Old 01-02-2003, 06:50 PM   #1
Blue_71
Bloo
Blue_71's Avatar
how to mount the bottem of a short water pump alt?
i know how to hook it to the top bracket, now how do i hook up the bottem??
the only thing i can see is bolt it to the exhaust pipe but i just cant see doing that.... which head bolt hole does the top alt bracket go in?
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 01-02-2003, 07:38 PM   #2
crazy longhorn
Fabricate till you "puke"
the trucks had a small cast bracket that mounted to the head, & the alt bolted to that.....i beleive that was 68-72(the 67s didnt have the accessory holes in the head, & used a stamped brackets like the cars had).....maybe somebody has some pics
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-02-2003, 08:23 PM   #3
neonlarry
neonlarry's Avatar
My stock bracket goes in both of the wholes in the head. I really don't like it though, and I am ordering one of these tomorrow.
From www.alangrovecomponents.com.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-02-2003, 08:35 PM   #4
Blue_71
Bloo
Blue_71's Avatar
ive got the top bracket that you adjust it with, but i cant find one for the bottem anywhere.... it looks like it must bolt straight to the end of the rams horn (theres 2 holes in it)
this pic of the old 305 shows how the top is mounted
Old 01-02-2003, 08:43 PM   #5
Desert Rat
Desert Rat's Avatar
69-72 have a cast iron lower that bolts into the front holes in the head,if you have early heads they dont have these provisions,aftermarket may not either.then the stamped steel adjustor.the 69 up trucks didnt use the bracket that bolts into the exhaust manifold.i have truck,car,style brackets available if needed,the style that bolt to side of manifold,and the kind that bolt to the front of manifold,and the correct truck ones.Im going to ebay them all soon,let me know if theres a certain kind you need.email me.
Desert Rat is offline   Reply With Quote
Old 01-02-2003, 08:47 PM   #6
jabarlow
the alt bracket in the bottom picture is from before the heads had mounting holes and will not work with heads with the mounting holes
72 Chevy K10 Short Stepside
72 gmc K2500
jabarlow is offline   Reply With Quote
Old 01-03-2003, 12:05 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
josh, here is where the bolts go...
And it'll look something like this...
I can't place it on there quite right since my truck has the later style brackets. My steering pump is in the way.
Old 01-03-2003, 04:39 PM   #8
70 longbed
Blue 71,
I have a great picture of the bracket and setup, took it so that I knew how to put it back together on my "70. The file is to big (800K) to post here. if you want I can send it to you direct if you have a high speed internet connection.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 01-03-2003, 05:53 PM   #9
Blue_71
Bloo
Blue_71's Avatar
i totally dont have the right set up then.... mine didnt have that bottem bracket... i have a 1 bolt top bracket and no bottem bracket i can find...
70 longbed, i would apreciate that pic
mlbunch@scrtc.com
Old 01-03-2003, 05:54 PM   #10
Blue_71
Bloo
Blue_71's Avatar
whoa woops wait you said high speed, i just have 56K dail up
Old 01-03-2003, 07:21 PM   #11
bigjimzlll
bigjimzlll's Avatar
longhorn ail isnt that a brkt for a long water pump? Mine bolted to the rams horn..had a heck of a time finding one to work with a short water pump..had to go to alan grove for a really cool brkt
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-03-2003, 07:51 PM   #12
crazy longhorn
BigJim, Im the other longhorn(the crazy one!), but that is a bracket for the short pump alt. If you didnt have the acc bolts in the heads, you needed a stamped steel bracket that bolted to the waterpump & ex manifold. Desert rat had the yrs right on (69-72) on the cast bracket. the stamped bracket was older, but mounted the alt in the same position(just had a boss on the end of the manifold that the later manifold didnt have). the same set up that Longhorn pics on , is in my kids ranger(Ferd with a SB Chev).......the only way to do a ferd
Old 01-03-2003, 07:58 PM   #13
bigjimzlll
bigjimzlll's Avatar
my badd....its been so long since ive seen a stock brkt it threw me off.
Jim
Anderson,CA
Old 01-03-2003, 08:22 PM   #14
crazy longhorn
Jim, I have73 up stuff on my longhorn, so have to think about the old stuff a little also! The kids ranger is stiill fresh in my mind(sorta)......it was only a couple yrs ago that I did that swap. the power steering pump bracket would make a preacher cuss tho, the pump is on the pass side
Old 01-03-2003, 09:35 PM   #15
Blue_71
Bloo
Blue_71's Avatar
woo hoo!!! i dont have the right bracket, but i found one in my pile-o-junk that fit the holes in my rams horns and worked with the alt, i style wish i knew what i did with the correct peices though, now i need a huge (IMO) belt
Old 01-03-2003, 09:44 PM   #16
crazy longhorn
Old 01-04-2003, 12:46 AM   #17
Longhorn Man
Josh...I just got done painting that bracket y0u see in the pic...top piece too. It won't bolt to the caddy no matter how hard I try.
Whats it worth to you?
Old 01-04-2003, 12:49 AM   #18
Longhorn Man
Then you'll be abl to install headers.
Old 01-04-2003, 12:52 AM   #19
Blue_71
Bloo
Blue_71's Avatar
dont really know man, after rebuildign this thing i dont have much $$ left, you need any parts for the longhorn that i may have? i wont really know on the money sit. for probably a week or so, im trying to sell some stuff
Old 01-04-2003, 12:54 AM   #20
Blue_71
Bloo
Blue_71's Avatar
also--- where does the top bracket bolt onto? mine bolts in one of the head bolts where your bottem bracket goes
Old 01-04-2003, 01:15 AM   #21
Longhorn Man
My upper bolts on the same way.
I'm int he same boat your in...tryin to get some $$ up for my truck.
Can't think of anything you may have that I need.
Old 01-04-2003, 01:23 AM   #22
Blue_71
Bloo
Blue_71's Avatar
ive got a 6 cylinder im selling, told the guy $100 and he said he'd think about it, i hope he buys it!!! that could get these things going i think
so how much you wanting? ill make sure to write it down and try to save that much if i can
Old 01-04-2003, 01:25 AM   #23
Longhorn Man
dunno what they are worth. make me an offer...I'll bump it up another 10 bucks
Old 01-04-2003, 01:28 AM   #24
Blue_71
Bloo
Blue_71's Avatar
make an offer and youll bump it up 10 bucks huh? hmmm, ok hows about uuh
$ 0.50? hehehe
Old 01-04-2003, 02:07 AM   #25
Longhorn Man
lol!
