01-13-2007, 08:35 PM | #1 |
Re: progress pics
XXL, would love to see what you had in mind for that front mount.
01-16-2007, 12:54 AM | #2 |
Re: progress pics
what 4 link are u running?
01-16-2007, 01:13 AM | #3 |
Re: progress pics
01-30-2007, 09:00 PM | #4 |
Re: progress pics
Got the 4-link mounted and rear bags on. I changed from going over the axle to in front. Next is the panhard bar. Just ordered it today.
04-18-2008, 10:08 PM | #5 | ||
I'm just glad to be here!
Re: progress pics
Looking at the pictures between these 2 posts, did you change the rear 4-link brackets? They look different. The fronts look the same, just flipped over. If you changed them, did you do it because the the reduced angle of the bars at ride height? Who's brackets did you use? Thanks.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 04-18-2008 at 10:09 PM. Reason: added numbers |
02-01-2007, 04:33 PM | #6 |
Re: progress pics
thats f-ing sweet.
02-12-2007, 12:30 AM | #7 |
Re: progress pics
Looks good, I like the way the tanks are mounted.
02-12-2007, 03:10 PM | #8 |
Re: progress pics
Cant wait to seee more!
02-12-2007, 03:29 PM | #9 |
Commander Taco Bello
Re: progress pics
nice tanks. i'm using one of those exact tanks, but will need to find a different place to mount it since my gas tank is where you have yours.
02-13-2007, 09:00 PM | #10 |
Outlandish Trends - FL
Re: progress pics
looks great! Are those the KP bag brackets?
-Bret 67 short-fleet sold! |
02-13-2007, 10:40 PM | #11 |
Re: progress pics
03-06-2007, 09:49 PM | #12 |
Re: progress pics
Looks great! Keep up the good work.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
03-06-2007, 11:19 PM | #13 |
Re: progress pics
great looking setup!
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
03-07-2007, 12:36 AM | #14 |
Re: progress pics
Looks great! I like your shock mounts!
03-07-2007, 06:01 AM | #15 |
Re: progress pics
nice work
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN 62 HARDTOP NOVA 65 CHEVROLET BB LWB FLEETSIDE 90 CHEVROLET EXTRA CAB CHEVY ONLY - NZ Chapter http://67-72chevytrucks.com/vboard/s...d.php?t=137984 |
03-07-2007, 10:21 PM | #16 |
Re: progress pics
looks sweeeeet. very clean.
69 4wd V6 20k orig miles!! 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
03-08-2007, 12:44 PM | #17 |
Re: progress pics
Thanks guys. Something new I'm trying to figure out......jacking up a slammed truck!
03-09-2007, 04:34 PM | #18 | |
LAIDOUT
Re: progress pics
AJA, I just add some air, slide the jack under, then deflate, then jack it up... |
03-09-2007, 04:36 PM | #19 |
Insert Title Here
Re: progress pics
lookin good
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
03-09-2007, 05:12 PM | #20 |
Re: progress pics
WOW i like it great work i like the welds
nickle and dime |
03-24-2007, 05:43 PM | #21 |
Re: progress pics
today I chopped the crossmember. I went with 1.5". I wasn't going to do all that work for anything less. I have a couple gaps, but overall, its coming out pretty good. I tacked it up and reinstalled it to make sure everything lines up. Now the million dollar question is what I'm gonna do for steering. I kow this subject is old hat, but if anybody can offer suggestions, Id appreciate it.
03-24-2007, 09:07 PM | #22 |
Re: progress pics
nice job on the cuts looks awesome, i would run rack and pinion for steering...
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
03-24-2007, 10:19 PM | #23 |
Re: progress pics
03-25-2007, 12:25 AM | #24 |
Too many projects
Re: progress pics
Has anybody tried moving the steering box and idler arm up on the frame an 1" or so? Or bending the pitman arm flat and raising the idler arm an equal amount to raise the linkage?
You would have to notch the frame for clearance, but it could help you use less joints in the steering shaft if the box was higher. I am looking into this for my cross member chop to avoid linkage / u bolt interference.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
03-25-2007, 12:28 AM | #25 |
Re: progress pics
i just said that tonight too. i think it would work
