Old 06-08-2006, 12:45 AM   #1
PBFAB.COM
PBFAB.COM's Avatar
Dropmember in a 69 C10
Here's some installation pics of a Dropmember in a 69 C10. Don't worry, the final hardware will all be grade 8!
PBFAB.COM is offline   Reply With Quote
Old 06-08-2006, 12:58 AM   #2
redneckdds
redneckdds's Avatar
Re: Dropmember in a 69 C10
nice work PB... youve got some good lookin stuff down at your shop!!
'67/70 Chevy C/10
'10 2500 Crewcab Duramax 4wd
redneckdds is offline   Reply With Quote
Old 06-08-2006, 01:02 AM   #3
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Re: dropmember
Definately different, NICE WELDS
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 06-08-2006, 02:11 AM   #4
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Nice welds...yours?
Is that all there is to it? Don't you have to section the cross member as well? Send me the plans!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 06-08-2006, 08:49 AM   #5
PBFAB.COM
PBFAB.COM's Avatar
Thanks for compliments on the welds Stllookn... they do belong to me. It doesn't need to be sectioned... its a replacement crossmember that converts the steering to rack and pinion, gives these trucks the extra ground clearance they so desperately need, narrows up the front track width, and changes the suspension geometry slightly. All changes needed to set one of these trucks ultra-low and still drive comfortably. I will post up more pics tonight. The rack will be mounted, the frame rails clearanced for the rack, we will have the arms back on, and should have the Air Ride Technologies Shockwaves all mounted up as well.
Old 06-08-2006, 08:54 AM   #6
PBFAB.COM
PBFAB.COM's Avatar
Re: dropmember
Different is good!... isn't that what Arby's said?
Old 06-08-2006, 11:33 AM   #7
matthufham
those welds are spectacular! looks like a great start, keep on going!
is that a 73-87 frame? the core support mounts are squared off instead of round like 67-72
matthufham is offline   Reply With Quote
Old 06-08-2006, 12:27 PM   #8
fastbagged68
fastbagged68's Avatar
Re: dropmember
I Like IT! I want to see more pics of that blazer and panel!!!! Any info on the crossmember???
fastbagged68 is offline   Reply With Quote
Old 06-08-2006, 08:36 PM   #9
7deuce
Sold! 2 days after finished
7deuce's Avatar
Re: dropmember
THATS WHAT I SOULD HAVE DONE! Looks SIIIIIICK. My front looks like an abortion compared to that. Keep em commin.
7deuce is offline   Reply With Quote
Old 06-08-2006, 10:51 PM   #10
PBFAB.COM
PBFAB.COM's Avatar
Re: dropmember
The panel is already on the board in 60-66 trucks (under 63 panle), and the blazer is under 67-72 blazers (under low72).
I didn't get everything done today I wanted to, but I do have more pics. The rack is in, the control arms and spindles are mounted up, and the motor/trans is mocked up and ready for mounts. I will not make much more progress on this one until next week.
Oh, it lays frame on a 29 inch tall tire (with a 3 inch drop-spindle)
Old 06-08-2006, 10:53 PM   #11
PBFAB.COM
PBFAB.COM's Avatar
Re: dropmember
One more good one. The cab mounts are not installed yet, that's why the rocker is also touching the ground.
Old 06-08-2006, 11:33 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: dropmember
Did I miss something? What's a Dropmember? Is that something you built, or someone else is building. The welds are awesome, and the end result looks good. I'm just wondering what it is....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-08-2006, 11:40 PM   #13
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: dropmember
Thats what I was wondering also???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 06-08-2006, 11:47 PM   #14
PBFAB.COM
PBFAB.COM's Avatar
Re: dropmember
This is a "Dropmember". It is made to bolt into 63-87 Chevrolet Trucks, 2wd and those who are tired of their 4wd sitting too high. It uses a rack and pinion, designed to be used with tubular arms (Air Ride Tech.) but can be used with stock arms (slight modification to lower arm is needed), it allows the frame to set on the ground with a drop spindle and a 29 inch tall tire. Porterbuilt Street Rods is the manufacturer and they sell for a whopping $1200.
Old 06-09-2006, 12:50 AM   #15
gringoloco
A guy with a truck
gringoloco's Avatar
Re: dropmember
Heh, I felt the same way. It was presented as if we were supposed to know what it was already...
What about motor mounts? Pricing?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-09-2006, 02:16 AM   #16
stllookn
stllookn's Avatar
I was going to ask about the steering linkage but I see you just ran it through the frame...KEWL! Just like the exhaust will be...through the frame! I love those lowered trucks...so much opportunity for creative solutions...LOL! Nice work!
Old 06-09-2006, 06:35 AM   #17
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
Re: dropmember
ok now i am going to ask how much is it!! and do you make one the will work with out a rack? looks like some awesome work!!
gostranger is offline   Reply With Quote
Old 06-09-2006, 11:09 AM   #18
byrd
Union Electrician
byrd's Avatar
Is the linkage from the power sterring box to the sterring column going to nterfere with the exhaust routing?That is some really,really nice welds!!! I think you have a great idea, would love to see the finished truck to show the vesitility(sp) of the new crossmember
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 06-09-2006, 07:34 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
porterbuilt- Thank you for becoming a supporting vendor. It looks like you have an awesome product that will be what many of these guys are looking for.
Articles-
"Refining Sierra"
Old 06-09-2006, 08:05 PM   #20
PBFAB.COM
PBFAB.COM's Avatar
I had a duplicate thread going in the 67-72 forum as well, so we went ahead and merged them together here. Some questions that were previously asked may have already been answered... go back and re-read the thread, if the question has not been answered please ask it again.
Old 06-09-2006, 08:27 PM   #21
lvscott
i've been talking with nathen porter for the past couple of weeks since i saw the dropmember metioned on the low 72 thread. nathen is a really cool guy and is very helpful. i will be ordering my dropmember next week. thanks for all the great pics and all your help nathen.
lvscott is offline   Reply With Quote
Old 06-10-2006, 12:43 AM   #22
smbrouss70
smbrouss70's Avatar
Is there another bracket that isn't in yet, to hold the top of the bags? Also did you move the mounts for the arms inward any, to give a little more clearance? It looks like you might have.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 06-10-2006, 01:47 AM   #23
PBFAB.COM
PBFAB.COM's Avatar
This truck will be running shockwaves, and the mounts are not finished yet. It is narrowed up a bit... four inches over all. Go to the 60-66 board and look at the 63 panel I posted and you will see some pics of the bracket for the bags. I would post some right now, but I am on my wife's laptop and all my pics are on mine.
Old 06-10-2006, 01:51 AM   #24
smbrouss70
smbrouss70's Avatar
Would you be able to run "normal" bags with another type of bracket?
*** EDIT*** Nevermind I went and looked at the pics on the panel and aswered my own question.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 06-10-2006, 07:09 AM   #25
onehot69stepside
onehot69stepside's Avatar
is that a typical ford rack and pinion (24" inner balljoint centers) or is it a modified one for extended travel, or does the drop-member require the use of impala spindles? what im getting at is how the turning radius is with that rack. I'm building a full chassis front to back on a table and I think I've got it figured out how to build my ifs from scratch using a rack with the same amount of bumpsteer as stock but I have to figure a way to get my turning radius tighter.
:mp:
onehot69stepside is offline   Reply With Quote
