Old 11-04-2002, 01:57 PM   #1
melloyello
melloyello's Avatar
fuel line
Just a quick question.... is it possible to place an inline fuel filter just before a mechanical fuel pump? Or will this cause problems? Any thoughts, comments are appreciated.
67 C/20 camper special 350
melloyello is offline   Reply With Quote
Old 11-04-2002, 01:58 PM   #2
Yukon Jack
Yukon Jack's Avatar
That is where mine is located on the present engine. No problems that I am aware of.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-04-2002, 02:06 PM   #3
Piston
Piston's Avatar
Typically you want the fuel filter after the pump incase any debris or componants from the pump are sent upstream. It's also harder on the pump to pull fuel in and could cause pump failure if the filter becomes restricted. Although I'll admin "" I have mine at the rear of the cab before the pump. I couldnt see cluttering up my nice new stainless steel lines and AN fittings with a fuel filter. But I wont have any room to talk with the carb floods out because of some piece of trash from the pump gets in there. Do what ya gotta do, just make sure there's a filter in the line.
Piston is offline   Reply With Quote
Old 11-04-2002, 05:06 PM   #4
hanssolo
hanssolo's Avatar
I use two cheap hi-flow filters. Before and after the pump.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 11-05-2002, 12:52 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have 2 on mine also....one under the cab, and a pretty chrome/glass one under the hood so i can keep tabs on how much rust I am flushing out of the tank.
Old 11-05-2002, 01:00 AM   #6
Blue_71
Bloo
Blue_71's Avatar
ive got one clearish plastic one, but im thinking about taking it out and going filterless again, i had less problems before i put that thing on there, now it wont half run
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 11-05-2002, 01:05 AM   #7
Longhorn Man
Josh...never run filterless. That is just asking for trouble.
Old 11-05-2002, 01:08 AM   #8
Hooter
My other Love
Hooter's Avatar
I have fuel filters under the cab coming off the fuel switch and another one just before the line meets the carb
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 11-05-2002, 01:23 AM   #9
Blue_71
Bloo
Blue_71's Avatar
i cant figure out what happened, it was running fine with the quad, then with the holley, then when i flooded the holley and it shot gas out the top (gotta tune that thing next time ) and then it worked with the quad again for about a hour, then it just doesnt want to run like its not getting gas
1989 Chevy K2500
Old 11-05-2002, 04:15 AM   #10
hanssolo
hanssolo's Avatar
blue- sounds like your pump is going out? I use a Carter hi-volume pump.
Old 11-05-2002, 06:28 AM   #11
Lippyp
English Chevy Owner
Lippyp's Avatar
I also have a Carter electric pump and have two filters, one before the pump and one in the engine bay. I have the first one there to protect the pump.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 01-28-2003, 12:19 PM   #12
Alex Hayley
Since the fuel line from the pump to the carb is hard, how have you guys went about putting a filter between the pump and carb?
Alex Hayley is offline   Reply With Quote
Old 01-28-2003, 01:11 PM   #13
hanssolo
hanssolo's Avatar
alex- I cut about 3" out of the line next to the carb and use neoprene rubber fuel line and Gates clamps on the filter.
Old 01-28-2003, 03:08 PM   #14
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Heres a pic of my inline fuel filter on the left of the carb. Its a clear one which is nice so you can see if fuel is getting to the carb and whether its dirty or not. It was like $10 at Autozone.
Wow I really do need to get a new intake to match that shiny new carb. Performer RPMs soundin good bout now.
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 01-28-2003, 11:54 PM   #15
Blue Beard
Blue Beard's Avatar
Glass Fuel Filter
I hard lined my glass filter in place.
Had several rumors from truck people in my area saying that the filter if attached with rubber fuel line would allow the filter to hit metal and crack or break, you know the rest.
Any comments to this theory?
Blue Beard
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-29-2003, 12:39 AM   #16
Longhorn Man
Blue Beard, it can happen, and has. A gy i know refuses to run them since he singed his stuff under the hood of his big block el camino that way.
however, if you place it where it is imposable to hit anything...then it won't hit anything.
I been running them for years on quite a few vehicles...never had a problem yet. You just gotta think about stuff like that when you do it.
Old 01-29-2003, 04:22 AM   #17
lost wages
lost wages's Avatar
one of my friends had a glass one break, he has a electric fuel pump so it kept pumping fuel, he got caught between the truck and the garage door when he was pushing the truck out of the garage, it was pretty scary, dont take much to start a fire when fuel hits the headers.
lost wages is offline   Reply With Quote
Old 01-29-2003, 04:33 AM   #18
Mudder
Mudder's Avatar
I had one of those break for no reason on a very cold night before I painted my truck red. Wind chill was maybe 20-30 below. It didnt hit anything and was already broken when I got out to my truck after work. Ive been running one since then with no problems.
Mudder is offline   Reply With Quote
Old 01-29-2003, 12:11 PM   #19
hanssolo
hanssolo's Avatar
Well, one thing, if they don,t break they last a long time cause it's easy to take apart and clean. I think maybe some guys overtighten them with pliers and put the strain on the glass. I have one somewhere but am using a cheap plastic throw away unit now.
Old 01-29-2003, 02:22 PM   #20
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
If you had Gas shoot out the top of a holley, there is a good chance it shelled the accelerator pump.......Holley's are notorious for that. My truck has 2 fuel filters, 1 before and 1 after the pump.....never had a problem.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 01-29-2003, 06:59 PM   #21
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
I have a filter before my fuel pump then before the carb. I have a rubber hose running from the pump to the carb...is that bad??? I have seen some with a steel fuel line from the pump to the carb...is it dangerous to have a rubber line???
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 01-30-2003, 04:50 AM   #22
Lippyp
English Chevy Owner
Lippyp's Avatar
I have the same setup as swingsax68, electric fuel pump on frame rail under the cab, short length of rubber to the pump and then rubber line all the way to the carb. I've been wondering about hard lines as the rubber lines need replacing.
Does anyone have a picture of the original solid steel lines, what diameter tube is it and how is it routed? Is it safe to have all rubber lines and would it be better to have steel braided hoses rathaer than just plain rubber?
Phil
'67 C10 long fleet.
Old 01-30-2003, 12:13 PM   #23
pierce
pierce's Avatar
Just got my truck back safe...going to a job this AM on the highway it started going slower 50-40-30 with the gas pedal to the floor. Limped to a gas station and checked all the fluid levels went to start it again, ran fine and made it back home. It has 1 of those coffee canister filters under the pass side cab thats probably clogging up don't know if they make filters like those anymore.
About the original hard line, it runs from the mechanical pump on the block to the front and across the top to a 90 degree turn into the front of the carb that has a built-in filter. If your running rubber line make sure it's fuel line rubber. The hard line is approx 1/4" I've got that setup on the 72 maybe you can make it out on the engine pic at my site.
69 GMC 1 Ton Longhorn
37 Chevy Coupe
pierce is offline   Reply With Quote
Old 01-30-2003, 01:48 PM   #24
mtdave2
newly minted old timer
mtdave2's Avatar
i love the glass ones., used the same one for years now on the harley! it vibrates the hell out of still no trouble. the trick is to posistion the filter so no matter how hard you hit or shake it it never hits anything.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 01-30-2003, 07:40 PM   #25
tom hand
CCRider
tom hand's Avatar
If you want to use one of those glass POS filters, run don't walk to the nearest store and buy a fire extinguser. ( you should have one in your truck anyway. ) The question is not if they will fail, but when.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
