Old 11-03-2007, 12:07 AM   #1
xshadow
what gear ratio do you run or would like to have
What gear ratio are you running, or what would you like to have....and why do you want to go with that ratio?
xshadow is offline   Reply With Quote
Old 11-03-2007, 12:27 AM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: what gear ratio do you run or would like to have
Gear ratio for what? All around, racing, highway, or pulling/towing? Not being smart, just wondering what you are wanting to know.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 11-03-2007, 01:16 AM   #3
brak
brak's Avatar
3:73 for me
just enough low end, and the overdrive on my 700-r4 should make up for any loss in top end.
Best of both worlds.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 11-03-2007, 01:48 AM   #4
68K20 x Drill
I went from 4:56 to 4:10, and its nice now to get all the way across an intersection before having to shift.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 11-03-2007, 06:57 AM   #5
For road use and light hauling these days I`d take a 3.08 with no o/d.If I have o/d,I like 4.10,but 3.73 would do.I like pullin`gears,but these days we need to squeeze all we can from the gas.A 3.08 will get you up and free-rollin`easy with the power these trucks have and is the single cheapest/easiest way to get economy.I think it`s too high for o/d,though.With o/d I wouldn`t want higher than 3.42s,but I`d want a torquey motor.3.73s will keep you in o/d with ease and give the best hiway cruisin`.
Old 11-03-2007, 08:01 AM   #6
WorkinLonghorn
WorkinLonghorn's Avatar
I currently have 3.73.No overdrive,31" tires and I can live with the 3.73s but I usually cruise at 60 MPH which means I'm pretty much a traffic hazzard and have to hug the right lane on the freeway.For pulling a heavy load,3.73 is just right.But if I'm empty then 3.08 would be better cause I could actually use my 4.56 low gear instead of starting out in second (2.28-1).Either way is no big deal,If I'm in a hurry and cruise at 70 MPH or even 75,my sbc is singing a sweet song and with the short stroke,I don't think it hurts anything.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 11-03-2007, 09:09 AM   #7
chris71
chris71's Avatar
i had a 3.73 with a 700 r4 overdrive, and man that was sweet, nice low gear off the starting line but had the nice high gear for the high way. i did some rough calculations and with the 3.08 first gear of the 700r4 and the 3.73 rear it is similar to having 4.56's with a turbo 350 (in first gear), but i could tool down the highway at 70-80 in 4th gear no prob. my 700 blew and i replaced it with a th350. i feel that the 3.73 are too low for me now with 28" tires for the highway so i bought a 3.07 posi. i should be good to go on the highway and for economy.
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 11-03-2007, 09:42 AM   #8
dave2953
Dave's not here, man
dave2953's Avatar
I have a 3.73 in my truck. I am looking to get a 700R4 so my Powerglide can take a much needed break.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 11-03-2007, 09:56 AM   #9
Shyguy
Junior Member
Shyguy's Avatar
I have a stock 350 with a granny low 4 speed and 3.73 gears with 31" tires and have found for what I use my truck for the 3.73s work fine.
I use it for farm work and running into town for supplies so I am not worried about mileage.
My son has a mildly modified 350 with a 3 speed and 3.42 gears. He drives a lot faster than I do and uses his truck for burnouts, cruising, and occassional trailer pulling.
I am a little long winded to end up saying it depends on what you use your truck for.
Danny - Southeast Missouri
Shyguy is offline   Reply With Quote
Old 11-03-2007, 10:57 AM   #10
piecesparts
Parts and more parts
piecesparts's Avatar
Originally Posted by brak View Post
3:73 for me
I run a 3.73 in my weekend cruncher and it also has a 700 R4 tranny. I get 15 MPG with a 383 stroker, carburated motor and can bite hard on the streets when needed. I run a little smaller tire than some, but the truck is lowered and it puts my RPMs around 2500 for 70 MPH cruizing. Anything lower would work the engine and the cruise control to much. ( I live where there are hills)
My daily driver has a 5.7/700R4/ 3.42 gear ratio and it is not bad on acceleration, but tends to be somewhat enemic compared to the 3.73s. The gas mileage on the daily driver is around 20 MPG, but it is also a TBI motor. The RPMs at 70 is around 2250 and it works fine overall. Both trucks are lowered and I run the same size tires on them, so the RPMs are comparible to the difference in the rear end gearing.
Old 11-03-2007, 11:22 AM   #11
Classic69
Love That '69
Classic69's Avatar
My '69 has a SBC 283/TH350/4.56's/235/75-R15 tires. It takes off the line pretty darn good. It's a show truck/cruiser so I don't do any hauling with it. On the highway at 70 MPH it cruises at about 3900 RPM's. I get about 12-14 MPG combined. The 4.56 gears are what came with the truck when I bought it 12 years ago. I swapped the 283/th350 combo into it.
