Old 11-23-2007, 01:00 PM   #1
70' GMC
HERE.......Somewhere
70' GMC's Avatar
Question the metal thats behind kick panel
I just went outside to vacuum the truck out and it the metal behind the kick panel and its rusty at the bottom pretty badly so what is the metal called or is it replaceable
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 11-23-2007, 02:30 PM   #2
70' GMC
70' GMC's Avatar
Re: the metal thats behind kick panel
whats it called
Old 11-23-2007, 02:59 PM   #3
dfosh
If what your looking at in side the cab is rusty , that is the kick panal. Their is a replacement panal for that.It is abot 9'' high and fits to the floor. You will have to cut it out to weld in the new one. it is spot welded alone the door flange and also to the a piller in the center of the panal and to the floor . hope this helped.
dfosh is offline   Reply With Quote
Old 11-23-2007, 03:13 PM   #4
raggedjim
raggedjim's Avatar
Here's some links that may help
Good luck, Rg
http://67-72chevytrucks.com/vboard/s...d.php?t=185885
http://67-72chevytrucks.com/vboard/s...d.php?t=219668
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is online now   Reply With Quote
Old 11-23-2007, 04:55 PM   #5
whatnow123
whatnow123's Avatar
Not to be the bearer of bad news, but if the inside of the kick panel is that is rusty, there probably is more in the door pillar as well as the rocker. I thought that was all I had as well.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 11-24-2007, 12:04 PM   #6
raggedjim
raggedjim's Avatar
Yeah, I when I hear people say "it only needs rockers" I always think "wait until you get it off..."
Roger
'70 GMC Jimmy 2wd
Old 11-24-2007, 05:05 PM   #7
john@thepier
john@thepier's Avatar
Been there done that a few times. raggedjim you could not have said it better. Even if the rocker looks good, it aint, to do it right your going to replace the bottom of the pillar and a piece of the inner rocker and a piece of the floorboard as well as the bottom piece of kick panel. I would only cut out what you need to!!! fit the replacement pieces buy cutting them to what you've removed. Replacement rockers need to be fit also. to make it nice you may want- need sand blaster, all 3 welders Tig/Mig and a resistance welder to give it the factory spot weld look. I coated all the back sides of my work with panel bond adheisive, should last well longer than me. I'll post some pictures in a day or so to show you what I'm talking about. OH and my first and second trucks were 70 GMC's cool trucks JOHN
john@thepier is offline   Reply With Quote
Old 11-25-2007, 07:56 AM   #8
70' GMC
70' GMC's Avatar
is hard to install and what do like take the old rusty metal and put in the new piece of metal
Old 11-26-2007, 02:40 PM   #9
70' GMC
70' GMC's Avatar
how would you do it and where do you get them
Old 11-26-2007, 03:21 PM   #10
heavy71chevy
heavy71chevy's Avatar
any of the board vendors and lmc all have them
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 11-26-2007, 07:20 PM   #11
john@thepier
Here bare pics as promised, My work is a little over kill but it makes me happy notice how the rocker looks perfect, it wasan't
Old 11-26-2007, 07:25 PM   #12
john@thepier
more of the pillar and kick panel
Old 11-26-2007, 07:34 PM   #13
john@thepier
More pics including some of the other things we work on here at my buddy TIm's shop "THAT'S AUTOBODY" in Richmond, Ill.
Old 11-26-2007, 07:42 PM   #14
john@thepier
Just a few more of the repair areas. I coated all the bare metal under and behind the rocker literally gluing the rocker on prior to spot welding making this job permanent never to rust again. Also notice how I fit the cab corners to the rockers by pie cutting them and welding them back together for that finished look!! John
Old 11-26-2007, 09:32 PM   #15
70' GMC
70' GMC's Avatar
John@thepier do you do body work or something cause you have lots of em
Old 11-26-2007, 09:34 PM   #16
70' GMC
70' GMC's Avatar
john@thepier is that new or original cab corners. so if you buy them are they the exact gauge im not talking bout the cab corners but the kick panel doo dad.
Old 11-26-2007, 09:37 PM   #17
clemson71guy
clemson71guy's Avatar
nothing aftermarket is the exact same as it was orignal
and its only easy to install if you know what your doing and how to to it.
clemson71guy is offline   Reply With Quote
Old 11-26-2007, 09:55 PM   #18
john@thepier
They are the original cab corners. It was easyer and a much better job to cut and fit the cab coner than to modify the rocker. Also the natural curve of the body line made it necessary. The kick panel replacement was heavier than stock material, also was the pillar and rockers. No its not easy to do but it is fun and for someone like me that wants 0 rust and a restoration that will look good for a long time its well worth the effort. Once I have the entire cab media blasted you will be able to see the very clean and neat job that was done. I know it looks messy now. I'll post some pics then.
Old 11-27-2007, 09:47 AM   #19
70' GMC
70' GMC's Avatar
so where did you get the metal at for the kick panels
Old 11-27-2007, 10:19 AM   #20
john@thepier
I buought my replacment panels from GMC PAULS He is a vender on this site.
Old 11-27-2007, 08:36 PM   #21
70' GMC
70' GMC's Avatar
does he have a magazine?
Old 11-27-2007, 08:48 PM   #22
clemson71guy
here is the website
http://www.gmcpauls.com/
Old 11-27-2007, 09:05 PM   #23
tcb-1
Nothing to see here.....
tcb-1's Avatar
do you have/know how to weld??? if not, you better be trying to make friends who do.....
tcb-1 is offline   Reply With Quote
Old 11-27-2007, 09:22 PM   #24
70' GMC
70' GMC's Avatar
good idea. cause I dont have a welder I need to see if I can take welding next semester.
Old 11-27-2007, 09:28 PM   #25
clemson71guy
well if you dont know how to weld then this aint a good place to pratice
my first weld was welding a go-cart floor back to the frame when i was 13
my 2nd weld was welding half the floor back in my truck abour 2 months ago
and i still havet got the hang of it yet...so welding aint something you learn to do overnite
but if you think you can do it then go for it
