Old 01-14-2007, 12:05 PM   #1
cooters
67 hood on 71?
has anyone tried to make a 67/8 hood fit a 71 style front end? Anyone have pics?
cooters is offline   Reply With Quote
Old 01-14-2007, 12:38 PM   #2
cstm68
cstm68's Avatar
Re: 67 hood on 71?
you need 67/68 fenders and grill too. im not shure about the core support.
cstm68 is offline   Reply With Quote
Old 01-14-2007, 02:10 PM   #3
cooters
Re: 67 hood on 71?
changing the leading edge of the hood is what is needed but wondering if anyone has doon it yet
Old 01-14-2007, 02:23 PM   #4
Gray Ghost
Gray Ghost's Avatar
Re: 67 hood on 71?
You will need the 67-68 core support, fenders and hood to complete the transformation.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 01-14-2007, 03:41 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: 67 hood on 71?
The hoods are a different length.I have seen a 71 with the hood pie cut and leaned back like the 67-68 hoods.It looked good and was something only someone who knew would notice.If it looks like the factory did it that way it's usually a goood modIMHO.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-14-2007, 05:40 PM   #6
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 67 hood on 71?
Buffalo is right, basicly you need the entire front clip!
CAL 58 GMC is offline   Reply With Quote
Old 01-14-2007, 06:10 PM   #7
BigSky71
LAIDOUT
BigSky71's Avatar
Re: 67 hood on 71?
Are you referring to this look? Its not my truck, just a picture from my collection. I thought about doing it until I located an early front clip.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 01-15-2007, 09:47 AM   #8
cooters
Re: 67 hood on 71?
thanx for the pic. that is exactly what i want to do to my truck, i will be trying the hood swap this week, pics to come!
Old 01-15-2007, 11:00 AM   #9
bodydropped68
bodydropped68's Avatar
Re: 67 hood on 71?
take your 69-72 hood and lay it back, one site to look at is if customs the have done this many times and have alot of pictures of this being done, take a look at matt eye's section on there site. hope this helps
bodydropped68 is offline   Reply With Quote
Old 01-15-2007, 11:13 AM   #10
Rokcrln
Rokcrln's Avatar
Re: 67 hood on 71?
I think what cooters was asking is a trick that most people would not due because of the amount of work involved. It involves taking a 67-68 hood and shorting the leading edge to the length of a 69-72 and it can and has been done. Their was a burb that had this mod and it looked nice but so does doing the pie section to a 69-72. The only thing with doing a pie section is people that know what they are looking at can see that it is the corect hood just tweaked abit. As with the 67-68 hood on a 69-72 front end should not be able to fit at all so people are not quite sure what took place. Even when you lay the front of a 69-72 back to the same slope as a 67-68 their is still alot of differances between the two. Look at the distance from the front side edge of the hood to where the body line curves up to the upper front slope and you will see the differance between the two hoods. A 67-68 has a longer "ramp" than a 69-72. Yes the core supports are different but only in the head light mounting area and the hood latch. With a few simple mods you can take a 69-72 core support and remove the head light bucket and use that support on a 67-72. But to use a 67-68 on a 69-72 you must fins these head light buckets and weld them on. Keep in mind that chevy was cheap and wanted to use the same basic part for as long as they could and this is good for all of us. Hope this all makes sence!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-15-2007, 11:19 AM   #11
Gray Ghost
Gray Ghost's Avatar
Re: 67 hood on 71?
Can you document the cutting and welding process? I'd like to see the outcome.
Kelly
Old 01-15-2007, 11:30 AM   #12
Rokcrln
Rokcrln's Avatar
Re: 67 hood on 71?
For those that have not noticed the side differance between the two styles here is a white 67 and a brown 70 to compair. I may have to do the 67 hood on my 70 for my "Low buck truck build" thread it would be fun
Kevin
LFD Inc.
Old 01-15-2007, 12:53 PM   #13
raggedjim
raggedjim's Avatar
Re: 67 hood on 71?
Check out the pics in this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=219546
raggedjim is offline   Reply With Quote
Old 01-15-2007, 01:26 PM   #14
Rokcrln
Rokcrln's Avatar
Re: 67 hood on 71?
Yeh this is the one I was thinking of. I was out looking at some of the hoods that I have and it would not be all that bad depending on how you went about it. Problem is what looks like the easy way to put a 67-8 hood on a 69+ will take two hoods (one of each) but that is not a big deal if you have several laying around right
Kevin
LFD Inc.
Old 03-05-2007, 06:45 AM   #15
brak
brak's Avatar
Re: 67 hood on 71?
I asked about the hood in another thread but this brings up a new question...
Other than the marker lights, is there any real difference between the early and later fenders?
----EDIT---
Nevermind, I see can the difference now in post #12
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 03-05-2007, 09:17 AM   #16
Re: 67 hood on 71?
It`s simple to do this on a GMC.Bolt a 67-68 hood on your 69/72 and eliminate the brows and top bar...done.
Old 03-05-2007, 09:47 AM   #17
cooters
Re: 67 hood on 71?
ive been trying to get started on the swap but here is first step, however it will be for a chev grill not a gmc
Old 03-05-2007, 09:54 AM   #18
49studebaker
49studebaker's Avatar
Re: 67 hood on 71?
This has really got me thinking. I realize the fenders on the 71 GMC are the same as 67-68's, but the hood is like the 69-72 Chevy's, where does the transition take place.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 03-05-2007, 10:21 AM   #19
N2GMTrux
N2GMTrux's Avatar
Arrow Re: 67 hood on 71?
There was an issue of Classic Trucks where they showed the entire process of removing the front brace on a 69-72 Chevy hood. Then they pie cut two inches around the front of the hood. Then they tampered the cut on the sides of the hood. Meaning pie cut all they way back,,, almost to about four inches from the back of the hood. What they did is made a 69-72 hood look like a 67-68 hood.
N2GMTrux is offline   Reply With Quote
Old 03-05-2007, 10:53 AM   #20
Re: 67 hood on 71?
In`69 when the hoods changed,GMC added the eyebrow trim to the fender front edgeds and riveted a surround piece (top bar) to the top of the grille to fill the gap.The `68-70 grilles are the same,other than the top bar on the 69/70s.You could swap any year GMC grille around between 67-72.The only thing that seperates the`67 from the 68/70 grilles is the`67 has GMC stamped in it.
Old 03-05-2007, 06:08 PM   #21
raggedjim
raggedjim's Avatar
Re: 67 hood on 71?
ALMOST, you will have to get the 67-68 GMC top bar, the 67-68 GMC grill support and the 67-68 GMC hood latch or it won't work... Trust me.
Rg
Old 03-05-2007, 06:41 PM   #22
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: 67 hood on 71?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-05-2007, 07:41 PM   #23
cooters
Re: 67 hood on 71?
well as soon as i get some time, i will cut 1 1/2 inches from the front of the hood and weld in a front edge and it should be done. There is nothing a weekend of welding and cutting cant cure
Old 03-05-2007, 11:11 PM   #24
49studebaker
Re: 67 hood on 71?
Rg
Thanks guys, I'm going to look into this as I have a donor 68 chevy hood (actually the whole truck) and I'm about ready to start putting the sheet metal back on my 71 GMC.
Old 03-06-2007, 12:42 AM   #25
Re: 67 hood on 71?
The`67s didn`t have a top bar or surround trim.I know that.The rest is true.I was just answering how this could work with the gap compared to a Chevy.Not the entire swap,good info.
