Old 05-24-2007, 11:05 PM   #1
streetstar
streetstar's Avatar
mileage motors
Kind of a funny topic under other circumstances, but this is a forum board full of people with 10 mpg vehicles. I like to drive my truck more than let it sit, and was wondering if any of you remember if the 305 Chevy motors from the mid '80's had any special cam grinds or anything that helped them get decent mileage. My '84 with an OD tranny got 18-19 bone stock back when i was in high school (late 80's) ---- My '06 F150 doesnt even get that good.
Anyway -- what tricks do i need to know to build a replica of my '84 setup for a '75 C10? I have a stock 305 motor from that era, but i suspect most of the efficiency came from the overdrive tranny, which i am willing to pony up for, but i am wondering if i need to use any special cam profiles or torque converters or anything.
(i will be pissed if i spend $1500 and take 100 hp's away from my truck to go from 10 mpg to , 12 or 13)
streetstar is offline   Reply With Quote
Old 05-25-2007, 02:28 AM   #2
Omnivec
Re: mileage motors
I don't know much on the cam grinds, but gm like to use swirl port heads on there low end 305s to help mix air and gas.
67 3/4 Lwb Step side X San Diego County truck
70 3/4 berb was 402 Th400 Dana 60 now just the dana
70 3/4 lwb Fleet Choptop bagged th350 no eng yet
79 rx7 Wide body 350 TPI t5 flat black(The interceptor)
64 comet mounted on a 93 Thunderbird chassis.
Omnivec is offline   Reply With Quote
Old 05-25-2007, 02:35 AM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: mileage motors
tighter compression and smaller cubes would be my guess
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-25-2007, 03:19 AM   #4
rwgregory
Re: mileage motors
Try an Isky "Mile-a-Mor" cam. I have personally never used one, but I have heard good things about them. Good performance and better fuel mileage, hmmm, what a concept...
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 05-25-2007, 04:14 AM   #5
combustion
Re: mileage motors
its called varible valve timing
lol
=P
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 05-25-2007, 06:14 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: mileage motors
just get a bigger motor.
I have a way outta tune 425 big block (worn thirtey over) with a non overdrive and 4.10 gears, and I get 12.5 on the freeway at 70.
Old 05-25-2007, 07:48 AM   #7
mrein3
mrein3's Avatar
Re: mileage motors
The real beauty of a big block - other than gobs of torque - is that if you're geting 12.5 on the freeway now, you'll get 12.5 with a head wind. Also with a tail wind. Also towing a boat or trailer full of toys.
If you're getting 10 mpg now, don't expect anything better than 13 with an overdrive. Typical OD ratios are .7:1 verses the 1:1 with non-overdrive.
(For the math challenged that is a 30% better ratio in OD, 30% of 10mpg is 3mpg, 10+3= 13mpg)
However you won't see EXACTLY 30% because until you get to overdrive and the torque converter locks up, you're still slipping away some mileage in the coverter.
If you are sitting at 10mpg now, you may want to tune it up good. Set the carb right. Leave the engine you got. Install the OD.
You may want to get a tach before you go OD. Some folks with 308 rear end gears have found a LOSS of gas mileage with an OD tranny. You can get too LOW of an RPM on the highway and actually hurt your mileage.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 05-25-2007, 11:14 PM   #8
streetstar
streetstar's Avatar
Re: mileage motors
Thanks for the responses --- the 305 i have is a low mileage motor - (45,000) and i have replaced the gaskets and valve seals to prepare it for use again. I will look into that Isky cam -- sounds like what i need. I was attempting a mild performance re-build on the motor a year ago, but lost interest in the 305, but i am more than willing to yank the lumpy cam i installed under the circumstances. The stock intake is long gone, but i have an aluminum one from a mid 70's corvette i can use if i can dig up a Quadra jet. (current intake sitting on the engine is a Performer RPM- which i am also willing to shelve in favor of a more fuel efficient engine if i have to)
The current engine in the truck uses an Edelbrock carb, but i was wondering if the '84 Q-jet could be re-built to be used in a non computer controlled vehicle?
