Old 11-11-2006, 05:37 PM   #1
rage'nrat638
rage'nrat638's Avatar
Sbc Overhauling 123 Top To Bottom W Pictures And Commentary
69 CHEVY 355 SMALL BLOCK
LETS START WITH THE HEADS
stock 882 cast heads press in studs ....start to finish
stud towers milled off and tapped for 3/8 studs and push rod guides
Z valve springs, comp cams retainers, and positive valve seals.
comp cam full roller rockers ,1.5 ratio and 3/8" studs.
gm performance valves
used lock tight on stud bolts ---- 3 angle valve job. $325.00
rage'nrat638 is offline   Reply With Quote
Old 11-11-2006, 05:40 PM   #2
rage'nrat638
Re: Sbc Overhauling 123 Top To Bottom W Pictures And Commentary
installing new studs and guide plates and 1 coat of paint
comp cam poly locks.. rebagged ready to install on block...
Old 11-11-2006, 05:42 PM   #3
rage'nrat638
finishing up
Old 11-12-2006, 05:21 PM   #4
rage'nrat638
well lets start to day by removing the oil pan..
notice the 4 bolt mains
clean the block head mating surfaces and retap out all mounting holes
apply thread sealant to all head bolt holes and bolts preinstall
oil pump tube welded into place
Old 11-12-2006, 05:24 PM   #5
rage'nrat638
after cleaning surfaces...clean out all mounting threaded holes with the tap set..a must for head bolts...
Old 11-12-2006, 05:28 PM   #6
rage'nrat638
some new parts..
arp head bolts
arp fuel pump rod
lifters
cam
double roller t-chain
felpro gasket set
Old 11-12-2006, 05:36 PM   #7
rage'nrat638
install heads after surfaces are all cleaned up
thread sealer applyed to head bolt holes and all new arp head bolt threads
tighten to specs
Old 11-12-2006, 05:41 PM   #8
rage'nrat638
lets jam on the cam and lifters.
timing chain cover and balancer
HERES A LINK FOR A THREAD I HAVE SINCE MADE FOR GETTING THE TIMING RIGHT
http://67-72chevytrucks.com/vboard/s...d.php?t=225820
lots of lube on all the cam lobes and lifter bottoms
i would have taken a picture of the cam lubed but i was afraid i might drop and break it inhalf
this is the hotest cam i can run with a stock converter and also power brakes
Old 11-12-2006, 05:47 PM   #9
rage'nrat638
install lifters and timing cover
new super duper oil pan will be here tommarrow
install hardened push rods and full roller rockers
set intake and some tall valve covers on for storage
Old 11-12-2006, 06:28 PM   #10
rage'nrat638
as soon as i get my new oil pan...MONDAY NIGHT....
we will be installing it with a new one piece oil pan gasket....
then we move to the intake installation...
then we install the hei dizzy w/pictures and stock hei wire rotation..
then i will show how to prime the engine on the engine stand to check for leaks...
INSTALLING ALL THE HARDWARE ON THE ENGINE W.P. P.S. PULLEYS A/C
then it will be adjusting the new roller rockers and engine installation in the truck..
then a start up video with my new camera
2000 RPM FOR 20 MIN...OPEN HEADERS...
DON'T GO AWAY !!!!!!!
O YEA AND SOME Q-JET TRICKS....
Old 11-12-2006, 06:43 PM   #11
action
Active Member
action's Avatar
Whats up with all the over spray? Aren't you afraid of all that paint running thru your motor. some old valve covers would sure keep a lot of the paint where it belongs.
Jack
action is offline   Reply With Quote
Old 11-12-2006, 09:33 PM   #12
rage'nrat638
this is the ENGINE/DRIVETRAIN fourm right?
Old 11-13-2006, 03:42 AM   #13
stllookn
Saving 1 truck at a time!
stllookn's Avatar
rage'nrat638, Would you tap the studs with a very mild hydraulic cam with only .420/.442 lift? I am doing a temporary and mild rebuild of a sb400 and won't be revving above about 3500 rpm. I love the paint...nothing nicer than shiny new Chevy orange! Did you Locktite the cam bolts?
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 11-13-2006, 07:46 AM   #14
rage'nrat638
i had trouble with the nuts on the rockers coming loose with the 4:11 rear end .. reving 3100 rpm at 60mph,
ploy locks might have fixed it....
yes i used lock tight on the cam bolts...
thanks for your input...
