Old 11-19-2006, 10:28 PM   #1
Chris27
Blazerless
Chris27's Avatar
Some pics of my Blazer
Finally some pictures of my 72 K5 Blazer. I have not worked on the body, it is on my To Do List.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD
69' Beaumont 388/700R4 11.70@116
77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad.
Chris27 is offline   Reply With Quote
Old 11-19-2006, 10:30 PM   #2
Southedisto
River life......
Southedisto's Avatar
Re: Some pics of my Blazer
Looks good, keep us posted on updates.
Southedisto is offline   Reply With Quote
Old 11-20-2006, 12:23 AM   #3
Chris27
Blazerless
Chris27's Avatar
I just finished the drivetrain swap (TBI350,700R4, 3/4ton diffs, 31gal. gas tank) There won't be updates for a while.The Blazer is the daily driver right now, can't do bodywork until spring when I can drive my car again. Have to get to work somehow. Still debating on the color. The light blue on the dash is original, but I kinda like the dark blue too. I'm thinking maybe the light blue only mettalic. Also not sure about the wheels, I got them cheap from a buddy, not my first choice if I was buying new, but I needed 8-lug wheels to fit the new diffs. Can't decide if I should go ahead and cut the front center caps for the hubs or wait for new wheels and sell these. Bigger tires are definately on the most wanted list. 235/85/R16's belong on a dually, not a 4x4!
Old 11-20-2006, 02:33 AM   #4
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Looks Good! Keep up the great work! I'd hold off on cutting the caps and sell the wheels in the spring or sumthing...
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 11-20-2006, 06:34 AM   #5
Pop's72
It's ok to stare...
Pop's72's Avatar
Nice looking ride... Since you asked and since it is not my money I would go with different rims and I agree with you bigger tires. Just keep the current set as your winter rims and tires.
Pop's72 is offline   Reply With Quote
Old 11-20-2006, 07:20 AM   #6
jaros44sr
jaros44sr's Avatar
Nice project, I really like the engine swap. How was it to put in the 31 gallon tank? J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 11-20-2006, 09:22 AM   #7
krue
Designated A-hole!
krue's Avatar
Curious about the tank swap myself.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 11-20-2006, 10:30 AM   #8
Chris27
Blazerless
Chris27's Avatar
The Tank swap was pretty straight forward. Got a new tank for a 87-91 Blazer, Sending unit and pump from a '87 'Burban (junkyard). Had to remove the rear crossmember. Made some new crossmembers front and back (straps go front to back, not side to side like the stock tank) Made some spacers out of 1-1/2" C-chanel to go between the tank flange and the frame. If you have a body lift you won't need this. The stock straps for the truck actually fit the new tank! (the new tank is as long as the stock one is wide) The filler is on the wrong side, so I removed it (it's soldered in) ,cut a new hole and soldered it in the new hole, then patched the old hole with some sheetmetal and soldered it all up. I had a receiver hitch behind the liscence plate, but I had to remove it because it hit the new tank. I will need to to some fabbing to get it to fit again.
Old 11-20-2006, 11:30 AM   #9
1Ton
1Ton's Avatar
Nice blazer.
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline   Reply With Quote
Old 11-21-2006, 01:15 AM   #10
Kool K5
Kool K5's Avatar
Keep the dark blue, it looks real sharp!
Evan
70 Blazer 4x4 305/sm465/np205
80 Buick LeSabre Limited
72 Honda CB350F
77 Honda Cb750K
00 Ducati Monster M900ie
Kool K5 is offline   Reply With Quote
Old 11-21-2006, 01:25 AM   #11
Chris27
Blazerless
Chris27's Avatar
Thanks for the input, whatever color I choose I will do the whole thing (including dash) unlike the PO. and it will have a '67 front clip. Anyone notice the side trim? That's not factory '72, it's actually the same trim found on 88-98 silverado's. The stock trim came in a box with the truck and had been mangled by the PO . It's a little narrower, but it'll do until i can afford real trim.
Old 11-21-2006, 07:09 AM   #12
jaros44sr
jaros44sr's Avatar
Chris, thanks for the info on the tank. Maybe I'll leave it on that side and make a dual fill tank. J.
