Old 09-13-2006, 01:32 AM   #1
myblue72
Need help with 8-lug custom wheels
Can anyone give me advice with what they did for after market wheels for thier 8-lug wheels. I have a 1972 3/4 ton 2-wheel drive and would like to get 16" - 18" polished alloy wheels, but I'm having trouble locating any type of selection. Any help or links would be welcome.
myblue72 is offline   Reply With Quote
Old 09-13-2006, 03:52 AM   #2
Mudder
Mudder's Avatar
Re: Need help with 8-lug custom wheels
Try Weld wheels.
Mudder is offline   Reply With Quote
Old 09-13-2006, 06:29 AM   #3
rage'nrat638
rage'nrat638's Avatar
mine are eagle
rage'nrat638 is offline   Reply With Quote
Old 09-13-2006, 07:17 AM   #4
Just get a magazine and check the tire & wheel ads.Maybe check a 4wd mag like 4Wheel & Offroad.There`s 4WheelPartsWholesalers,NTW,and TiresInternational.Most everything in those ads is available in 8-lug.
Old 09-13-2006, 07:46 AM   #5
72freak
Rottenwood Garage Member
72freak's Avatar
It has been my experience that there are very few choices that are resonably priced. I researched for about a year and in my opinion there were only 3 choices that would work in my price range.
I was real pleased with stock steel wheels, dog dish center caps and a thin chrome trim ring.
Hummer wheels with chevy center caps....you can paint or powder coat them any color you want.
The older ford style wheel with the holes on them.
Remember.....you can use just about any 8 lug wheel form any vehicle from any age except post 1999 Ford.
72freak is offline   Reply With Quote
Old 09-13-2006, 12:55 PM   #6
Deuce
Deuce's Avatar
PM classicchev. He is putting a set of Boyds he bought off e-gay on his 3/4 ton "work truck"
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 09-13-2006, 03:35 PM   #7
dave666693
dave666693's Avatar
I used the wheels and tires off a HD2500 Chevy. Tons of them around when these guys remove them and put on the serious Bling.
dave666693 is offline   Reply With Quote
Old 09-13-2006, 03:57 PM   #8
72freak
72freak's Avatar
Did you have to use spacers? I have seen a few sets on our rides and the backspacing was way off.....they needed about 1" or more to push them out to there they looked good?!??!!
Old 09-13-2006, 05:27 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I was about to mention that, late model wheels will have back spacing issues and look like a fat man on a bicycle from behind.
If you actually haul things in your 3/4 ton / one ton 8 lug truck, DON'T use ford/dodge wheels. The trucks use HUB excentric wheels... the center hole supports most of the weight, the lugs/lug nuts only hold the wheel on. Ford and dodge wheels have much arger hubs, and when installed, the lugs are supporting the load.
If your truck doesn't haul much weight, then this is a moot point, (a savy pennsylvania inspevtion station may say something though... they are paid to be pricks) but be warned if you to haul. While it is far and few between, we have actually had a few trucks come through our shop where the lugs all broke off flush with the drum, and the wheel was always the wrong style.
Old 09-13-2006, 10:32 PM   #10
dwaite72lnghrn
Does anyone know when GM went from 8 on 6.5" by4 3/4" hub to the 5.15 hub and metric?
I am ready to finally go to radial tires and am looking for 16" white steelies.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 09-13-2006, 11:07 PM   #11
72rustbucket
72rustbucket's Avatar
I have been doing the same for my c-20. You can find wheels like american racing, weld, many others. Just make sure you don't get wide wheels like 10 or 10.5because they can stick out on the fender. You have to look for 9 or 5.5. I found some 20s but they are like couple hundred dollars more than the 5 or 6 lug 20s. g/l
72rustbucket is offline   Reply With Quote
Old 09-14-2006, 12:21 AM   #12
ClemsonChevy
8 vehicles only 4 that run
ClemsonChevy's Avatar
I've been looking at these:
http://store.summitracing.com/partde...5&autoview=sku
95 2500 350 w/ 3.73
72 GMC 1500 SWB stepside
65 Chevy C10 SWB stepside
72 Chevy C10 LWB fleetside
ClemsonChevy is offline   Reply With Quote
Old 09-14-2006, 03:57 AM   #13
OhioDan
OhioDan's Avatar
Here's what I'm using.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 09-14-2006, 12:16 PM   #14
dave666693
dave666693's Avatar
I didn't have any spacing issues on my '67 with the HD2500 wheels and tires. I was even able to use the stock center caps. I did have to get lug bolts off E-Bay because the center cap nuts are metric.
