New-B needs advice on C4 susp.
Hello all,
I'm a new guy to this site and thought it may be the place to gain some much-needed advice on installing a complete C4 suspension into my 58 Chevy Apache project. The plan is to use Flat-Outs front crossmember kit along with the bolt-on rear kit. Motor will be 454 BB from an 86 Silverado along w/ TH400 tranny from the same truck. I guess I am seeking any and all information I can acquire regarding this setup. Anyone w/ experience installing a big block into a 55-59 chevy pickup will be a huge help to me as well. Here are a couple of pics to show what I am starting with, a pretty solid roller. Thanks much! paul5663 |
ToTM Winner
Re: New-B needs advice on C4 susp.
Good Lookin 4 holer, keep us updated on your progress.
Welcome to the board from Central Califorina!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
Apache Club
nice project
![]() ![]() My Trucks Apache Sitting Idle MySpace Project Dad's Truck (74 C-10 to K-10 conversion) ![]() |
Check out this thread;
http://67-72chevytrucks.com/vboard/s...ighlight=block You probably will hafta massage the firewall for clearance and maybe you want to shave that anyways. Good luck on such a sweet project and keep those pics coming. |
Hello:
I am using Flat Out parts. Check out my CarDomin site. PM me for more. http://www.cardomain.com/ride/2330005 |
Certified Car Nut
Fuchster I was just about to send him to your cardomain site.
Thanks a mil. Where are you now on your 58?
Certified Car Nut
If this was directed to me I at the point of no return, too much money spent and it still looks like crap, but I'm in too deep to stop now.
![]() Really I'm at the mock up stage almost really for my 2nd tear down and reassembly starting from the frame up. |
I suggest sending Frizzle Fry a PM. He is doing a 60-66 with a C5 (I think) set up. Find his thread in the 60-66 forum and check out the pics. The work is amazing to say the least.
Good luck on it, it looks like a solid start. Welcome!
1959 GMC project |
Here it is, found it.
http://67-72chevytrucks.com/vboard/s...d.php?t=179289
1959 GMC project |
Thanks Jebb, the Frizzle 61 C10 / C5 is seriously impressive and definitely is inspiring me to get the 58 C4 officially started. Good news is the complete '85'vette suspension is on it's way from Michigan. I run a powder coating business so everythings getting a new finish. Flat out install kits for front and rear are ordered. I'll post detailed pics of powder coat process and build as it progresses. Got the fever.
paul5663 |
Awsome! Can't wait to see what this one will turn out like!
Fuchster that truck is gonna be NUTS! Nice work!
1959 GMC project |
Some recent developments: Suspension is in and work has officially begun. Recieved the FlatOut rear install kit and the parts appear to be of decent quality. Powder coated all four calipers. and will be posting more soon of A-arms and hubs and more to be coated.
I ordered an "X-member" from Progressive Automotive to stiffen the frame. Hasn't arrived yet. Anyone used one of these before? |
#15 |
Apache - C4 install update
It's been a while but have made some progress since last post. Got down to business on the frame and front and rear are both in place. Now to box entire frame and install Progressive Automotives X-member. Picked up some 18" Coy C5 wheels that should look fine. Mocked up what I could to get and idea on the stance. I'll add more as it goes down.
#16 |
great stance even without the heavy stuff in it
'56 Big window 350/700r4 9" rear w/disc |
#17 |
that is gonna be sinsiter looking.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#18 |
Latest on my 59....... have frame boxed and progessive X-member is in place. Next will be to place cab on frame to line up position of brake pedal bracket etc, as well as mock-up motor (opted for ZZ4) and trans (700R4) to position motor and trans mounts.
#19 |
Did you center your wheels in the front fender?
#20 |
I installed the crossmember onto the frame as directed by Flat Out's directions included with the kit. I mocked up the frontend and it was well centered (see pic)
#21 |
![]() Join Date: Mar 2005
I love it! Keep postin' them pics! Very nice fab work, by the way.
#22 |
Yellow truck club
This is starting to look killer......
Keep the pictures coming.. Always like seeing another 4 lighter come back to life .... Brian .... ![]()
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
#23 |
Paul, looks great. I am going to be installing the Progressive cross member soon....probably next weekend or the one after. Did you have any issues with it? From the looks of the directions it looks pretty straight forward. Keep up the great work.
Bernie |
#24 |
Yellow truck club
Any one have the link for Flat-out ??
Brian .... ![]()
#25 |
Thanks Bernie and no, not any real problems w/ installation. Just square and measure often. Went pretty smooth, I'm not gonna win any pretty-weld beauty contest... thats for sure, but it'll hold.
Brian, unfortunately Flat Out is only reachable by phone (714-639-2623). Good part is that Don is very knowledgable and will certainly take care of his customers, at least that is my experience so far. |