SAFETY FIRST
AS usual, off topic
Jim
Old 11-21-2006, 10:12 AM   #13
Chris27
Blazerless
Chris27's Avatar
If you're not concerned too much about departure angles and ground clearance you can also install the tank backwards. I almost did it that way but it just didn't look right. Plus the filler neck was reallly close to the body mount.
Old 11-21-2006, 12:24 PM   #14
Yukon Jack
Yukon Jack's Avatar
Good looking K5. When you did the front axle, what year was it and how did you address the rubber brake lines. I'm doing axles in my 70 K5 from a 78 3/4ton (Dana 44 front).
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-21-2006, 02:59 PM   #15
Chris27
Blazerless
Chris27's Avatar
I used the front diff from a '77. It was a direct bolt in. The stock '72 brake lines on the truck bolted right up to the '77 calipers. The only thing I had to fab was a mount for the swaybar. Or if you don't want a swaybar, the stock '72 spring plates should fit. Gotta love GM interchangeability
Old 11-21-2006, 11:01 PM   #16
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks like a nice ride.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-21-2006, 11:46 PM   #17
84 400
Sb 400 club
84 400's Avatar
sweet ride! if you do the blue dark or metalic are you keeping the tan or white strip on the bottem? i am guessing not if you go with the stock color. anyways looks really sweet!!! some fatter more agressive tires would be nice and fun in the snow. and i would sell those and not keep them as winter ones since what is the fun of having agressive tires not in the snow? Also don't cut them if your planning on resale. looking great!!!
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 11-22-2006, 12:12 AM   #18
Chris27
Blazerless
Chris27's Avatar
Here's a pic of the '70 Jimmy I just sold. It's on a shortened '97 3/4 ton chassis complete with Vortec 350/4L80E/241/ 14bsf and whatever front diff the IFS chevy's have. I drove it for 2 years, put 30,000 miles on it and got $4000 more than what I paid for it. I didn't build it so it didn't really feel like it was mine.
Old 11-23-2006, 02:43 AM   #19
Canadian694x4
Born To Lose Club
Man that's a sweet Jimmy! I'd have a hard time lettin' that go!
Old 11-23-2006, 09:29 AM   #20
Chris27
Blazerless
Chris27's Avatar
It was a really nice truck, but it had some "issues" I didn't want to deal with. Plus it was heavy (5600 lbs.) Sure rode alot nicer than my leaf sprung '72. When I bought that one, I was looking for a Blazer/Jimmy to fix up, then I saw that one and had to have it.
Old 11-24-2006, 07:38 AM   #21
krue
Designated A-hole!
krue's Avatar
www.daveramsey.com
Old 11-25-2006, 05:15 PM   #22
72LoBurb
Yup, I'm comp-useless
I've seen your Blazer a couple of times and looks like a great starting point, but I think it may have been the previous owner. I don't think it had the bigger diffs and those wheels on it.
Come spring, if you come by any of the cruises look for my '72 'burb(medium olive) and introduce yourself.
Dave
72LoBurb is offline   Reply With Quote
Old 11-26-2006, 12:09 AM   #23
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Nice
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-27-2006, 12:58 AM   #24
Chris27
Blazerless
Chris27's Avatar
72LoBurb, I think I've seen you around a few cruise night too, usually in the summer I'm cruzin' the Beaumont though. I just completed the diff swap about a month ago (I've owned the truck for over a year now) So you may have seen me driving around. It used to have Rallye wheels with bald 33's and smoked alot. Fortunately with the new EFI motor I've gotten it to quit smoking
Old 12-02-2006, 01:39 PM   #25
72LoBurb
Beaumont? What does it look like? I've probably seen it and may have even talked to you. I'm a chrome dome in the summer.
I'll be doing a motor swap in the spring, the 'burb's engine started making some strange(bad) noises just before I parked it. Depending on overtime, maybe a crate motor and possibly TBI, that I have out of my old '90 'burb.
Have you been to WhiteOaks on 137ave/122st(A&W), I sometimes sit with a '72 Blazer 2wd(light brown). He's the guy you wanna know if your redoing your Blazer; he owns Super Service Truck Parts.
