Old 07-15-2006, 07:54 PM   #1
XXL
Seņor Member
XXL's Avatar
Idea on cleaning up the back end...
I've tended to hold back a little, so as not to go "too far over the edge" (yes, my truck is a conservative take), but I've been inspired by Frizzle Fry's hybrid project body lines to push that edge just a little bit. The bed half of the Wallet Eater is in progress, and I recently finished doing a double wall on it. I also picked up some mandrel bends to do the trick Frizzle Fry did. But I've been wanting to clean up the lines on the tailgate area. Here's a q&d pshop of an idea... the gate is skinned with a bed side or a couple of door skins to get the body line crease and rolls of the side of these trucks. It flows smoothly into the rolled pan, which curls under and terminates.
Waddaya think?
XXL is offline   Reply With Quote
Old 07-15-2006, 08:01 PM   #2
Bob Moore
Re: Idea on cleaning up the back end...
Sounds AWESOME! What is the corner cutout on the rolled pan for? Can the pan extend tp the edge of the gate?
Not that familiar with Steps - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 07-15-2006, 09:51 PM   #3
krue
Designated A-hole!
krue's Avatar
Fits with the theme of your truck, but makes the bedrails seem out of place (look like mickey's ears ).
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 07-15-2006, 11:20 PM   #4
XXL
Seņor Member
XXL's Avatar
Who's the leader of the club that's made for you and me?
Wait... check the "Frizzle Fry" link in my OP. I'm laying out lines for cuts now.
Old 07-15-2006, 11:50 PM   #5
meathead95
computer illiterate
meathead95's Avatar
looks good
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 07-15-2006, 11:55 PM   #6
72CSTC5
72CSTC5's Avatar
How about using some thin wall tubing and cut it from end to end to get the curve and the taper you are looking for from end to end of the tailgate and then you could weld flat sheetmetal the the pipe and the rollpan to get the desired effect. I think it would be difficult with door skins because I would say you would need at least two. Just a thought.
72CSTC5 is offline   Reply With Quote
Old 07-16-2006, 09:47 AM   #7
wibilly
wibilly's Avatar
the door skins lines also don't match up from front to rear great idea, looks sharp i think a bed side or roll your own skin is the way to go, and yes you have to cap the bed rails
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 07-23-2006, 07:18 PM   #8
XXL
Seņor Member
XXL's Avatar
Let the carnage begin!
Old 07-23-2006, 08:04 PM   #9
Hart_Rod
Hart_Rod's Avatar
Looks good. Where did you get the bends made at?
Rob
Hart_Rod is offline   Reply With Quote
Old 07-23-2006, 08:38 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Since your looking for opinions let me throw my spare change in. Extending the bed rails with the mandrel bends is a great idea. I also like the idea of adding the body line across the tailgate.
There are two more things I think it needs. I would look at extending the bed sides at the tailgate. This would create a smoother transition between the bed sides and the roll pan. The mandrel bends might work there too.
I would do something with the filler panel for the tailgate too. Even though you added the lower body lines, it's still very flat back there. It needs a recessed area to break things up.
Yes, I know you went through a lot of trouble to remove the factory recessed are there, but it's going to be too flat now.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-23-2006, 11:16 PM   #11
XXL
Seņor Member
XXL's Avatar
Bends came from here (1.75", Ø 2.25")
Old 07-23-2006, 11:19 PM   #12
XXL
Seņor Member
XXL's Avatar
My quick and dirty pshop didn't really demonstrate the curves I'm shooting for. Picture these lines across the bed. That should be pretty non-flat... I think... I hope. As for the transitions to the fenders, I should have saved the corners off the old cab I chopped up
Old 07-24-2006, 08:50 AM   #13
70c10
67-72 Addict!
70c10's Avatar
Those radiiused tubes make all the difference in the world. Looks really good not looking thru the open end of the rail.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-24-2006, 09:13 AM   #14
basketcase
basketcase's Avatar
Some great ideas there. That's the best looking way to cap off the bed rails I have seen. I'm thinking about frenching some thin horizonal tailights into the lower rear of the fender. I think it will visually lower and widen the rear of the truck.
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 08-04-2006, 10:51 PM   #15
XXL
Seņor Member
XXL's Avatar
Small progress this evening... first chance to work on the truck in a couple of weeks
Old 08-04-2006, 11:24 PM   #16
E's c10swbfleet
E's c10swbfleet's Avatar
looks great
E's c10swbfleet is offline   Reply With Quote
Old 08-05-2006, 12:34 AM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
Ok, that make more sense. In the photoshop pic it looks flat. Now I understand you are palnning on use the same curve that the door has.
Yep, those old cab corners would have been ideal for finishing off the lower part of the bed...
Articles-
"Refining Sierra"
Old 08-07-2006, 01:41 PM   #18
XXL
Seņor Member
XXL's Avatar
Now to find a couple of door skins. Any suggestions???
Old 08-07-2006, 06:30 PM   #19
Hart_Rod
Hart_Rod's Avatar
GoodMark sells them. It might cost more, but will save you time cutting a door down.
Old 08-08-2006, 12:55 AM   #20
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
If you were closer I would give you some door skins..
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 08-09-2006, 05:02 PM   #21
XXL
Seņor Member
XXL's Avatar
q&d of a door skin in place. I _think_ the scale is about right... I don't have measurements handy.
Old 08-09-2006, 05:16 PM   #22
XXL
Seņor Member
XXL's Avatar
complete...
Old 08-09-2006, 07:21 PM   #23
SCOTI
SCOTI's Avatar
Very cool idea. Get to work.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-09-2006, 08:09 PM   #24
XXL
Seņor Member
XXL's Avatar
Didn't you see? I'm done! Now if I can just figure out a way to do pshops directly on the truck
Old 08-10-2006, 01:38 AM   #25
RicksTrucks
RicksTrucks's Avatar
JUSTASCATCH usually has a lot of doors, check with him. I may be able to bring them to you next trip north.
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