Old 11-13-2006, 11:12 AM   #15
Billla
Billla's Avatar
Great quick 'n dirty overhaul thread. A couple of quick questions:
  • It looks like you're not touching the rotating assy, correct? (i.e., topend only)
  • Looks like you cleaned up the heads yourself vs. hotank/blast?
  • What did you do with the overspray on the head intake gasket surfaces?
A couple of comments for your and the watchers feedback and perspective:
  • I worry a bit using abrasives on something that's not coming all the way down. How did you keep grit out of the bore while you were cleaning up the block deck?
  • I'm not a big fan of using taps to clean out threads. Thread chasers are a lot safer choice for the occasional rebuildiner - a chaser is hard to start wrong, and if you do, it won't turn. Get a tap in crooked and you have a problem as it will happily cut new threads Decent chaser sets are pretty cheap.
Billla is offline   Reply With Quote
Old 11-13-2006, 07:36 PM   #16
rage'nrat638
the bottom end was just rebuilt 5000 miles ago..
the heads i had redone at the mechine shop...
the intake gasket surfaces will be cleaned with thinner...as was everything
i had rag's stuffed in each cyl hole while cleaning...
power flushed each cyl...
compressed air dryed....
no threads or animals were hurt or killed during this rebuild
MY OIL PAN GOT SHIPPED TO WISC. SHOULD BE HERE TOMMARROW NIGHT NOW...just as well it's raining outside and i can't (won't) sit my prostreet truck out in the rain
Old 11-14-2006, 09:30 PM   #17
rage'nrat638
ok lets get on with the new oil pan install...
this pan has trap doors inside and a crank scraper...
the best thing is it has flange reinforcement
Old 11-14-2006, 09:34 PM   #18
rage'nrat638
next is 35.00 worth of stainless steel bolts..enough for the complete engine from ace hardware ...SWEET
MY NEW TALL VALVE COVERS...
and two stickers to hold it together...
Old 11-14-2006, 11:15 PM   #19
Crank
Crank's Avatar
Okay I have one quick question. Is this motor originally a '69 out of your truck. I dont know the difference motor wise between a 2 piece and a 1 piece rear seal block. I'm assuming from yours it is a stock '69 block with a one piece oil pan gasket. Like everyone else that owns a Chevy. I'm having problems getting my '73 motor in my '86 to seal up right at the pan. Will this gasket you've used work on my 2 piece rear seal 350 out of a '73? And it looks like in the picture it has some sort of blue permatex or something or is that just the gasket? You've got me wanting to pull my dang motor and paint and clean up the turd. Thanks for this detailed buildup.
Brandon
Crank is offline   Reply With Quote
Old 11-15-2006, 12:14 AM   #20
rage'nrat638
Brandon
YES YOU CAN GET THIS ONE PIECE GASKET SET FROM MURRYS FOR 29.00 FOR A ONE PIECE OR TWO PIECE REAR MAIN...THEY ARE THE CATS MEOW
yes its blue sealer just in the four corners...the rest goes on dry..
THE KIT COMES WITH ALL NEW BOLTS AND WASHERS....
Old 11-15-2006, 02:41 PM   #21
mySAVIOReigns
Active Member
mySAVIOReigns's Avatar
Man, that looks great! I love the black on orange
Website Here
-Stephen
1985 Chevy Silverado, 1/2 ton
mySAVIOReigns is offline   Reply With Quote
Old 11-15-2006, 03:58 PM   #22
swb85
On a budget like Fred Sanford
swb85's Avatar
Cool thread! Engine looks awesome. If you don't mind me asking, where did you get the "super duper" oil pan & what did it cost?
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 11-15-2006, 07:35 PM   #23
weasel29gm
SLOW BUT SURE,BUT CLOSER
Cool thread and love those home built small blocks.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 11-15-2006, 09:09 PM   #24
rage'nrat638
ONE SUPER DUPER OIL PAN...49.00 PLUS 15.00 FOR SHIPPING
EBAY ITEM #Item number: 8073851381
http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
Old 11-15-2006, 09:23 PM   #25
rage'nrat638
INTAKE INSTALL TIME !!!!!!!
i started by cleaning the mating surface's
put thread sealer in the open ended hole's on the heads...for sure the 4 by the carb base that always seem to leak....
i am using the sweet baby blue silicone that match's the baby blue felpeo gaskets
throw the rubber end seals away..for the intake valley...
put thread sealer on the intake bolt ends and tighten as GM recommends