Old 09-14-2006, 01:24 PM   #15
PETEM1957
Junior Member
dave666693 I HAVE THE SAME RIMS ON MINE BUT I NEED TO KNOW WHAT YOUR LUGS CAME OFF OF TO GET SOME SO I CAN RUN THE CENTER CAPS.
PETEM1957 is offline   Reply With Quote
Old 09-14-2006, 01:52 PM   #16
panhandler62
Java Mechanic
panhandler62's Avatar
Just poking around at Summit I found these...
Might need mudflaps with this size in some states...
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-14-2006, 10:39 PM   #17
myblue72
Great stuff, guys. Thanks so far for all the help. Also, knowing what not to do is a big help. I've looked at the Weld Racing's New Hotrod & Custom series, but have to find out if the come in 8-lug. They look to be a little spendy. If anyone is interested, check them out at:
http://www.weldwheels.com/hotrod/
Keep the good advise coming.
Old 09-14-2006, 10:44 PM   #18
myblue72
So what type of wheel do I want if I hall? One that the weight is displaced on the hub or on the lugs?
Old 09-14-2006, 10:49 PM   #19
Longhorn Man
on the hub.
Old 09-15-2006, 07:48 AM   #20
Finally,Weld`s getting back to making some nice looking road wheels.The Outbacks were the nicest SuperSingles they made and they stopped.The Sidewinder is nice,I figured they were next.It seems most 8-lug alloy wheels these days have some kind of poser beadlock mimmick or dimple to make them tough to clean and hurt the looks,IMHO.
I`m not too sure any of those will be 8-luggers,though.
Old 09-15-2006, 10:05 AM   #21
dave666693
dave666693's Avatar
Pete-I got mine on E-Bay. There are several on their for converting. Here is 1 example: E-Bay item#290028600679. May not be the size you need though. The center cap threads are metric while our wheel studs are American.
Old 09-15-2006, 12:07 PM   #22
mark69
I'm back did you miss me?
mark69's Avatar
My C20 came from the previouse owner with American Racing OutlawII's and after reading Longhorn Mans post I checked and found that they are not flush with the hubs!!! the hole is at least a half inch bigger. I plan on hauling my toys so I just picked up a set of OE steelies from RV supply.
1984 C10 Shorty 250 Inliner
1969 Custom Camper/20 GONE(but not forgotten).
1976 C20 with 292L6 36K original miles now 41K. SOLD
87 Chevy P30 stepvan 6.2L diesel 140K (SOLD)
mark69 is offline   Reply With Quote
Old 09-15-2006, 04:48 PM   #23
Longhorn Man
Had a DHL truck come in today like this. They have a fleet of mostly ford vans, and a few chevy P/30 grummens, and a few new smaller P/30 SRW Work hoses.
I've been telling them not to put the ford wheels on the work horse trucks but they kept blowing me off.
Broke every stud on the left rear, driver was doing 50 MPH when it broke off. He's lucky he didn't roll over or hit anyone else.
Old 09-16-2006, 10:53 PM   #24
pooz911
pooz911's Avatar
I looked for a long time before I decided to go back to the old aluminum slotted wheels on my truck.
www.cardomain.com/id/pooz911
pooz911 is offline   Reply With Quote
Old 09-17-2006, 08:03 AM   #25
Check 4WheelPartsWholesalers.There have 4 or 5 mfgrs listed with several styles in each.I like vintage on mine,too.
