Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-24-2006, 12:57 AM   #1
Hart_Rod
Hart_Rod's Avatar
1969 SuperBurb build-up (Bagged and Blown!)
*** 6/20/18 Hanging the body trim.....***
*** 4/24/18 Will this thing ever be done???***
*** 3/15/17 All front sheet metal bolted on for the last time.***
*** 10/23/16 FINALLY FIRED IT OFF!!! ***
*** 10/5/16 On the home stretch!!! Finishing up some small details before trying to fire it up....***
*** 11/5/10 Still working on the wiring: fuel injection, body harness, electric fans, a/c and Magnacharger install.... ***
*** 8/6/10 Currently working on the wiring: fuel injection, body harness, electric fans and air ride.... ***
*** 4/2/10 AccuAir is installed!!! Time to start working on the SuperCharger, ***
*** 1/1/10 Painting is complete!!! Time to reassemble, ***
Paint code: red - WA9260; white - WA8624
I put this here because most of the modifications/upgrades apply to trucks as well. The first picture is of the truck when I bought it. It was an original California black plate truck. It had minimal rust, most do to a leaky windshield and the exhaust exiting out the sides. The next picture is a rendering of what I envision it looking like when I'm done (rendering by Zumo graphics).
List of work completed:
Front suspension: ART bags, ART StrongArms, CPP 13" drilled and slotted rotors with dual piston calipers and modular 2" dropped spindle. 1.25" sway bar.
http://67-72chevytrucks.com/vboard/s...d.php?t=174330
Rear: ART bags, Porterbuilt 3" dropped tubular trailing arms, CPP C-Notch, ECE Super track bar, ECE upper shock relocation kit, 5 lug conversion axles, hidden hitch, and flip down tag. CPP 12" rear disc brake conversion with drilled and slotted rotors.
http://67-72chevytrucks.com/vboard/s...d.php?t=162718
http://67-72chevytrucks.com/vboard/s...d.php?t=162641
Build sheet:
Billet Specialties Vintec wheels/Toyo ProxyII tires, rear: 20 x 10 (5" BS) 295/45, front: 20 x 8.5 (5.0" BS) 245/45s
Accuair E-level air management setup (3/8" lines, 3 gal tank, Viar compressor, remote control)
ART StrongArms
ART Bags
CPP 2" modular dropped spindles
CPP 5 lug conversion kit with 13" drilled/slotted rotors and dual piston calipers
PorterBuilt tubular trailing arms with built in 3" drop
ECE Super track bar
ECE Shock Relocation Kit
ECE 5 lug axles
ECE hidden hitch and flip down tag
PST sway bar & ECE lowered sway bar brackets
Misc parts from board members (drag link, brake pedal....)
CPP C-Notch
New 3.73 Yukon Gears and bearings
New Eaton posi unit
Energy Suspension polyurethane body mount kit
Body work:
Replaced/repaired inner and outer rockers, lower inner kickpanel, partial floorborard, and doglegs on both sides (Goodmark parts from Ed at MotherTruckers)
Welded holes in firewall including heater box
Welded in new rear lower quarters
Removed stock upper suburban trim and filled holes
Welded in 5 1/2" remote gas filler lid from 80's Nissan Sentra car
New sheetmetal - Doors, fenders, inner fenders, core support, cowl induction hood, 72 GM inner and outer grill, 72 bumpers
Custom made Mar-K.com upper and lower trim
Custom Billet Aluminum Emblems
Chrome plated/stainless steel factory roof rack
OEM truck cargo light converted to LED 3rd brake light
All new glass, glass rubber, vent windows (RogerKoop), door seals (PrecisionReplacementParts)
Converted manual liftgate extensions to gas struts
http://67-72chevytrucks.com/vboard/s...d.php?t=220511
Removed tailgate scissors and replaced with cables.
Welded in truck bed ends for truck tail lights.
Bottom of body has been sprayed with SpeedyLiner undercoating
Engine:
5.3/4L60E w/ DBW(only 10 miles, 2006 Tahoe)
MP112 Magnacharger with 43LB marine injectors (BIGTEX)
Speartech EFI harness
Clayton Machine Works billet coil covers
Painless body harness
Entropy LSX radiator and dual cooling fan setup
Doug Thorley Tri-Y 323 headers (JAMIE)
http://www.truckinweb.com/tech/engin.../photo_01.html
2007 Cadillac CTsV oil pan and components
ECE LS conversion motor & tranny mounts
ECE 28 gallon Stainless Steel EFI fuel tank (Ricks Tanks)
http://www.earlyclassic.com/catalog.aspx
Custom fuel line setup using Corvette fuel/pressure regulator and Walbro in tank fuel pump (Thanks Shifty, BowTieOgre and PCMCobra!)
Interior
Dakota Digital HDX blue tooth programmable gauges (MCBMatt)
Custom Front row Buddy Buckets with heated seats cup holders, 2nd row Buddy buckets, 3rd row bench.
Tilt Steering column
Custom woodgrain steering wheel
Cruise Control
72 Cheyenne Super Front and rear door panels
Intermittent wipers
Vintage Air Gen IV with Dakota Digital controller
Custom RetroSound 2 Bluetooth radio
Hart_Rod is offline   Reply With Quote
