Old 10-28-2006, 08:40 AM   #1
msgross
msgross's Avatar
Closed Knuckle Axle with disc's (is it possible?)
I have a 68 K-10 with the original closed knuckle front axle. Nobody sell a conversion kit for front discs and I thought that it was impossible. I have heard though that you can pull the parts off of a mid 70's 4x4 and place them on the closed knuckle..... Can Anybody confirm or deny this? I am getting ready to redo my drum brakes and this would change everything! Thanks...
msgross is offline   Reply With Quote
Old 10-28-2006, 10:27 AM   #2
qksilver
Re: Closed Knuckle Axle with disc's (is it possible?)
yes it is, go junking and bring a measuring tape........
qksilver is offline   Reply With Quote
Old 10-28-2006, 12:05 PM   #3
wolfthing2000
I am in the same boat and would like to know more specifics on this mod.
wolfthing2000 is offline   Reply With Quote
Old 10-28-2006, 12:39 PM   #4
69TowRig
Here's what I know from converting my open-knuckle '69 to disc brakes. With proper use of a grinder for clearancing you can use drum knuckles, if I recall correctly you have to grind a notch in the knuckle to clear the caliper properly. Reason for this is the disc-brake studs are clocked differently and thus the backing plates put the caliper in contact with a part of the knuckle. You will need the spindles, rotor/hub, backing plates, and all caliper hardware.
Best bet is to get 73+ brakes for ease of finding cheap parts, if you want to keep standard fittings get 73-77 parts, 78-79 calipers are a crap-shoot between 3/8 and 10mm, 1980+ are all 10mm.
When I did my swap I pulled the knuckles off an '82, I know that isn't an option for you. I did keep the original outer axle shaft, and drum shafts are about 1/4" short due to a slight difference of the bearing location within the hub assembly. You cannot swap the outer shafts from the 73+ trucks because the u-joint is a larger size; you *could* use 71-72 outer axle shafts to fix this but finding them will be tough. The net effect is that the snap-ring that retains the manual locking hub innards will not seat. Solution is to use a 7/16" fender washer and a 7/16"-20 x 1" long bolt to screw into the end of the axle shaft (it is threaded).
Hope that gets you started.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 10-28-2006, 12:52 PM   #5
ND_guy
Tool Addiction=Money Shortage
ND_guy's Avatar
This past summer I tried this swap on my k20. It didnt work with the parts I used. I pulled everything off a 79 k20 10bolt (spindles, hubs, backing plate, rotors, calipers) They all fit the axle great until I tried to fit the caliper on the backing plate. The caliper hits the ball for the closed knuckle. The closed knuckle really interferes with the caliper so grinding for clearance isnt an option. For now I am just looking for a open knuckle D44 in ND to swap.
I have switched to boosted drums until I get discs and that has made a huge difference over unboosted.
ND_guy is offline   Reply With Quote
Old 10-28-2006, 01:21 PM   #6
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
ND_guy,
What type of booster did you use and what all is needed to complete this task. I have a '68 K-20 that I definately need to do this to. Thank's for your input.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 10-28-2006, 01:38 PM   #7
ND_guy
ND_guy's Avatar
I used Hydroboost out of 80 1ton van. It wasnt a bolt in system I made custom lines, pushrod and mounting brackets for the booster and used the van power steering pump.
Old 10-28-2006, 01:43 PM   #8
Bishops Trucks
KEEP ON TRUCKIN'
Thanks, I'll keep that in mind.
JIM
Old 10-28-2006, 02:12 PM   #9
msgross
msgross's Avatar
I may just go for the booster setup from a disc truck and redo my drums until I tear the truck apart someday and look at an axle swap.
Old 10-28-2006, 02:13 PM   #10
69TowRig
Good info about hitting the ball, I never thought that it would be that close.
A point to note, between all the parts I had to buy to make my junk work (balljoints, fancy brake lines, new calipers, etc) I spent more than if I had simply bought a 73+ axle complete and swapped it under my truck. My issue at the time was that I could not find one with the right gear ratio, so instead I decided to tear mine apart. Later I did find one for less than $300, and it would have basically been a bolt-in.
Food for thought.
-Chris
Old 10-28-2006, 02:15 PM   #11
msgross
msgross's Avatar
What axle ratio would my 68 K-10 have?
Old 10-28-2006, 02:20 PM   #12
wolfthing2000
For what it is worth, I have a vaccuum boost on my 69, unknown source that PO installed. He said that made all the difference in stopping or not. It works good, the only problem with the drums is that they are real hard to find or expensive.
