Master Blaster
My blazer pics
I hope that these post ok.
Master Blaster
Re: My blazer pics
More pics. Try to imagine the blaz a bright yellow(maybe next fall). I still have to add the new air ride management and finish some firewall work. Then lots or odds and ends...........jesse
Master Blaster
Re: My blazer pics
Thanks for all the help in getting the blaz this far. I read these forums regularly
Master Blaster
Re: My blazer pics
still more pics...........
Master Blaster
Re: My blazer pics
Last set.........for now
Re: My blazer pics
Sweeeet one you got there!
Re: My blazer pics
Lookin' CLEAN!
What serpentine setup is that? I've never seen one with the A/C compressor on the passenger side like that. |
67 Chevy Stepside
Re: My blazer pics
nice truck
1967 Chevy stepside 1976 BIG DOOLEY 454 turbo 400 4:11 |
Re: My blazer pics
that is one fine blazer........how'd a/c turn out,happy with it?
" Never look up a dead dogs butt." ![]() |
Re: My blazer pics
How much did you drop it? And what size are the wheels?
Chris
Re: My blazer pics
Nice ride.
What kind of drop does it have, and is that a vintage air setup or what?
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
Master Blaster
Re: My blazer pics
serp setup is from gm performance(all new) you can get the same stuff from early to mid 90's camaro I think. Others will have way more info. the kit from gm ram me about 750.00$ all new and every nut and bolt to complete(reverse water pump, power steering pump, alt., air compressor, idler). Boatpuller, I love the A/C from vintage
![]() ![]() ![]() The tires are 245/40/20 front and 295/40/20 very pleased here also, next fronts might be 245/50/20. Just a little more sidewall, this is driven as much as possible ![]() |
Master Blaster
Re: My blazer pics
Drop: all airride, four-link in the rear with Blackbirds rear disk conversion(highly recommend) standard bags and plates up front. The air bottle will be coming out of the rear and in goes the new airride electrics with a 5 gal. tank and two compressors with valves and pressure solenoids. I just dont trust the 10 pound bottle, no way to generate your own air if you have a problem.(tried to go simple and cheap, just dont trust it on a 5 hour drive to san diego
Re: My blazer pics
gosh, there are so many AZ members on this forum!
#15 |
It followed me home?
Re: My blazer pics
Very nice Blazer, would you mind taking a closer pic of the roll pan? I'm curious how far the tank hangs below the rollpan. Thanks and the seats look great, do you mind me asking what it cost to get the rear recovered?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 05-20-2007 at 08:38 PM. |
#16 |
What Hump?
Re: My blazer pics
Very nice.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
#17 |
Master Blaster
Re: My blazer pics
rollpan was on the blaz when i purchased it. the tank hangs down pretty far
![]() ![]() As far as the rear seat, I had the seat done and the carbon fiber looking side panels, along with the carpet glued to the mat over the dynamat at the same time. I am not sure about just the seat price, I do know that using GM material is more than just about anything else ![]() |
#18 |
BAD BOW-Silverado XST
Re: My blazer pics
Nice setup. What type crate motor is that? How did you route the heater hose? I'm trying to work mine out. Does your water pump have two ports or one port? I'm adding a similiar serpentine belt to my 83.
#19 |
Master Blaster
Re: My blazer pics
Motor is a zz4, the water pump is a reverse rotation short for the serp setup. I believe it only has one port for the heater hose other heater hose is on the intake. Do a search for Gilbert cheverolet, they used to be named sallee chevy, very good info on the performance parts stuff.
#20 |
Until Seventy Times Seven
Re: My blazer pics
Good looking Blazer, inside and out.
![]() ![]() ![]() BTW, what's sitting on the roof?
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
#21 |
Re: My blazer pics
Which hose did you use as a supply? Return?
Does the bracket to the passenger side head only use two bolts? |
#22 |
Re: My blazer pics
Sweet looking blazer!! Good idea on the front tire meat. I was looking at the pix saying " that would look sweeter with more meat on the front wheels" lol
#23 |
Right in front of you.
Re: My blazer pics
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A |
#24 |
Cruzzzn' Vet
Re: My blazer pics
Very,Very Nice
![]() John |
#25 |
Master Blaster
Re: My blazer pics
Malo- she is a $h!!tty champange color and a 20 footer at that
