Old 06-09-2007, 08:48 PM   #1
Texas1971
Do our trucks use door key ... or same as ignition?
My ignition keys don't work on door locks. Did they have a round key for doors 1n '71? Can anybody make one based on VIN or do you have to remove or replace lock? Thanks in advance.
Texas1971 is offline   Reply With Quote
Old 06-09-2007, 08:49 PM   #2
Re: Do our trucks use door key ... or same as ignition?
They are separate keys for the ignition and doors, that is if they are still stock.
Old 06-09-2007, 09:35 PM   #3
Texas1971
Yes, the square key will go in the lock all the way, but it won't turn the lock. I thought maybe the lock was just froze, but you are probably right that it was a separate key. Do you recommend taking out the lock and having a locksmith make a key OR replace the cartridge OR what. Any advice is appreciated!
Old 06-09-2007, 09:54 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Has anyone made one key to work everything? I was thinking of doing that down the road. Is it better to keep separate keys?
I think you need to pull the code from the passenger side lock cylinder to have new key made.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 06-09-2007, 10:05 PM   #5
1LoC10
Insert Title Here
1LoC10's Avatar
my sqare key does the doors and ignition...guess its not stock
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 06-09-2007, 10:09 PM   #6
BarryB
BarryB's Avatar
Probablly cheaper in the long run just to replace the lock cylinders. I don't think they're more than 30 bucks. Just my $.02
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 06-09-2007, 10:18 PM   #7
Texas1971
Yep, a pair of cylinders are cheap at $15. Can you get to them by just taking of the inside panels?
Old 06-09-2007, 10:24 PM   #8
Sport/Truck
Sierra Grande Club
Not sure what to expect on the other side of the door panel, IE window regulator and such, but shouldn’t be that hard.
Where did you find the lock cylinders?
s/t
Old 06-09-2007, 10:27 PM   #9
GREASEMONKEY72
GREASEMONKEY72's Avatar
so they originally had seperate keys?
my one key does both ign and doors
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-09-2007, 10:41 PM   #10
mvfd70
mvfd70's Avatar
My 68 has the same key for ignition and locks as well.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 06-09-2007, 10:49 PM   #11
Texas1971
Hmmmm? Come to think of it, my 1967 that I had way back in 1976 only had one key that did everything and I'm certain it was stock. Maybe a bit of "finesse" is in order to get it to turn.
Old 06-09-2007, 11:15 PM   #12
truckdude239
truckdude239's Avatar
my 71 has 2 diffrent keys square for ingiton and round one for doors botha re gm
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-09-2007, 11:16 PM   #13
MrShelley
Too Many Clubs Club
MrShelley's Avatar
I'm in the one key works both camp. My '68 was originally my dads and I still have the original key the dealer handed him.
How I installed my air bags...
MrShelley is offline   Reply With Quote
Old 06-09-2007, 11:22 PM   #14
brak
brak's Avatar
Best bet is to replace the door locks. It's simple, remove the door panel, disconect the lock rod, remove clip, and pull the cylinder out of the door. perform steps in reverse for reinstallation...
if you are gonna replace the locks, you may as well spring the extra 10-15 bucks and get a complete kit. this will give you ignition, door, and glove box, all keyed the same.
I think i paid $35 for my complete set
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 06-09-2007, 11:22 PM   #15
Green Machine
Green Machine's Avatar
One key should run doors and ignition, if not, something has been changed.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-09-2007, 11:31 PM   #16
Sport/Truck
Sierra Grande Club
Seems like it should only be one key. Mine has two though. I should try the PS door with the ignition key, but it’s really worn and don’t think it will work even if it is correct.
Something could have been changed on mine somewhere down the line too. It’s definitely a PITA.
Old 06-09-2007, 11:41 PM   #17
lbpd719
Zappaphile!
lbpd719's Avatar
Count me in the one key camp too..
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 06-09-2007, 11:42 PM   #18
woodrow59
OzarkHillbilly in Atlanta
maybe i'm thinking about cars, but I remember 2 keys, one square, one oval.
Only truck I had that used the same key was the one i bought ignition and door locks keyed the same. I also have a Freightliner lock and key for the glovebox. (ya never know what is interchangable).
72 custom/10 LWB
68 Longhorn C20 Custom Camper (sold)
woodrow59 is offline   Reply With Quote
Old 06-09-2007, 11:57 PM   #19
I got replacement locks keyed for just one key to replace mine. Maybe there was a switch on them as my 70 has the two separate ones and they are the originals, I guess I thought they were all that way cause all my GM cars had the separate door/ignition setup until my 92.
Old 06-10-2007, 12:05 AM   #20
GREASEMONKEY72
fwiw, i can take the key out of the ign with it in the on position and the engine running, ill go out and start her up and lock the doors and go back inside while she warms up
-steven
Alte Seele S.S.
Old 06-10-2007, 12:12 AM   #21
MXmaniac
MXmaniac's Avatar
My truck uses just one key for both. What bugs me is that you can't lock the doors from the inside before you shut the door, because they unlock when you shut the door. My truck has only been on the road for a week so I'm still getting used to those little details.
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
Old 06-10-2007, 12:20 AM   #22
Sport/Truck
Sierra Grande Club
I hate that too.
Old 06-10-2007, 12:24 AM   #23
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
My '72 has one square key that opens the doors, ignition and rear hatch. It is stock.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 06-10-2007, 12:25 AM   #24
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
If you look in the owner's manual(if you have one) at the beginning it states that when the truck was purchased the dealer gives you two keys with the removed "knockouts" and each key works both the doors/ignition. My truck had two keys, door and ignition as the ignition was changed but the Suburban still had it's original locks and one key worked the ignition, front doors, and rear tailgate. In 1973 GM switched to separate keys with the oval key for the doors and the square key for the ignition.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 06-10-2007, 12:32 AM   #25
LockDoc
The Older Generation
LockDoc's Avatar
This thread might answer some of your questions.
http://67-72chevytrucks.com/vboard/s...d.php?t=213860
LockDoc
Leon