Old 10-28-2006, 09:58 PM   #13
WyoRoadDog
Page intentionally left blank.
WyoRoadDog's Avatar
If you're lucky it will still have the tag on it. There should be a small metal tag attached at one of the bolts on the differential, which will give you the ratio. Otherwise, it involves counting teeth on gears, and some math. Something someone more experienced than me needs to explain, I got lucky and had the tag on mine (3.54).
I would be interested in knowing if there is an easier way, it would help when I go junkyarding for this project.
There is a theory which states that if ever anyone discovers exactly what the Universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.There is another theory which states that this has already happened. - Douglas Adams
'67 GMC 4x4, 305 V6! Or all the parts for anyway...
'17 Subaru Outback.
'18 Toyota Tacoma TRD Off Road.
'99 Ducati 900SS.
WyoRoadDog is offline   Reply With Quote
Old 10-29-2006, 10:14 AM   #14
qksilver
the 1/2's are different, if any body wants to come down, move a few parts and 2 trucks, pull a wheel you can take all the pictures of the conversion you want.
The major hard part is getting the spindle off of the steering knuckle. Need the proper tool and a slide hammer, penetrating oil and sometime a little heat.
Old 10-30-2006, 06:37 AM   #15
69TowRig
I just use a dead-blow, or a real hammer and a block of wood? I've removed 4 of them that way, all rusted pretty decently. The slide-hammer trick would be pretty cool, I'd think you'd need some strong arms to get it out that way.
-Chris
Old 11-10-2006, 07:30 PM   #16
drink2mny
drink2mny's Avatar
Yes it is possible..
http://www.blackbirdscustomtrucks.com/index25.html
Support The Board
drink2mny is offline   Reply With Quote
Old 11-10-2006, 08:13 PM   #17
msgross
msgross's Avatar
that says 3/4 ton, will it work with 1/2 ton 6 lug closed knuckle? Do you have a total kit then?
Old 11-10-2006, 09:38 PM   #18
drink2mny
drink2mny's Avatar
I must be blind.. for some reason I didn't notice you needed half ton..
We are waiting to get a front diff to build one off of it. So as for now.. No.
Support The Board
Old 11-11-2006, 12:08 AM   #19
wolfthing2000
OK I am interested. I am a machinist with lotsa experienceeo and I have not a lotta denerio ( dollas!)!! Blackbird, if you could, peice meal me a kit in some form as I gather parts from this or that and do this or that to make it happen????? Like , what I meana is would ya work witha mea????
Old 11-11-2006, 01:33 AM   #20
drink2mny
drink2mny's Avatar
Thats like asking a restaurant for thier secret sauce by asking for one ingrediant at a time....
We are the only company right now to make this as an option for the closed knuckle. I am very sorry, but I am not going to tell you what you need to make this kit..
Support The Board
Old 11-11-2006, 09:16 AM   #21
wolfthing2000
I am truly sorry that I misunderstood this thread. I thought this was a posting of information to do this mod and for those helping others to give that info.
I did not expect this to be solely an ad for a kit for sale only!
expect this post to be banned.
Old 11-11-2006, 09:37 AM   #22
msgross
msgross's Avatar
The post I started was searching for information to do the mod, drink2meny is a vendor on the site and has a similar kit that he was informing us about. I didn't know that anyone was making these so that's great. (I plan to buy when he get a 1/2 ton model). Asking a vendor for his plans isn't what this was about, asking another member their technique for a mod is normal....
Old 11-11-2006, 12:17 PM   #23
drink2mny
drink2mny's Avatar
I wll check with my fellow mods and see if I crossed the line.
All I did was answer what the main question of what title ask.
I didn't take time to read through the whole post, so hang a brother..
msgross, sorry.. didn't mean to take away from your original post.
Support The Board
Old 11-11-2006, 03:13 PM   #24
msgross
msgross's Avatar
no problem here, I think that he's upset or something...
Best solution for the brakes is to swap with a newer style axle (150-200 @ junk yard?), that is until you invent a kit for 1/2 tons.
Old 11-11-2006, 03:21 PM   #25
wolfthing2000
No one upset here. Just expect that if we are discussing mods............then that,s what we do.. I was just asking to get info....... not looking to be insulted in front of the rest here.
I don't recall anyone saying there was a "secret ingredient" here at the get go, so I figured it was fair to ask and not made to look stupid after I ask!!!!