I AM CANADIAN!!!!!
1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights
2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates
Classic69 is offline   Reply With Quote
Old 11-03-2007, 03:36 PM   #12
JAKES 68GMC
Aluminum slot wheels rule...
I think I've got 4.10's, but I'd like some 3.73 or maybe even 3.55 gears. My truck cranks at anything above 50mph.
JAKES 68GMC is offline   Reply With Quote
Old 11-03-2007, 05:08 PM   #13
bad6772
Official Site Guitar Shredder
bad6772's Avatar
i run 4.56s in the 72 ...And im looking to change it....lol it sucks the gas......bad...........
bad6772 is offline   Reply With Quote
Old 11-03-2007, 05:24 PM   #14
chevy72blu
chevy72blu's Avatar
3.73 with a 28" tall tire (no OD) is fine for a DD as long as you arent spending a ton of time on the freeway. Even if you are... run it 55-60 and take the extra 2-5 minutes to get there.
3.73 are the best middle of the road performance/driver gear IMHO. If you dont have an interest in racing it, go with a 3.55 or slightly lower.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 11-03-2007, 05:44 PM   #15
lilred67
lilred67's Avatar
my dd has 3.42's w/350 & 4l60e and i have found this to be my favorite combo. it gets good milage and pull decent as long as it is drive(no od).i'm changing the rear end in my '67 out to a 3.08 just because i have one, but my plans are to re-gear the original rear end to 3.42's w/ 350/sm465 tranny.
lilred67 is offline   Reply With Quote
Old 11-03-2007, 06:26 PM   #16
cdowns
cdowns's Avatar
well when at the gas pump filling the tank i wish i had a 2:73 sittin at a stoplight next to a blowmaster type guy i wish for 4:11
Old 11-03-2007, 07:17 PM   #17
bucky_21_7
bucky_21_7's Avatar
I have 3.08's but my first gear in my saginaw is like 3.54 i think so first gear is supper high makes it feel like 4.10's or 4.56. Realy good for burning rubber but not so good for gas milage. But my Power mec teacher has the exsact same tranny with same ratios in it and he said he had 3.73's in his 58 bel air but he said it was bad because there was barley a first gear so he went back to 3.08's
bucky_21_7 is offline   Reply With Quote
Old 11-03-2007, 08:47 PM   #18
clay68c10
clay68c10's Avatar
I've got 3.07 now and with a th400 I like it, 70 mph is around 2600 rpm. If I had an overdrive, I'd change to 3.55 to get good low & top end.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 11-03-2007, 08:51 PM   #19
Ace in the hole
I have 4.56 right now, wouldn't mind 3.73 though.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 11-03-2007, 08:53 PM   #20
Texasdeere
Texasdeere's Avatar
I have a 3.07 rear with a TH400, 402BB. I like it.
If I had 3.73s, I would put in a TH700R4. That would be better on both ends.
Texasdeere is offline   Reply With Quote
Old 11-03-2007, 09:45 PM   #21
wibilly
wibilly's Avatar
i have 3.73 in my driver and love them but overdrive would make them even better. for now i'm running 31"tires that helps. cant wait to find a nv4500 if i don't by spring i'll probably go with 3.08's cause if i have to tow somthing real heavy i have 4.10's in my 71
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 11-03-2007, 10:18 PM   #22
pdr510
Junior Member
pdr510's Avatar
3.73 with a 4L60E tranny works good for me.
1970 C-10 Fleet Side
Gen IV 6.0 with 4L80E
pdr510 is offline   Reply With Quote
Old 11-03-2007, 10:18 PM   #23
Ryan Hubbard
I have a 3.55 gear in my Dana 60. I am running a blown 350 with a turbo400. I can cruise the freeways in SoCal with no problem and still tow easily because I have 500 lb ft of torque.
Regards,
Ryan Hubbard
Ryan Hubbard is offline   Reply With Quote
Old 11-04-2007, 07:48 AM   #24
Note:Just a reminder
Truck 12-bolt rears had 3.08:1 ratio available.
There was also a 307 cu.in. SBC available.
No 308 motors and no 3.07 gear in trucks.
Old 11-15-2007, 10:34 PM   #25
nates70lwb
4:10's man, who cares about gas mileage its an old hot rod truck, I just want to get in it and burn the hell out of the tires...
nates70lwb is offline   Reply With Quote
