05-03-2006, 06:15 PM | #1 |
Tub Stiffeners, what do you guys think
These are popular out here. While they may not be the best looking I think they work pretty well. These are used on the prerunner trucks out at that sand dunes. I have my top off and I'm sure the tub could use some stiffening. Since I'm not doing 50mph on sand dunes I bet I could get away with a not so aggressive angle. The 45degree angle really takes up a ton of space.
I tried checking the search and couldn't find what some of you have done before. I remember you guys building boxes or something like that. They only extended into the bed about 6in or so.
Rob "RunTMCfan" |
05-03-2006, 09:40 PM | #2 |
Re: Tub Stiffeners, what do you guys think
doesn't the tail gate keep the side together at the latches?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
05-03-2006, 09:50 PM | #3 |
the ones ive seen were all tied into roll bars or roll cages. ive never seen em in the tail gate. are you planning on running with out your tail gate?
72k5 4wd 04 Tahoe 02 Roadstar Warrior 2000 Buick Lesabre on 20's |
05-03-2006, 09:53 PM | #4 |
I'm not planning on running with out the tailgate. These are what's used out here at the tailgate for prerunner trucks. They do run with out the tailgait. I'm just wondering if you guys think this would work for the front corners. Or something similar.
I need to find a OE rollbar before I do something permenant. More importantly, I would like to see or hear about other options. I can how the roll bar would work. You could even do a couple of brackets if your welding skills were ZERO like mine.
Rob "RunTMCfan" Last edited by RunTMCfan; 05-03-2006 at 10:06 PM. |
05-03-2006, 10:07 PM | #5 |
what are you trying to accomplish? Why do you need the body to be stiffer?
05-03-2006, 10:09 PM | #6 |
theres a truck on this forum with stiffeners in the front right behind the seats didnt take up too much space. looked good too. im gonna try to find it.
05-03-2006, 11:34 PM | #7 |
Thanks for looking 671...
When I'm driving with the top off the tub corners in the front are moving just enough to rattle at the door strikes. This is what I'm trying to fix. Secondly the additional support is probably needed anyway. Also, I believe my left rear corner is taporing away (out) as it gets to the top. My goal/intention to to square up the tub and keep it that way. And by doing this I may be able to have a more rigid tub that will not rattle against the door stikes. The shot of the stiffener is more of a concept photo. I do not want to use an exact duplicate of that. It would be a bit too much.
Rob "RunTMCfan" Last edited by RunTMCfan; 05-03-2006 at 11:35 PM. |
05-03-2006, 11:38 PM | #8 |
I think that stiffening the frame might work for your problem. It would require more work but you would have ugly bars in the back either. What do you body mounts look like? If they are worn it could cause this problem.
05-04-2006, 12:02 AM | #9 |
I am replacing the body mounts. I put 1 in this afternoon and have all the rest loosened up. Even with the tub bolted down properly in my head I still see the top corners of the tub, where it meets the doors still needing some support.
I will see if there is a difference when I'm done with the mounts.
Rob "RunTMCfan" |
05-04-2006, 10:18 AM | #10 |
No,I DON'T have Tourett's
New body mounts will probably take care of your problem. Take a look at your rocker boxes too. I had a door that rattled and found that when the previous owner replaced a bedside, 5 bolts were cut and never replaced.
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
05-04-2006, 10:45 AM | #11 |
I've never seen a Blazer that didn't rattle with the top off...
I never run a top and mine rattles like crazy, good thing the exhaust is so loud! You could bolt in a bulkhead (kinda like the ones used with the half cabs) It would certainly stiffen everything up... Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
05-04-2006, 11:02 AM | #12 |
The Blazer King
On my old 4x4 Blazer the Spare tire carrier swung open with a 33 in tire and the tailgate down, these would have came in handy. It always looked like that carrier was gonna rip off the Quarter panel cause it was so heavy.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
05-04-2006, 11:20 AM | #13 |
SKINNY TIRES RULE!
I don't see any real point unless you are going to be running across the desert at 100 miles per hour.
Replace your body mounts and see how that works.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
05-04-2006, 11:22 AM | #14 | |
Like this is what most "pre-runners" we see on the roads do anyways haha |
05-04-2006, 11:33 AM | #15 |
This what you are looking for? (doors shut with a solid feel now) (also roll cage is tied into windshield frame-nothing moves with top off)
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer Last edited by jhow66; 05-04-2006 at 11:37 AM. |
05-04-2006, 11:42 AM | #16 |
Complete buildup here:
http://pg.photos.yahoo.com/ph/jason_burkhart/my_photos
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
05-04-2006, 12:23 PM | #17 |
There we go! Pretty much the same thing but yours is custom and much nicer. Thank you. I will check out your build photos.
Most of the prerunner guys out here are posers. But if you go to the desert and watch the guys at the dunes you will regularly see $100k+ rigs of all types.
Rob "RunTMCfan" |
05-04-2006, 03:08 PM | #18 |
thats the truck i was talking about!!! nice job jhow66!!!
72k5 4wd 04 Tahoe 02 Roadstar Warrior 2000 Buick Lesabre on 20's Last edited by 671blazer; 05-04-2006 at 03:09 PM. |
05-04-2006, 03:14 PM | #19 | |
05-24-2006, 08:28 PM | #20 | |
05-24-2006, 10:33 PM | #21 | |
05-24-2006, 11:05 PM | #22 |
Those tailgate bars would work well with a lumber rack. I have over loaded the rack on my pickup to the point of flexing the bedsides,
05-24-2006, 11:20 PM | #23 | |
05-25-2006, 12:07 AM | #24 |
PROJECT 7DEUCE
IIRC that was a s@w cage???
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-25-2006, 07:06 AM | #25 |
I'd say, look deeper.
A stiffener will just be a temporary band aid for what's really going on. JMO. As far as tying a roll cage into the windshield frame & body that's also tied into the chassis, there's two definite camps on the theory. Do some research, what works for some may not be the answer for your K5. Disclaimer: Not making a 'right' or 'wrong' statement, just saying there's two distinctly different ways to installing a cage and how it gets tied into the vehicle. |
