Old 05-21-2006, 07:11 PM   #1
67sss
67sss's Avatar
parting out 69 1 ton
got it home did a compression and test and have decided to part it out rather than fix it. Everything will not include shipping. Truck is a 6-cyl (292) auto, pb. Let me know what you want off of this. The heater controls, black arm rests and the dash pad are spoken for. I'll start with:
west coast mirrors-$10 each
auto. linkage-$30
metal dust cover $10
67sss is offline   Reply With Quote
Old 05-21-2006, 07:19 PM   #2
67sss
67sss's Avatar
Re: parting out 69 1 ton
oops! wrong place,hopefully MOD can move it for me .
Old 05-22-2006, 10:24 AM   #3
bobvilla67
does it have the auto crossmember?I need the spacers where it bolts to the frame.thanks
1968 Custom 10 SWB
1970 2wd Blazer 350/400
1972 K20 292/350
bobvilla67 is offline   Reply With Quote
Old 05-22-2006, 06:31 PM   #4
67sss
67sss's Avatar
clearance lite pics
bobvilla67- yes it has the auto crossmember, not sure by what you mean about the spacers?
Old 05-22-2006, 06:47 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
They are faded pretty bad.. .I'll pass and let some one more desperate than me grab them.
Old 05-22-2006, 06:51 PM   #6
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I'll take the light lenses!!!!!!
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 05-22-2006, 07:24 PM   #7
67sss
67sss's Avatar
Robert- yours PM sent
Old 05-22-2006, 08:02 PM   #8
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I'm looking for leaf spring rear suspension exhaust hangers for the passenger's side.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 05-22-2006, 08:41 PM   #9
silvertonguedevil
silvertonguedevil's Avatar
Have a torch? I need the center section of the cross member that the driveline passes through. I only need the center section so if you could cut it on each side of where the rear trailing arms bolt up, that would be perfect. I am in no real hurry so if you wanted to wait until you sold things that made it easier to get to, that would be fine.
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 05-23-2006, 12:30 PM   #10
bobvilla67
I have a crossmember from a 1/2 ton and it is to small for the 1 ton frame I have.someone posted pics from a 1 ton crossmember and it looks like a spacer on the bottom where it bolts to the frame.is the whole croosmember different from the 1 ton and 1/2 ton?I 'm not sure maybe someone can answer.thanks
1968 Custom 10 SWB
1972 K20 292/350
Old 05-23-2006, 12:34 PM   #11
Livrat
Member #1049
Livrat's Avatar
Yes all the AT crossmembers are the same.. the 1 tons have a spacer..
Livrat is offline   Reply With Quote
Old 05-23-2006, 01:23 PM   #12
silvertonguedevil
Not trying to hijack your thread here but.....so I need a cross member from a 1/2 ton or 3/4 ton only?
-Greg
1974 C20 Cheyenne
Old 05-23-2006, 01:24 PM   #13
silvertonguedevil
...and is an automatic cross member different from a stick shift?
-Greg
1974 C20 Cheyenne
Old 05-23-2006, 01:47 PM   #14
Livrat
Member #1049
Livrat's Avatar
silvertonguedevil...All of the automatic crossmembers are the same... 1/2ton, 3/4ton and 1ton.. Just the 1 tons used a spacer because the frames are taller..
The manual transmission trucks used 2 different crossmembers which are riveted to the frame under the belhousing.. the 6 cyl is different from the V8..
Old 05-23-2006, 02:52 PM   #15
silvertonguedevil
We may be talking about different cross members. I'm not talking about a transmission cross member. I'm talking about the cross member that the driveline actually passes through. Some had a carrier bearing and some did not but that's the cross member that I'm talking about. It would be the first one after the tailshaft on your transmission (and the driveline passes through it).
-Greg
1974 C20 Cheyenne
Old 05-23-2006, 05:32 PM   #16
Livrat
Member #1049
Livrat's Avatar
silvertonguedevil.. Opss.. my mistake.. yes were are on different pages.. sorry.. I do not know if they are the same between 1/2ton and 1/4 ton.. the 3/4 ton ones could be made of thicker material.. the 1 tons would be taller.. anyone??
Old 05-23-2006, 06:21 PM   #17
67sss
67sss's Avatar
I'll take some pics later of both x members and maybe that'll help.
Old 05-23-2006, 08:16 PM   #18
chucks70
Do you have a pic of the engine and air cleaner if original? Does it have PS?
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
Old 05-23-2006, 08:48 PM   #19
67sss
67sss's Avatar
bobvilla- here's a set of spacers for you.
badpeanut-leaf spring rearend pic and a pass. side exhaust hanger.
silvertonguedevil- 2 pics of x members for you.
chucks70- engine pic for you- only 1 bracket left of the air cleaner setup. I'll check with my cousin, I know he has a complete setup. No P.S. on this. I have a ps gearbox in the shop or are they diff. on a 1 ton.
Old 05-23-2006, 08:51 PM   #20
67sss
67sss's Avatar
more pics
Old 05-23-2006, 10:35 PM   #21
silvertonguedevil
67sss, thanks for the pics but those cross members are totally different from what I have/need. I guess I need at least a 1/2 ton or a 3/4 ton. Thanks again.
-Greg
1974 C20 Cheyenne
Old 05-24-2006, 12:20 AM   #22
67sss
67sss's Avatar
no problem...turn em over, I'm sure they'd work.
Old 05-24-2006, 11:03 AM   #23
bobvilla67
How much for the spacers shipped to 75160?thanks
1968 Custom 10 SWB
1972 K20 292/350
Old 05-24-2006, 12:39 PM   #24
1969K10
1969K10's Avatar
Is it me, or are the mirrors different on each side?
1969K10 is offline   Reply With Quote
Old 05-24-2006, 02:52 PM   #25
ScottH
ScottH's Avatar
How much for the air cleaner assembly shipped to 08753?
Thanks.
ScottH is offline   Reply With Quote
