11-20-2006, 01:30 AM | #1 |
68swb build up AKA (Baglady)
I have finally decided to start a thread for my project. Its a 1968 swb original v8 three speed truck. I wanted to do a fast build and just get it running and drive it. But after getting in to it that went out the door. Know a year later its bagged and lays frame and there is still a lot to do. I have decided that I am going for the rat rod look with the primer, eventually the white wall tires on the 15in wheels and a pic of a pinup on the doors.
11-20-2006, 01:34 AM | #2 |
Re: 68swb build up AKA (Baglady)
Looks good!
11-20-2006, 01:37 AM | #3 |
Born To Lose Club
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Saweeet!
Brian Smith - "Born To Lose" 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
11-20-2006, 01:46 AM | #4 |
Looks like a good start!!!! How tall is your rear tires? Also is your frame touching the rear end? I am curious how much bed i will have left when i am done with my truck. Anyways good job and keep up the work!!
Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
11-20-2006, 01:48 AM | #5 |
Here's what i got done this weekend. Finally got the motor done. Bolted the motor and trans together and set it in and started cutting the firewall for the trans tunnel. Found out that I can't run an HEI distributor that sux, it won't clear the firewall. Not sure if i want to cut the top of the firewall yet to make it fit. What are you other bagged guys running for a distributor.
11-20-2006, 02:16 AM | #6 |
hey i have a "evil twin" LOL just kidding look really close to mine.... was mounting up bed a pain it the a$$, i know mine was?
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
11-20-2006, 11:49 AM | #7 |
You can use a small cap hei or a unilite small caps can come with all kinds of goodies underneath. You could even convert a points ignition to a magnetic breakerless for about $75. Good luck and she looks sweet. I'dve left it the way she was, but this is cool as well!
11-20-2006, 07:45 PM | #8 |
Looks good, keep us posted on it.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
11-20-2006, 08:54 PM | #9 |
Sweet
11-21-2006, 08:43 PM | #10 |
The frame is laying on the rear end with no bump stops. The tires on the back right now are 245/75R-15. The bed is only 9 1/4 deep all they way around right now.
11-21-2006, 09:10 PM | #11 |
I like how it looks! Great stance.
The Fastor Pastor '68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed: '70 swb; TH-400 - bagged & shaved. Looking for new engine or parts. Wife - Original {A Real Classic!} |
11-21-2006, 10:25 PM | #12 |
04 Orange & FnLow69..... How much did you guys 'Z' your frames?
As for the dizzy, MSD makes a sweet (and compact) billet dizzy that drops right in & is electronic like the HEI.
11-21-2006, 11:21 PM | #13 |
Man, that looks great with the flat floor!
11-21-2006, 11:27 PM | #14 |
Steel Horse Cowboy
Wow looks really nice!
11-22-2006, 12:16 AM | #15 |
The frame on mine is z'd 6in. We just stacked the frame rails on top of each other.
11-22-2006, 02:30 AM | #16 |
Designated A-hole!
That truck would look good if you lowered it a little bit.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
11-22-2006, 03:19 AM | #17 |
Chevy truck addict
11-22-2006, 12:21 PM | #18 |
i Z'ed mine 3" w/ 2.5" drop spindles
11-22-2006, 07:51 PM | #19 |
Insert Title Here
lookin good, I thought it was another post by FnLow69 when i first looked at it
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 11-22-2006 at 07:54 PM. |
11-23-2006, 12:30 AM | #20 |
Well I was trying to make it lay frame without having to buy spindles and control arms. It worked at first till I completely rebuilt the entire front end with everything new. After I did that it raised the frame up 3in so I had to put drop spindles on it anyway to get it back down on the ground. If I had realized that it wasn't going to work right I wouldn't have z'd it that much.
12-17-2006, 10:56 PM | #21 |
I got to work on the truck this weekend got alot done. Finished cutting the floor out. Painted and hung the doors, put the bed back on and started cutting the fender out to make it fit. Still have to adjust the bed it looks like it is sitting a little high in the rear and i got to find a 67 passenger side fender.
12-17-2006, 11:58 PM | #22 |
THE VILLIAGE IDIOT
man it looks great...i would love to see mine like that,,but with a bad back i cant have my knees up around my neck when driving..or it could be the frind i had that had a s10 like this,,was just built wrong..main thing is i got to be comfortable while driveing,,but i still love the body drop look..
honestly honey,,i have no idea how that truck got here. |
12-18-2006, 12:14 AM | #23 |
Darn both you guys make me feel like mine is a 4x4 Fully dropped I still have about 1" under my rockers!
Looking good, both of you! Kevin LFD Inc. Last edited by Rokcrln; 12-18-2006 at 12:14 AM. |
03-07-2007, 05:46 PM | #24 |
Hot Rods For Life
Any progress?
03-07-2007, 10:37 PM | #25 |
i second the any progress???
btw thats a *****in lookin truck man
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
