Old 02-12-2007, 03:14 AM   #1
Luis_gz06
Luis_gz06's Avatar
Sheetmetal Gauge comparasion
Is the sheetmetal on 67-72 chevytrucks heavier than 73 and up trucks?
I would also like to know about 50's and early 60's trucks sheetmetal. Were there all the same through 72 or different??
Luis_gz06 is offline   Reply With Quote
Old 02-12-2007, 10:51 AM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Sheetmetal Gauge comparasion
I'd like to know this too.I know my '69 is a tank compaired to newer models,but which year(s) did they start using thinner metal-if anybody here knows.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 02-12-2007, 12:41 PM   #3
bobthecop
bobthecop's Avatar
ttt
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 02-13-2007, 10:08 AM   #4
Huck
Huck's Avatar
The earlier the year of the trucks, the thicker and heavier the sheet metal was used. Just try knocking out a dent on a pre 50's truck and you will see what i mean. Around mid 70s they even painted them without a protective primer and they rusted prior to delivery!!!! Some vendors say the new Tiwan sheet metal is the same thickness or weight as original butttt just sit on a new tailgate---it doesn't have the tack welds through the center as the originals did so not as strong. Try to stay original when possible and protect any sheetmetal you replace with a good paint sealer prior to install. Huck
Huck is offline   Reply With Quote
Old 02-13-2007, 12:03 PM   #5
Luis_gz06
Luis_gz06's Avatar
Just heard from an old guy yesterday that 72 and below were all the same 20 gauge sheetmetal and 73 and up was all JUNK thinner metal!!!!! The only thing he said about old 50's trucks is that they were stamped differently than later models. Maybe thats why it might sound heavier than newer ones!!!
Old 02-13-2007, 01:26 PM   #6
Only thing I can add is experience. Since I mixed, matched and welded parts from an 84 stepside and my 70, I can say that the sheetmetal thickness on the bedsides, step fenders and front panels are the same.
Old 02-14-2007, 07:30 PM   #7
mbgmike
Newer steel has a higher tensile strength than older steel. This allows Mfg's to use the thinner gauge.
mbgmike is offline   Reply With Quote
Old 02-15-2007, 12:41 AM   #8
WorkinLonghorn
Re: Sheet metal Gauge comparasion
Well,this may be true to some extent,but on my '69 my crew and I often walk across the hood,step up on the roof to load stuff into the front of the bed when it is almost full up (4 foot side boards). I weigh 220 lbs and with an 80 lb. load that's 300 lbs with each footstep-----and it is never a problem for the sheet metal. Try that on a 2007 model.
Old 02-15-2007, 12:45 AM   #9
MACO
MACO's Avatar
On newer vechiles the sheet metal is just there to hold the paint up!
1969 C20 Customer Camper CST, 396, TH400, Factory A/C, Olive Green.
MACO is offline   Reply With Quote
Old 02-15-2007, 07:59 AM   #10
AKChevyman
Chevy Forever
AKChevyman's Avatar
I think the new stuff might be the same gauge but it can't be the same density.(or tensile strength) My new repop tailgate weighed 10lbs lighter then my old one. Now it doesn't because I took the thing apart and welded in a 1'X1" tube in the top lip of the tailgate the entire length and replaced the side hinge pieces with the ones from my original. I should have just went and bought a take off tailgate.
My first love
1971 C20
Hugger orange
Getting face lift and heart transplant .30 402 BB /TH400 and GV
Wifes car
1969 Chevelle SS 396 325hp/TH400
Factroy A/C Automatic w/ Floor shift console.
restored.
AKChevyman is offline   Reply With Quote
Old 02-15-2007, 08:09 AM   #11
72-stomper
Not possible
1972 Chevy 1/2 ton on 1981 chevy 3/4 ton 4X4 chassis!
8" lift
Frame off resto.
72-stomper is offline   Reply With Quote
Old 02-15-2007, 02:01 PM   #12
shifty
Questionable
shifty's Avatar
So, just as a general question: What gauge is the firewall in our trucks? I was wondering about this. I bought 16ga to replace whatever is there when shaving it. Is it actually 20ga?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-17-2007, 11:58 PM   #13
shifty
Questionable
shifty's Avatar
Man, I'm at that stage still - can anyone tell me what gauge the stock firewall is, pretty please?
