Old 07-03-2008, 04:25 PM   #1
panhandler62
Java Mechanic
panhandler62's Avatar
Re: Heavy Chevy -- the penny pinchers rebuild
Oh well... I wanted shiny new ones anyway.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 07-04-2008, 10:20 AM   #2
panhandler62
Java Mechanic
Is ther a special school that previous owners go to in order to come up with ideas like, "It won't fit Earl, let's just tear a new hole until it does!
Keith
Old 07-19-2008, 08:19 PM   #3
panhandler62
Java Mechanic
It's too hot to grind rivets off the frame today so I decided to clean up my tranny cover.
Keith
Old 07-21-2008, 07:08 PM   #4
panhandler62
Java Mechanic
I hope these things are easier (I know it's more complex, but I'm thinking sweat a tude here!) to reassemble than to take apart!
I need to get that other x-member and some other bits off so I can get the frame stiffeners out and restore that area. Whuff.... "Rust Never Sleeps."
Keith
Old 07-21-2008, 07:31 PM   #5
msgross
msgross's Avatar
I had to replace that same "dogbone" looke crossmember. Mine was growing rust like yours. Once it came apart mine had a hole in the frame. I replaced it with a piece of steel and a board member in Arizona sent me a new crossmember.
Gotta love that living rust...
Bet you're getting good with the cutoff wheel and air chisel....
by the way, I replaced all those rivets with grade 8 bolts with lock washers from Tractos Supply. Nice that they have them in bulk... I bet I did nearly 100 total
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-22-2008, 02:20 PM   #6
panhandler62
Java Mechanic
I think I'm going to end up needing about 30 or so. Is it worth melting a bead on the replacement bolts when it's back together, or is lock tight suffcient?
BTW: Are you planning on Carlisle in two weeks? I've been working on the better half about finding some seats... lol
Keith
Old 07-22-2008, 03:36 PM   #7
msgross
msgross's Avatar
I'll be there,,, what kind of seats are you looking for?
I just used bolts, washers, lock washers and nuts. I wish I would have bought nylock nuts but I can always replace some if needed. TSC is pretty cheap for the hardware though...
The Garage:
Old 07-22-2008, 05:24 PM   #8
panhandler62
Java Mechanic
I'm thinking some kind of high back buckets .. not actually an imediate priority though... the interior is at least a year away.
Keith
Old 11-25-2008, 02:43 PM   #9
panhandler62
Java Mechanic
no money.. no sun.. may as well work on cleaning things up...
Keith
Old 11-27-2008, 04:29 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looking good keep up the good work.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-01-2009, 04:23 AM   #11
Wilson_
Wilson_'s Avatar
Any updates??
Is that the HAMMERED paint on the calipers?
Northern California Group
Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby
Wilson_ is offline   Reply With Quote
Old 10-21-2009, 05:30 PM   #12
panhandler62
Java Mechanic
Originally Posted by Wilson_ View Post
Any updates??
Yes, it is. I'll see how it works out. If it flakes off I can always pull 'em and redo them with real brake paint. I mostly wanted to get he patina off after spending so much time cleaning them up. lol
Keith
Old 10-27-2009, 08:44 PM   #13
Wilson_
Wilson_'s Avatar
Thanks, after my hand gets better i plan on cleaning up my rear axle and front suspension and painting it that or satin black.
Old 10-21-2009, 04:15 PM   #14
panhandler62
Java Mechanic
Finally got to get back to the project...
Here is my first box of new toys to show up:
Keith
Old 10-21-2009, 04:17 PM   #15
panhandler62
Java Mechanic
I'm doing a statis drop in front, so I am getting the rust off my springs. The bucket is full of viniger and softener salt, the battery is out of an old lawnmower and the charger is keeping the battery going.
Keith
Old 10-21-2009, 04:57 PM   #16
panhandler62
Java Mechanic
Another delivery truck came by..
Keith
Old 10-22-2009, 09:35 AM   #17
panhandler62
Java Mechanic
The rust removal system works so well that my anode disintegrated. lol... ate the alligator clip on the jumper cables... I had to rig something new up (and make sure that only my sacrificial wrench was in the solution this time) to continue.
Here is the first spring with the rust inhibiter setting. The second spring is in the vat.
Also -- here are the rear springs for comparson purposes.
Keith
Old 10-22-2009, 04:02 PM   #18
panhandler62
Java Mechanic
Springs are all cleaned up now... next step will be to remove a coil.
The rears are not going back in. A pair of Firestone 2600s are taking their place.
Keith
Old 10-22-2009, 06:00 PM   #19
ripdog28
ripdog28's Avatar
You have an air compressor but your getting springs ready?
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 10-22-2009, 06:30 PM   #20
panhandler62
Java Mechanic
The rear is going to sit on air but the front is going to be a static drop.
I'm using 3" drop spindles in the front and shortening the springs.
The rear is getting bagged and a pair of Porterbuilt trailing arms to replace the rusty ones I pulled out.
Keith
Old 10-23-2009, 12:29 PM   #21
panhandler62
Java Mechanic
Another part showed up today. I got this from a bracket racer from the other side of WV for $40.
It's a 750 with vacume secondarys (3310 carb) It's gonna need cleaned and kitted, but I still like the deal.
Keith
Old 10-27-2009, 08:37 PM   #22
panhandler62
Java Mechanic
More boxes showed up today... Firestones and the 3" drop spindles. Just waiting on the intake manifold and the trailing arms and panhard from Nathan.
Oh, you can see I rebuilt and painted that carb too. The truck is going to be a black and orange theme throughout.
Keith
Old 10-27-2009, 08:40 PM   #23
msgross
msgross's Avatar
those look like the firestones I put on my motorhome...
The Garage:
Old 10-27-2009, 11:10 PM   #24
panhandler62
Java Mechanic
They are 2600s and, tell you the truth.. I *am* planning to get another pair of them for the RV later on.. keep it from wallowing around so much.. lol
Keith
Old 10-28-2009, 12:45 AM   #25
VA72C10
VA72C10
VA72C10's Avatar
Good work so far...I'll be following along.
