01-11-2011, 10:30 PM | #1 | |
Re: Project Vitamin C-10
01-11-2011, 10:31 PM | #2 |
Daring to be Different
I need to see the whole diagram. Remember that where ever you put that ground it has to be screwed to a non painted surface.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
01-11-2011, 10:32 PM | #3 |
I'm just glad to be here!
The black wire coming out of #9 shows to be grounded at each gauge. Where does the black line go to the right of the gauges in the picture? You cut off that side...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-12-2011, 01:07 PM | #4 |
Alan,
My guess, (without physically looking at gauge cluster), would be that with the ground ending at the tach, the tach is mounted in the clusted making contact with 'bare' metal as will all of the other gauges when also mounted. Attaching the ground wire to the dash frame will accomplish the same completed ground circuit. IMO you're more of a 'Lectro Guru' than you thought. As long as the negative post on the battery is attached to the vehicle's frame, the body is making a good metal to metal contact to the frame and the dash has a metal contact to the body the circuit is complete. I have seen 18 wheelers run several thousand mile before experiencing computor module malfunctions due to painted ground terminals. Like Strodder said...
HAPPINESS IS A COLD BEER, A SATELLITE DISH & QUALITY TIME WITH MY DOG....! |
01-12-2011, 03:34 PM | #5 |
Hey Alan,
When the key is turned on the alternator warning lamp current flows from the power source at the coil through the warning lamp, through the resisters, transistors and field coil of the alternator, then to ground causing the lamp to illuminate. Once the alternator is at full output, voltage from the diode trio, also applied to terminal 1, equals the battery voltage. So, with 12 volts on both sides the of the lamp there is no path to ground and the light goes out. Danny
01-12-2011, 03:43 PM | #6 |
SSN 706
Damn, it sounds good to me. I think he knows he electrial.
01-12-2011, 05:02 PM | #7 | |
01-12-2011, 05:22 PM | #8 | |
1 thing at a time is progress.
Been working on drawing my own schematic for my application. This is pod #1 housing the Gen/Oil and ebrake idiot lights and temp gauge. The QD's will be added to the American wire harness so I can disconnect the individual pods. Am I on the right track?
Alan
Philippians 2:14-16 |
01-12-2011, 05:20 PM | #9 |
A picture says a thousand words:
01-12-2011, 05:26 PM | #10 |
Thanks again. That really helps with a mental pic.
Alan
01-12-2011, 05:34 PM | #11 |
Is this the proper solution.
Alan
01-12-2011, 06:36 PM | #12 |
I couldn't make into work today, so why not stay inside and work on more drawings. It's progress. I just finished the speedo and rt pod schematics. Now just need to tie up the loose ends with an overall schematic with everything hooked to the american wire harness. It's a lot easier than haveing a bunch of wire laying on the floor.
Alan
01-12-2011, 06:38 PM | #13 |
One day...
Inspiring me Alan.. i have to take my last ASE test on wiring would you like to take it for me??
01-12-2011, 07:33 PM | #14 |
SSN 706
Your going to make me go pull my gages out arn't you. I hope it snows like hell in GA.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 01-12-2011 at 07:35 PM. |
01-12-2011, 07:38 PM | #15 |
Another picture....?
In some cases when you try to shut the vehicle off, power from the alternator can feed up to the coil and keep the engine running. To cure this you can install a diode in the ignition wire that activates the #1 terminal. This will stop the power from feeding back up the ignition line. These are buck or two at Radio Shack, just be sure to put the stripe end toward the alternator to stop any flow. Danny aka: Sparky
HAPPINESS IS A COLD BEER, A SATELLITE DISH & QUALITY TIME WITH MY DOG....! Last edited by 66BowTieBoy; 01-12-2011 at 08:42 PM. Reason: spelling |
01-12-2011, 08:39 PM | #16 |
Alan,
I've got a 'BRAND NEW STILL IN THE BOX' American Auto-Wire waiting for me to get off my deadbutt and install it. Are you go'na shame me into being productive....? Sure you can TEE off the brown wire.... If the BROWN WIRE feeds to the coil, then I would put the aforementioned diode between the TEE and the GREEN LIGHT. This will keep backflow from feeding the coil. But, if ya put the diode between the alternator and the Green Light, (and the diode is working properly), the GREEN LIGHT might not go out as it should not receive any positive power from that direction...! At least in theory..... Danny
01-12-2011, 09:48 PM | #17 | ||||
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 01-12-2011 at 09:50 PM. |
01-12-2011, 10:01 PM | #18 |
Is this a great forum or what.
