How about some pics of bagged C-10's
lay it low.[IMG]
![]() Join Date: Jun 2006
Re: post all bagged c10 here
here's one for you
Junior Member
Here is mine
going to sell this one...looking for a SWB project next. |
Commander Taco Bello
my daily driver. 76 days and counting....
Well here is my bagged 10 but it is comming apart as we speak to give life to two other vehicals.
Kevin LFD Inc. |
Texas Big Wig
Noooooooooo, don't take it apart that thing is sweeet !!!!
Heres mine, only bagged in the front but soon in the back ![]() ![]() |
thanks scoti, Stats bagged,stock floor bodydrop, 4 link,4 wheel disc, 12 bolt posi 4.10 gears, two 3/4 hp compressors,four air tanks,FBSS, bed floor raised now 8 inches deep, crate 350/700r4,KMC SS 20x8.5 wheels,245 40 20 front 285 50 20 in the rear. that's some of it later, paul
Epoxy Primer Friendly
Here's mine.
Questionable
more info on wheels and tires (and caps?), what arms and spindles you're using?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#11 | |
![]() ![]() well, i was waiting to reply so i could go out and look to see what size tires i'm running, but i can roughly guess somewhere around a 245-70-15 for the tire. some cheap brand i'm pretty sure. the wheels are your standard 15" steelies with baby moon hub caps and the thinner trim rings. I'm running 2.5" drop spindles and factory arms. out back i have 2.5" blocks, and a notched frame, but the blocks are kinda pointless since the axle hits the frame long before the bag bottoms out. |
heres some more pics
#15 |
On the fast track to nowhere..
I'm a late bloomer, here's a couple more of mine
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
#16 |
![]() Join Date: Aug 2005
Still fine-tuning my levitation device...
#17 |
![]() Join Date: Aug 2006
Hey Frizzle that thing looks SICK!!!! I like it alot!
Here is my project but i am going to be swapping out the frame for a new one once i get it built because i am going to be using a complete c5 corvette supsension, motor and transaxle! Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
#18 |
Heres 2 more
#19 | |
Texas Big Wig
A link to your photobucket will suffice ![]() |
#20 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
heres mine........................
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#21 |
heres some pics of my rear set-up. just a kp notch and a suicide doors superlift 4 link.
#22 |
Heres mine so far.....
![]() Heres the rear suspension... minus the air valves there going on the tanks.. ![]()
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
#23 |
Junior Member
Here's mine. Sorry no new pics. Truck is @ Stoked Out getting some mods done. I think N2TRUX may have a newer pic
#24 |
the front is just the suicide doors front kit and i cut down the cups. i hate to say it but the front is all the way down and is sitting on the inside edge of the fender. i think i'm going to cut the fenders to see if it will go any lower.
#25 |
Anyone else think it's funny that not too many of us have "complete" bagged C10s
