Old 03-31-2007, 07:03 PM   #1
corkscrew
Where could i find a Turbo that attaches on to your muffler...
I saw one on TV the other day and am very interested...thanks for your help
corkscrew is offline   Reply With Quote
Old 03-31-2007, 07:30 PM   #2
neonlarry
neonlarry's Avatar
Re: Where could i find a Turbo that attaches on to youf muffler...
here is one place:
http://www.ststurbo.com/universal_system
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-31-2007, 09:16 PM   #3
corkscrew
Anywhere else guys?
Old 03-31-2007, 11:38 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Contact forum member Capt Kaos. Chris is a dealer for the one above...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-01-2007, 12:39 AM   #5
dogfishguzzler
dogfishguzzler's Avatar
Im interested in seeing this forum play out; being ignorant in such matters it seems to me "how do you suck instead of blow?" would you need a new cam to have an "exhaust turbo" seems to me that you would but my knowledge is limited.
69 C10 a long way from done
dogfishguzzler is offline   Reply With Quote
Old 04-01-2007, 01:53 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Turbos are run by the exhaust, with the exception of some new belt driven turbo...which is basicly a supercharger then.
These being discussed here are just mounted under the vehicle instead of right off the exhaust manifold.
If you have room under hood for a traditional turbo, then there is pretty much no advantage to this under body type.
Old 04-01-2007, 05:43 AM   #7
GREASEMONKEY72
GREASEMONKEY72's Avatar
the turbo style ones run by the belt are prochargers and are a mix of a supercharger in the turbo form and as far as the turbos under the car or at the back you will have more lag vs being under the hood and closer end result is the less lag the sooner the power hits
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 04-01-2007, 08:29 AM   #8
Longhorn Man
and less boost period since the exhaust has cooled quite a bit and has less force to it. More high pressure compressed air leaks, esp in the cold weather too
Old 04-01-2007, 10:27 AM   #9
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
Yeah you can only run 6-8 #'s of boost on these...
Pl4yboy is offline   Reply With Quote
Old 04-01-2007, 12:37 PM   #10
pharcydekm
Now I speak from zero experience with these turbos but... You can run up to 15psi of boost and from what I have heard the lag is not an issue. I too would like to see how this thread goes and would love to hear someone chime in that has used one or at least been in or seen a vehicle with one.
I saw an episode of Horsepower TV that they intalled one on a C5 Corvette. It looked awesome!!!
They are still very new so I can see how people would be cautious on throwing down the cash for it.
pharcydekm is offline   Reply With Quote
Old 04-01-2007, 01:39 PM   #11
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
It seems like a lot of money for the "universal system" from STS. $3k gets you a run of the mill diesel truck turbo, a pop- off valve & trinkets, an oil scavanging pump that can be bought here http://www.rbracing-rsr.com/oilsystems.htm for $530 (which includes the "super" pump & check valves). Sure, the trinkets add up, but not that much. Buy the oil pump from RBR, pick up a turbo from a diesel shop, get the pop-off on ebay, have your oil lines made locally, buy a power relay & make the simple wiring yourself. I think all this could be bought for under $1500. Then the $1500 you saved can be used for the exhaust work/ mounting & air piping.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 04-01-2007, 03:51 PM   #12
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
Maybe I'm wrong about the boost. But I did hear that somewhere.
Old 04-05-2007, 02:51 AM   #13
GREASEMONKEY72
nice camaro
-steven
Alte Seele S.S.
Old 04-05-2007, 07:13 AM   #14
Is there a slight chance water might find it`s way into the filter on the red car???
With these under body turbos,what about wastegate controllers?Under the hood they have problems hanging up,already.I can imagine road grime,oil,and corrosion would surely play havoc on this component.
Old 04-05-2007, 07:27 AM   #15
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
IMO, the lag is going to be increased with the turbo back that far. You have the intake at the rear now and you are going to pressurize the pipe that runs all the way back to your carb/throttle body. The shorter that plumbing is the better, plus it will be less prone to boost leaks.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-05-2007, 12:07 PM   #16
pharcydekm
s/t
Agreed on the longer pipe more chance for leaks sid eof it. But... on the boost once the pressure is there it is there. In my mind it would be like an air hose connected to an air compressor if it is 100psi 2" from the compressor it is going to be 100psi 10' from the compressor.
Old 04-05-2007, 03:51 PM   #17
neonlarry
neonlarry's Avatar
But your air compressor doesn't put out 1200° air that cools to 100° in that 10'. The airspeed is a lot less 10'ft away from the manifold.