01-12-2011, 10:56 PM | #19 |
Amen Brother!!
OK, I think I have the schematic all done that ties my gauges to the American Wire harness with the needed QD's to enable me to remove the insturment pods individualy. It's all good in theory, until I'm hanging upside down under the dash trying to make it work. I'm thinking I can do most of it on the bench. There is no guarantee that this will work yet. There is still the question of the diode, but that can be done later. It might be confusing but makes complete sense to me. I just want a nice and neat functional harness that people say Wow!! (in a good way) The kids markers came in real handy doing all of this.
Alan
01-12-2011, 11:28 PM | #20 |
Can we start all over I'm confused.........
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
01-12-2011, 11:29 PM | #21 |
Ok Alan,
I got the schematic in my hand, (wine glass in the other), and it would appear that the PINK WIRE powers the ignition coil and the BROWN WIRE goes to the fuse block where ORANGE to Engine Fan, BROWN to AC/HEAT, TAN to accessory connector,as well as TAN to the Radio all branch off. The BROWN from the Alternator runs DOTED LINE to the fuse block where it meets with the BROWN from the Ignition Switch. I would place your GREEN LIGHT in series with the BROWN wire from the alternator without any diode, as the PINK wire feeds the coil and is not conected to the BROWN wire anywhere that I can see.... If you put an Ohm meter on the ignition switch and find the PINK & BROWN terminals are still conected with the key in the OFF POSITION, you should put the diode in the DOTTED BROWN WIRE between your GREEN LIGHT & the fuse block. And if that doesn't work as I claim, I'll cut my Tech Support Fee by 50%, or you can pull my chain...! My schematic looks a little different from what I can see of yours. Mine is part # 500560 'FULL VEHICLE WIRING KIT 1960-66 CHEVY/GMC TRUCK'... Danny
HAPPINESS IS A COLD BEER, A SATELLITE DISH & QUALITY TIME WITH MY DOG....! Last edited by 66BowTieBoy; 01-13-2011 at 12:04 AM. Reason: LAST MINUTE CLARIFICATION |
01-13-2011, 12:29 PM | #22 |
Member of the longbed union.
Alan if your nice maybe Dave will put you a Diode in the mail to you.
Dave I already instaled the diode in the harness that you bought from me. And theres a couple extra in the Purple Pampers box. Alan yes you need to install the Diode. If you go to turn off the ignition power will still feed through and not let the the alt from sending a charge. It's just like putting a check valve in a air system. It's actully funny, with my painless harness I hooked it all up and started up the truck and was wondering why it wouldn't turn off. I guess I didn't see that part in the instructions about the diode. 66bowtie where you from in the hill country?
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 Last edited by ruffrida2005; 01-13-2011 at 12:31 PM. |
01-13-2011, 01:54 PM | #23 |
Hey Paul,
We have a little Bat Cave out here in the Sticks, not too far from 'Pull-My-Finger Texas'. Ya go west til ya smell it, then north til ya step in it.... I could draw you a map, but I think would be a violation of the Witness Protection Program... P.S. I liked your Spinner Hupcap Video and God bless & thank you and your bros for your service.
01-13-2011, 02:04 PM | #24 | |
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
01-17-2011, 07:08 PM | #25 | ||
Alan
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