I assume the transmission in my recipient vehicle is a basically stock TH350. Does anyone know what difference a lockup vs. non-lockup converter would make as well with a mildly tuned 305?
Lot of questions - i know
Old 05-25-2007, 11:21 PM   #9
streetstar
streetstar's Avatar
Re: mileage motors
.[/QUOTE]
I probably would leave it alone and suffer at the pumps, but the current 350 in the truck is locked up, --- the 305 is doing nothing and would be a cheap swap for a semi-daily driver. But as i said in an earlier post -- i sure hate to lose hp's unless i gained some mpg's somehow.
Besides, my 75 is a driver, i have a 496 thats "set to kill" in my '69 for when i want to go fast in a straight line.
Old 05-26-2007, 05:07 AM   #10
68K20 x Drill
Re: mileage motors
Lockup TC will make a difference, more difference with higher stalling convertors.
A 2bbl carb can help, but TBI would probably be better. Overdrive will make more difference than either. Hang one of those plastic craps under the front bumper, fold mirrors in at speed. Install a vacuum guage so you can tune and drive for the highest vac reading at criuse. i once gave my friends 82? Sub 3MPG by hooking up the smog system...The 5 port valve in the thermostat housing, don't bother with the AIR unless you need it to pass inspection. YMMV
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 05-26-2007, 07:25 AM   #11
Longhorn Man
Re: mileage motors
a 2bbl would kill the MPG on a truck/car with a carefull driver.
Old 05-26-2007, 08:30 AM   #12
mnunn454
mnunn454's Avatar
Re: mileage motors
Since we're all tossing in opinions, if I were in your shoes, here's how I'd go about seeking higher MPG.
1) measure tire diameter and ring and pinion to determine drive ratio with two different trannies (1:1 TH350 and a 0.7:1 TH200 or TH700). Choose the driveline option that comes the closest to letting your engine spin about 2000 revs at 65-70 MPH.
2) If the above can be done with a TH350, make sure get one with a lock up converter (TH350C). The TH200/700s come with lockup.
3) Use a stock converter or one made for an RV. Not a high stall.
4) Choose a cam grind that has a lot of LSA (Lobe Separation Angle) to minimize valve overlap. Ideally one that's been prescribed for your application. Talk to the experts.
5) Choose your headers carefully. For the stock 305 you'll want very long and relatively small diameter (about 1-1/2") primary tubes for best torque.
6) Make sure you use an MSD box in conjunction with your HEI distrib. Below 3000 RPMs, it sparks multiple times and burns the fuel more efficiently.
7) Install an O2 sensor and A/F meter and jet the primaries on your carb for 14.7:1 A/F ratio while cruising at highway speeds.
8) if bucks are still available, use an Edelbrock "Performer" or similar high torque/low RPM dual plane aluminum manifold.
9) If there's still more of that green candy in your pockets, find out which heads you have now and consider upgrading them to ones that'll yield about 9.5:1 one compression ratio.
Of course, all this assume emissions requirements aren't an issue. If they are, then it'll require a different choice of emissions legal parts, but the strategy is still the same.
Hope it helps.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 05-26-2007, 10:39 PM   #13
streetstar
streetstar's Avatar
Re: mileage motors
Cool --
thanks for the replies --
Cashflow isnt that much of an issue to an extent (lets call it a grand for the project-more or less)---- but if i had unlimited resources, i would just have a shop swap in a newer vette or z28 efi motor and tranny combo and be done with it.
As for exhaust, i was just gonna use rams horns for appearance issues - i have a set of long skinny flow-techs, but don't relish the idea of how fugly they look after 6 months and ceramic coating them is out of the question
Old 05-27-2007, 05:35 AM   #14
GREASEMONKEY72
Re: mileage motors
i though you had a 500?
-steven
Alte Seele S.S.
