicillin~ 68 crewcab build up!
This is one of my new projects itbelongs to "extd56" one of the board members. I will be doing all the panel and rust removal as well as a full build up. extd56's plans for it are to fix all the rust(3 rockers and inner panels, both kick panels,cab corners and as of last night the passenger side winshield post and both passenger side doors. Then shorten the frame 12" (it is a long bed now) but leave the rear stock behind the rear wheels. Once this is done I will shorten the bed to fit and install a 91 burb 42gal gass tank under the rear and add a gass filler door to the passenger bed side. Next is to install a 91 TBI 454, AOD and T-case, 4" lift and 35" tires. Also I will be rewiring the truck with a painless harness, doing body work, smoothing the fire wall, paint the inside, door jambs and inner doors and the fire wall. If things stay the same the out side will be orange with a white top and burb trim around the cab just below the windows.
I will be posting pic's as I go and try and explane things as I go or as questions are asked. I will not get to all of them just because time is short and I am building this truck after a full days work. I will also be doing small jobs for others as they come up and inbetween steps on this project. Just a quick note on this truck. It started out as a Suburban that was chopped behind the third door and a truck cab was grafted on the back. Who ever did the work originaly did it right and used the tops of the truck doors instead of leaving the square tops that so many people do when trying to build a truck like this. The top skin was cut off and laid back down an inch or so lower to get rid of the high roof on the stock burbs. Then it was placed on an 80's crew cab long bed frame and adjusted to fit. ight now it has a 350/350 combo with a T-case on the back. First task will be the drivers side rocker.. Kevin Last edited by Rokcrln; 02-11-2006 at 12:25 AM. |
02-11-2006, 12:17 AM | #2 |
Re: Project Penicillin~ 68 crewcab build up!
Well all the parts are now here or at extd56's house so it is time to get started. First order of buisness is the rockers and cab corners. Tonight I started with the drivers side rocker, inner rocker panel, kick panel and "A" post bottom removal. This week end I plan on cutting out all the rust , treat the affected areas and replace all that was removed (minus the pile or rust) and prime. Then maybe start on the other side. I hope you all enjoy the build!
Kevin Last edited by Rokcrln; 02-11-2006 at 12:20 AM. |
02-11-2006, 12:19 AM | #3 |
The fun begains!!
Kevin |
02-11-2006, 12:23 AM | #4 |
Happy to be here
Holy crap what a mess. It's good to see you at it again. Post some pics of the truck so we can see it....
02-11-2006, 12:25 AM | #5 |
Back in the sticks
Looks familiar! hehe, should be a nice project. Whatever happened to the 67 extended cab? Is she still in the works or done? Thanks for the pics and keep us updated. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
02-11-2006, 12:31 AM | #6 |
Get that rust,"outta there!!!"Said like an umpire on the third steerike.It`s going to be nice.Question:why not a standard shortbed?I guess this question is for Extd56.
02-11-2006, 12:45 AM | #7 |
The extended cab is on hold for now not knowing of its fate at this time.
Reason for a shoter bed but not a short bed is for two reasons. extd56 likes it as a full on long bed crew cab and I think it should be a shorter than short bed. It is his truck but I guess I wined enought to make him want to shut me up so he is letting me shorten in ftont of the wheels to give it a shorter look but keeping the real long to hide that 42 gal fuel tank. Trust me that tank will take up every bit of that over hang.. Kevin |
02-11-2006, 12:48 AM | #8 |
When I read the title, the first thing that came to mind was Extd56.
Are you going to leave it a 3 door or are you going to add a left rear door?
03 Tahoe 72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays. |
02-11-2006, 12:45 PM | #9 |
Aluminum slot wheels rule...
That rust looks worse than school lunches........have fun working on the truck.
02-11-2006, 12:46 PM | #10 |
02-11-2006, 01:15 PM | #11 |
PROJECT 7DEUCE
Looks like it should turn out really nice keep us posted..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
02-11-2006, 04:24 PM | #12 |
Yes it will be a bit of work removing and replacing it all
Wel I started the morning off finishing the cut away prosses. Then I bent up some inner rocker panels that have a nice return lip for the floor to sit on as well as a small return lip at the bottom to add a bit of rigdity to the rocker. Then it is a matter of clamping it all into place and test fitting it all. Once you are happy with the first round of fitting then I like to use self tapping sheet metal screws to hold it all in place while I test fit the door. Once that is to my liking I remove the door and unscrew it all, clean and paint all the parts with rust prevenative paint/ primer. Time for lunch then weld away! Kevin |
02-11-2006, 04:25 PM | #13 |
and
02-11-2006, 06:54 PM | #14 |
Looks great. It always amazes me what good body guys can do in a short period of time.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-11-2006, 07:04 PM | #15 |
I really enjoy watching your builds. Gets me motivated to practice my welding and metal skills. I like that trucks look. I'd love to find one like it someday.
02-11-2006, 07:20 PM | #16 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
02-11-2006, 10:13 PM | #17 |
One down and two to go
It is ready for a light skim coat, seam sealer and paint!! Kevin Last edited by Rokcrln; 02-11-2006 at 10:15 PM. |
02-11-2006, 10:22 PM | #18 |
One more unexpeted find! I stared to remove paint for the drivers side cab corner replacement and found way more bondo than I expected! The quarter panel is almost 3/4" out past the "door jamb" area. It might be easier to just remove it and fab up a fourth door The truck cab's door jamb is still in place and a B post would not be the hardest thing to scratch build, but who knows! I need to dive into my magazine archives and find that 2wd 4 door crew that was built a few years ago. He listed what he did to get a fourth door.
Kevin |
02-12-2006, 01:18 AM | #19 |
Funny, I was just talking about the crew cab tonight, and BAMM heres a post. Love the look of the crew cab, keep us posted on the progress.
67- 72 Parts collecter |
02-12-2006, 04:11 AM | #20 |
I vote for the fourth door. It's nice to have when 3 people are seated in the back. Also it is easier to get a bench seat in. And bolting down the left rear seat bolt to the floor might be difficult unless the sliders move the seat far enough forward. At least in a burb you have all the space to get behind the seat. Nice work. Keep the progress pics coming!
02-12-2006, 05:22 AM | #21 |
so, I am not familar with the 70's pick ups, is that a true crew or is it something someone fabbed up?
66 Chevy P/U 1/2 ton (new best Oct 09 9.78 @ 139 w/1.3760ft) http://i8.photobucket.com/albums/a41...erdd5d5045.gif |
02-12-2006, 10:32 AM | #22 |
When a burb and a pick up get in a head on this is what happens! Burb front half of the cab and a truck rear section grafted together.
Kevin |
02-12-2006, 10:35 AM | #23 |
sweetness i wish i could find something like that it be cool to drive
02-12-2006, 12:15 PM | #24 |
Nice work!
could you do me a favor and take some pics of the body mounts? Im going to be putting a 70 cab on a 79 frame and would like to see what they did for the body mounts. Thanks
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
02-12-2006, 12:27 PM | #25 |
Just curious Rokcrln, from start to finish on the floor, rocker repair,etc. about how many hours have you got in to it? I'm going to start replacing panels next weekend. I'll be way slower but I'd like an idea.
Thanks.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
