Old 02-12-2008, 11:13 AM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good Blazer...
Started dorkin' w/ the rear brakes. Spent most of my time tearing everything apart and cleaning/painting. I figured it was a good time while I was in there to replace bearings/seals.
I am using Glock's brackets, but for whatever reason they are not a 'bolt-on' for me. The bolt heads for the caliper bracket hit the rotor, even after switching to the smaller diameter allen head bolts. The spacing is about 1/2" off from aligning the rotor/caliper correctly. I think my axle/flange spacing is off a little from a 2wd axle, so I will have to modify them to work for me. The last pic is just a mockup showing what they could look like...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-13-2008, 03:12 AM   #2
Frizzle Fry
Frizzle Fry's Avatar
Originally Posted by gringoloco View Post
I am using Glock's brackets, but for whatever reason they are not a 'bolt-on' for me. :
Those don't look like the same brackets. You may have the Caprice brackets there. Those look like camaro calipers...?
Frizzle Fry is offline   Reply With Quote
Old 02-17-2008, 04:48 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Impala brackets and calipers. Looking at a pic from Ram-Man, it looks like he had the same problems I have. Note the nut between the backing plate and caliper bracket. I think I can weld nuts to the backing plate serving to both align the caliper correctly and eliminate the rotor/bolt interference. Oh well, tear it down and try again...
-Chris
Old 02-12-2008, 01:51 PM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Bummer... But still SWEEEEEEET !!!
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-17-2008, 10:29 AM   #5
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Just keep swim'n, just keep swim'n...
Sinister
Killer
Old 02-21-2008, 10:13 AM   #6
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Any new progress to report?? Just checking in to get more motivation.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 02-21-2008, 11:05 AM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Nope. I've been occupied getting the bike and Sea-Doo ready to play(Yep- it's already spring in Louisiana) as well as getting the parts together and in powder to bag my pickup(Yes, I have a sickness.)
My love lies waiting silently for me... Looks like she's been sippin' the cervezas while I'm away too
-Chris
Old 02-23-2008, 08:20 AM   #8
jkade
jkade's Avatar
No busch for her
jkade is offline   Reply With Quote
Old 02-23-2008, 08:27 AM   #9
babyblueoval
babyblueoval's Avatar
Originally Posted by jkade View Post
No busch for her
Oh, that's bad.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 02-22-2008, 02:19 AM   #10
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Looking good Gringo! Don't you LOVE this weather!!!
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 02-22-2008, 06:12 AM   #11
gringoloco
A guy with a truck
gringoloco's Avatar
Temperature is great, just wish it would stop raining for more than a day at a time...
-Chris
Old 02-29-2008, 09:40 AM   #12
gringoloco
A guy with a truck
gringoloco's Avatar
I did some trading with a boardmember(thanks Shifty) for a mildly used ECE tubular transmission crossmember. I immediately put together plans to hack it to pieces to fit my needs. Unfortunately, ECE uses an oddball size rectangular tubing I could not find locally, so I had to wait for the stick I bought to be delivered.
I started by screwing it down to a piece of 2x6 to keep everything aligned. I then sectioned out the center, with the crossmember flipped upside-down. I made filler pieces out of the 1.5" x 2.5" .120 wall rectangular tubing. After squaring everything up, I welded and ground it smooth. Turned out pretty nice, me thinks...
This will put the tailshaft in the proper position for the Dropmember and allow me some clearance for exhaust tubing. I've got plenty of tubing left over- I think I'm gonna build one from scratch for my pickup.
-Chris
Old 02-29-2008, 10:11 AM   #13
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Thats SWEET !!!
Sinister
Killer
Old 03-01-2008, 10:02 PM   #14
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by Spray-Bomb View Post
Thats SWEET !!!
Thanks! Here's a couple pics of the finished product. You can see that the transmission mounting surface is about 1" higher than stock. Also, the new crossmember does not hang below the framerails at all- the stocker hangs about 1.5" below. With that and the increased exhaust clearance, I'd say this little project is a success...
-Chris
Old 03-01-2008, 10:10 PM   #15
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Cool !!!
Sinister
Killer
Old 03-20-2008, 01:26 AM   #16
randomhero472
randomhero472's Avatar
Havent been on in a while, this thing is turning out amazing.. keep it up man, awesome job!!!
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 03-21-2008, 09:03 AM   #17
1lo67
1lo67's Avatar
I love it, i want one of the PB members for mine, just to many irons in the fire. your ride hight is just sweet. great job. cut it up it feels good
1lo67 is offline   Reply With Quote
Old 03-21-2008, 06:19 PM   #18
bama51
Thumbs up Re: How to: Ruin a perfectly good Blazer...
Don't mean to hijack this thread, but DANG, your ride's sweet, too, 1lo67!!!
bama51 is offline   Reply With Quote
Old 03-23-2008, 04:58 PM   #19
bagged74
its just $$$$$
bagged74's Avatar
isnt that the blazer that board member slogo built?
bagged74 is offline   Reply With Quote
Old 03-23-2008, 06:05 AM   #20
jlaird
jlaird's Avatar
gringo, Ive got that same crossmember but its from performanceonline.com Why did you need more exhaust clearance? isn't there plenty of room to run it above the x-member? Also, why did you move the mount 1 inch up? I wasnt planning on hacking this thing up.
jlaird is offline   Reply With Quote
Old 03-23-2008, 07:32 AM   #21
Rokcrln
Rokcrln's Avatar
I belive he did it because the DropMember moves the engine up so the tranny needs to move up as well.
Not sorry, this is a full on Hijack!
1lo67 we need more info on your ride. That thing is sweet! Would you mind sharing some pics of your hinge set up and rear latch?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-23-2008, 07:32 PM   #22
abadsvt
abadsvt's Avatar
Looking real good Gringo! Keep up the great work.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 03-23-2008, 07:46 PM   #23
Hart_Rod
Hart_Rod's Avatar
Looking real good! Now all you need is a set of these..........
Hart_Rod is offline   Reply With Quote
Old 03-24-2008, 03:34 AM   #24
gringoloco
A guy with a truck
gringoloco's Avatar
Going under gives a straight shot for the exhaust pipes from the collector through the trailing arm crossmember- I'm building a mandrel bent exhaust and didn't like having all those bends right after the collector. Just personal preference- you don't have to hack it, I just prefer it this way. I moved the tranny mount up 1" to match the Dropmember engine mounting position. It is a little higher to clear the rack...
This is Hart_Rod's pic, but it illustrates why I modified my crossmember:
Yep. That's even slogo's pic...
Josh
Thanks Josh! Yours too.
Or two...
-Chris
Old 03-24-2008, 06:27 AM   #25
Hart_Rod
Hart_Rod's Avatar
Gringo,
I think it will clear the stock ECE tranny mount without any bends. Here's some better pictures from the rear.
R/