Old 04-18-2007, 12:09 AM   #14
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Man ya know what shifty I tried seaching for ya and guess what thread came up THIS ONE I tried. I don't know either lets see who comes up with the right answer.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 04-18-2007, 12:38 AM   #15
sevt_chevelle
Lost amongst the CORN
sevt_chevelle's Avatar
My 49 and 72 chevy trucks all measure the same on exterior gauge as well as all 3 70 chevelles Ive had. GM used 19 ga on exterior panels as well as other car makers.
16ga for a firewall is too thick, 18 would be a better choice as a thicker gauge was used for more structual parts.
Today's steel is lighter thinner and stronger. You have steel that is sandwiched between plastic, steel with different alloys and quenched at different temps and procedures.
The old steel is draw quality metal very workable, used because it took the molds/presses easily. Today they use ultra strength instead of draw quality because of better technology and because its alot stronger and thinner.
Same holds true with the old/new aluminum. Aluminum is a DREAM to work with, but the stuff they use today you cant touch. Today's AL is throw away...Eric
Currently working on How To Videos and custom metal
70 Chevelle gettin Sliced and Diced Anything But STOCK
70 Chevelle SS455 not a typo its a BUICK BABY
49 and 72 Chevy Trucks restored to original...close to it
Drommer Stor....Norwegian for Dream Big
http://s969.photobucket.com/albums/a...lle/?start=all
https://www.flickr.com/photos/47922830@N03/
Pictures of my work and projects
sevt_chevelle is offline   Reply With Quote
Old 04-18-2007, 12:53 AM   #16
shifty
Questionable
shifty's Avatar
thanks, Eric.
i'm also curious to hear from guys who've shaved their firewall (Shane, where are you? ) and finding out what they went with for metal. I'd hate to think I got a big ass sheet of 16ga steel for nothing
Old 04-18-2007, 12:57 AM   #17
brak
brak's Avatar
PM rokcrln He'd know
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 04-18-2007, 01:01 AM   #18
RACINJASON22
GEARHEAD
Shifty when I did the seach I read something about a honda hood Shane used
and it beung the same gage as the fire wall and got a pretty funny reply but there was no mention on actual #'s.
found it read herehttp://67-72chevytrucks.com/vboard/s...d.php?t=233488
Old 04-18-2007, 01:16 AM   #19
pat
pat's Avatar
Does anybody have a micrometer?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 04-18-2007, 01:24 AM   #20
Luis_gz06
Luis_gz06's Avatar
I just guess all sheetmetal from 72 below were all the same!! 73 & up is lighter.
Old 04-18-2007, 01:27 AM   #21
RACINJASON22
GEARHEAD
I do but the truck is here and it is not or I would go check right now.
Old 04-18-2007, 05:37 AM   #22
Shifty, I have some old step bedsides, as well as an extra hood that I get my patch panels from. I cut pieces from the original bedsides of my truck to patch the firewall.
Old 04-18-2007, 05:38 AM   #23
GMC Jim
GMC Jim's Avatar
I could be wrong but it comes to mind that 1/8" = 11 gauge; and 16 guage is 1/16" thick..........
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 04-18-2007, 08:52 AM   #24
Richard H.
Spanked once
Richard H.'s Avatar
Eric , There is a plant in Indy Called GM Truck and Bus that stamps The skin metals for there trucks. The first time I was in there was in 1972 and have made several return visits as an " outside" electrician. At any given time there are over 250,000 doors riding along on the carousel awaiting fabrication at the plant. They do stamp the firewalls and fender parts there also. Kind of neat watching the firewall being done , roll of sheet metal being fed into a machine that has a total wieght of 3200 tons and out the other end come a firewall with all the holes punched and all the fasteners welded and or crimped in.
I believe it is all the same size metal for these parts to eliminate plant confusion or error. Heavier parts like the radiator support are made some where else.
Richard H. is offline   Reply With Quote
Old 04-18-2007, 09:50 AM   #25
sevt_chevelle
Rich,
There is nothing like taking a tour throu a plant. One of the coolest was the fridage air(sp?) in Iowa where they make washers and driers.
Anyways theres some numbers for you guys
16ga .0598 right at 1/16
18ga .0478
20ga .0359
I dont have the numbers for 19 ga but around .040/.041
Ive never measured the "inside" metal on my 72 as I didnt have to replace any metal, but the floors on the chevelle where thicker as well the firewall. The floor braces, trunk braces and few other braces measured 16ga.
19ga is correct ga to use but since its hard to find most use 18ga unless there is lots of shaping involved then they switch to 20 ga because its easier to shape...Eric
