Old 12-24-2006, 10:22 PM   #1
masterbeavis
Having issues
masterbeavis's Avatar
What are the chances of this motor ever turning again??
Its been exposed for 2-3 years now. A couple of cylinders filled with water.
masterbeavis is offline   Reply With Quote
Old 12-24-2006, 10:24 PM   #2
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Re: What are the chances of this motor ever turning again??
is that the motor in the '71 Jimmy? Probably just needs the cylinders honed out, new piston rings and a big lopey cam!
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 12-24-2006, 10:32 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Hey, It's a Chevy. You can't hurt those things.... 4x4 about 2 ft long with the corners shaved off & BFH, break the pistons loose, put it together and drive it.......
LockDoc
Leon
Old 12-24-2006, 10:44 PM   #4
timcos
Chief Honcho In Charge
timcos's Avatar
Wd-40 and some duct tape...good to go.
I recommend an HEI dizzy too.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 12-24-2006, 11:22 PM   #5
Slammed70
Slammed70's Avatar
Wow.....that balancer is HUGE
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 12-24-2006, 11:33 PM   #6
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
If you can get all the old stuff out and get it machined it will breath again.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 12-24-2006, 11:49 PM   #7
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
lets see now wat did i use to use to break things loose...oh yeah i think i used kerosene,,let it soak for a day or so,,then a bfh and a 2x4..and make sur eno little kids or ladies are around to hear the cussing...i think i head the mystery oil is supposed to work to,,or deisel fuel works good..my dad always used deisel on old tractors he would pick up that hadnt run in a while...
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 12-25-2006, 12:44 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've seen worse brought back to life with no rebuild... but I don't recomend it.
Old 12-25-2006, 01:05 AM   #9
timcos
timcos's Avatar
Kerosene...is considered a lubricant.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 12-25-2006, 01:06 AM   #10
wolfthing2000
GIBBS will fix it right up!!
wolfthing2000 is offline   Reply With Quote
Old 12-25-2006, 01:17 AM   #11
wolfthing2000
Just looks like a "protective coating of rust" to me. If you have wore out parts, just let em set out , rust up good and assemble and good to go!!!!! Brings back the size..............(old sprint car trick!) I would soak it good with Gibbs, about a week or so, get it in everywhere that moves, and take it apart and hone it out , assemble with a clean bottom end and watch it scream!! A tight bottom end and wore out ( then honed ) run same size rings as the wore out bore ( loose as a go9ose) and use cast rings, good to go haulin' ass!!
I did this on a 327 with 180,000 that I spun a rod bearing on...........put in a regro8und crank kit, a wrecking yard cam from a 350 and did a valve job. What a screamer!! Revved like no bodys business! Ran lotsa more modern trucks right off the road on the freeway pullin a pass or towin!! Had the Ramas Horn run through duals to turbos. Sounded like the wind goin down the road, quiet as a mouse, then look out when i kicked the secondarys in and blasted past em all in the passing lane in the old 66 fleet!!
Rebuild it ala cheap, since it is a turn around motor for sure. Or break it all down and use the block,,,,,,,,it certainly is seasoned by now!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 12-25-2006, 01:35 AM   #12
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Definately a 4bolt motor. Well worth saving.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 12-25-2006, 04:26 AM   #13
72armyswbtruck
72armyswbtruck's Avatar
I think the BFH works best, Oh yah and a few cases of spuds and a few friends
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 12-25-2006, 10:20 AM   #14
Boog
laying low
Boog's Avatar
Had a 327 in this predicament some years back. I soaked the cylinders first then put a grinding stone on an electrical drill and cut down most of the rust buildup to get the pistons out. Rust pits too deep to hone out and the rest of the engine was all standard size so I had the 2 bad cylinders sleeved, honed the other 6, polished crank, new cam and fresh heads and way to go.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-25-2006, 04:31 PM   #15
wolfthing2000
Much better choice than a crate motor!!!!
Old 12-25-2006, 08:12 PM   #16
Ram-Man
Ram-Man's Avatar
1 can of "liquid lifters" and it should be ready to fire up.
Ram-Man is offline   Reply With Quote
Old 12-25-2006, 08:26 PM   #17
Longhorn Man
fill the cylinders with brake fluid, and come back tomorow, you'll get 1/4 to 1/2 turn of the vrank... then top them off again and go back the folowing day. This is assuming you drag it inside.
Again... not recomended onless you like damaged rings and a crappy seal. It'll smoke for a year untill something lets go.
Old 12-25-2006, 08:28 PM   #18
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Hm, brake fluid will really help eh? I've got a 350 shortblock that has two frozen pistons... Had pb sitting the bores for 3 months now, wont budge.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 12-25-2006, 10:45 PM   #19
RustyParts
RustyParts's Avatar
Nothing better than a well seasoned block.
RustyParts is offline   Reply With Quote
Old 12-25-2006, 10:49 PM   #20
Longhorn Man
yep, brake fluid should unlock the rings from the walls...if the crank is stuck too, then I have no idea how to unstick it short of disasembly.
Old 12-25-2006, 11:05 PM   #21
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Crank itself is unstuck, only the rings themselves are stuck.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 12-25-2006, 11:16 PM   #22
JDL
JDL's Avatar
It would be a real good block for a rebuild.
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 12-25-2006, 11:24 PM   #23
blacktruck
Super Trucker
i'd personally, if it was my block, i'd just spring for a whole rebuild. that's my $.02. there are plenty others with much more experience on these matters.
American by birth, Southern by the grace of God.
".. you aint just whistlin' Dixie..."
Rebel till I die
blacktruck is offline   Reply With Quote
Old 12-26-2006, 12:44 AM   #24
wolfthing2000
If it is stuck , use GIBBS lubricant. This stuff penetrates like nobodys busines and leaves behind a good lubricant that fights corrosion. Forget all of the back yard, homemade penetrating oils. I'm not saying they don't work to an extent, but Gibbs is the one!!!
Old 12-26-2006, 01:26 AM   #25
masterbeavis
Having issues
I didnt want to say anything, but I had that motor turning freely within 40 minutes of fooling with it(before I posted this thread). Without touching the motor, I put a 3 foot breaker bar on the balancer bolt, and it moved 10* or so. I worked it back and forth for a mintue or two, had it up to 30* I scraped the crud I could off the cylinder walls with a flexible putty knife, then some WD40 cuz I couldnt find any opened ATF. #3 and #7 were the worst of the bunch, they were the ones holding up the show. No visible rust pits, a hone and ring job will bring this motor back. I dunno about the 4 bolt main part. The shortblock is out of a '75. It is a 010 block, suffix TYW