Old 05-27-2007, 11:51 AM   #15
Longhorn Man
Re: mileage motors
it was makin death noises, so it came out. This was back in march
Old 05-27-2007, 11:07 PM   #16
GREASEMONKEY72
Re: mileage motors
ah ok, any difference between the 500 and the 425?
retselgerg - 511.000 miles, man thats alot of miles
-steven
Alte Seele S.S.
Old 05-27-2007, 11:31 PM   #17
Brad
Out of the carpool lane.
Brad's Avatar
Re: mileage motors
Anyone check out the current issue of Camaro Performers? There's an article about how to add 150hp to the 305. There key component was the use of EngineQuest Lightning cyclinder heads milled .030 along with an Edelbrock Performer AirGap intake and a Barry Grant 650 carb. They made 372hp at 6100rpm. Pretty interesting read and I'd totally do it if I had a 305!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 05-27-2007, 11:36 PM   #18
Longhorn Man
Re: mileage motors
yeah, about 75 cubes!
Well, neither engine was really all that sound. So I *try* to resist from getting into it too much. I have noticed a slight decrease in torque, but I'm not sure if it's the junk engine, the crappy carb, or what. i wanted to get the 500 rebuilt, but the sticker shock tossed the engine off the tailgate into the scrap yard. Got a whopping 45 bucks out of it. I'l probably gonna go look at a couple deralict caddys I've noticed around town, maybe one will actually run good and be cheap. Who knows.
Old 05-28-2007, 02:18 AM   #19
Brad
Brad's Avatar
Re: mileage motors
Hey Andy, you can always get a 6!
Old 05-28-2007, 02:24 AM   #20
GREASEMONKEY72
Re: mileage motors
smartass
-steven
Alte Seele S.S.
Old 05-28-2007, 03:08 AM   #21
cameeks
Long Fleet Club
cameeks's Avatar
Re: mileage motors
I'm getting a TPI kit from First Fuel Injection
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 05-28-2007, 09:56 AM   #22
Longhorn Man
Re: mileage motors
I've driven many 6 cylinder trucks, and there was only one that I think I would be happy with, but the turbo and intercooler alone are worth more than everything I own.
Old 05-28-2007, 10:59 AM   #23
Tmiller
slims 68
Re: mileage motors
I wish i had the pecs but I know my cousin whom i go to the drags with gets 23 mpg on the highway, and this is a stout 480hp 350 chevy. I know he's running a 700r4, 10.5:1 comp, a 750 holley and some 5.13 gears. I'd find it hard to believe but my gas guzzlin 11mpg big block will suck a tankfull to get to the stip but his only use a half. I'm sure theres alot to do with tunning because he can sure tune the hell outta that thing.
68 c10 LWB, blown 454 , 550 hp & 600 tq est.
06 Chevy Cobalt SS supercharged 2.0L
08 Chevy silverado crew cab 1/2 ton 2wd 5.3L, she wont let me put a supercharger on it.
Tmiller is offline   Reply With Quote
Old 05-28-2007, 05:33 PM   #24
mnunn454
mnunn454's Avatar
Re: mileage motors
It's mostly in adjusting the air fuel ratio to be stingy with gas when you don't need it without compromising too much driveability. 5.13 rear gears with a locked up 700R4 means he's running a drive ratio in the 3.6 range. Couple that with tall tires, and you're right in the sweet spot for a 350 SBC to get decent mileage. Still, 480 HP (all on gas I assume) AND 23 MPG is really impressive and getting close to perfection, I think.
Slowing the engine revs down, opening up the exhaust, raising the compression some, tuning the a/f ratio to average about 14.7:1 on the highway should go a long way toward reaching your goals. I'd think a 25% to 30% improvement isn't unreasonable for our trucks.
Old 05-28-2007, 06:51 PM   #25
Pyrotechnic
Pyrotechnic's Avatar
Re: mileage motors
Use a QuadraJet. I know they are a little strange to work on, but once rebuilt and tuned properly those small primaries will get you great gas mileage. When you need to pass someone or have a little fun, you have those huge secondaries.
I think a 3.08 gear out back was the standard option in the 80's as well.
Pyrotechnic is offline   Reply With Quote