Old 04-05-2007, 09:31 PM   #18
Cooler air is a good thing.That`s why there`s intercoolers.Cooler charge air allows higher boost with tolerable EGTs.Longer tubing does not effect charge air pressure.
Old 04-05-2007, 09:37 PM   #19
GREASEMONKEY72
cooler air also makes more HP, but IMO theres just alot more risk just driving normaly on the street with the turbo sitting under the car and the airfilter being right there next to the road plus i mean come on it looks so much cooler sitting under the hood
-steven
Alte Seele S.S.
Old 04-05-2007, 10:36 PM   #20
N2TRUX
Happy to be here
N2TRUX's Avatar
Maybe this will answer some of your questions and minimize the speculation.-
Benefits of Remote Mounting
Ease of installation. STS turbo systems can be installed in about 8 hours with standard tools and average mechanical ability.
Performance Sound. The turbo acts as a muffler and sounds like an aftermarket performance muffler. Turbo spool and rushing air from the blow-off valve make a unique sound that will turn heads!
No need for major modifications to your vehicle. STS systems are designed to "bolt-on" to factory mounts.
Increased gas mileage. Unlike a belt driven supercharger, the turbo utilizes "wasted" energy leaving your tailpipe. Most of our customers get 1-3 mpg increase in gas mileage.
Lower underhood temperatures. No need to worry about melting wires, hoses, or other components.
Converts back to stock in about an hour.
More room under the hood. Future repair work or modifications will not require the expense of removing the turbo system to allow access to engine components.
Cooler oil to the turbo. Cool oil is better for both the turbo and engine.
Approximately 500F lower turbo temperatures. Eliminates the need for a turbo-timer, which allows the engine to run after the car is shut off in order to cool down the turbo and prevent oil and bearing damage.
Denser exhaust gasses drive the turbo turbine wheel more efficiently.
Built-in intercooling. Intake piping provides ~50% intercooler efficiency. There is no need for the expense, pressure drop, and installation problems associated with a front mounted intercooler.
Turbo is exposed to ambient air rather than underhood air. Allows for better cooling of turbo components.
No need for expensive headers, mufflers, or exhaust systems.
Turbo is closer to the tail pipe outlet. Provides a better pressure differential across the turbine wheel which promotes better flow across turbine.
Better weight transfer. Increases traction because the bulk of system is mounted in rear of vehicle rather than up front.
Less noise in the passenger compartment.
Articles-
"Refining Sierra"
Old 04-06-2007, 08:30 AM   #21
Sorry N2TRUX,that sounds like a bunch of sales b.s. to me.A few possible pluses,none to outweight the minuses IMO.
"Better weight transfer?"About like sitting a 12-pack on the passenger floor.
"Increased gas mileage?"They only compare it to a belt system.
Just a sample
Old 04-06-2007, 10:34 AM   #22
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Where could i find a Turbo that attaches on to your muffler...
It may be sales hype BS, but at least it's coming from someone that knows the system, and not a bunch of " I heard from a friend" speculation. Or "buy all the parts and build it yourself".
I have my concerns over this system too, but it does produce results. On an older car or truck, there isn't as much advantage since space under the hood is not a real concern.
On a late model car or truck where space under the hood is a major issue, this system has huge advantages. Yes, there may be some trade offs but the benefits "appear" to out weigh the trade offs.
Articles-
"Refining Sierra"
Old 04-06-2007, 10:42 AM   #23
msgross
msgross's Avatar
I saw the guys on "horsepower TV" do this to a Corvette. Longhorn man is right on when he said that room under the hood is the main reason for this. As for Lag, they said it wasn't that noticeable but the benefit came from cooler boosted air since it had to travel the length of the car to enter the engine. Cooler air is denser air = more good! The car sounded like a jet with twin exhaust turbos screeming...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-06-2007, 05:37 PM   #24
russellmarling
russellmarling's Avatar
I read a review (In Chevy High Performance Magazine I think) on the STS turbo setup on a 4th gen Camaro. It performed great except in the rain. They said the car ran rough when it was wet because the air filter was so exposed. This would be a major concern on a daily driver. If you plan on driving in heavy rain don't use one.
'70 GMC SWB step-side- 454, 4 speed, air bags (in progress)
'09 CTS-V M6
'03 Sierra SWB Z71
'82 Yamaha Seca XJ650R Turbo!
'04 Yamaha FZ6
russellmarling is offline   Reply With Quote
Old 04-06-2007, 06:30 PM   #25
pharcydekm
Great point!!
This is exactley why this board kicks *ss!!!
