Re: Project 7deuce
Sofa King Crazy!!
Re: Project 7deuce
They do. Four headlights!!
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
Re: Project 7deuce
Isn't Hot August Nights this weekend? Did you make it?
74 C10 LWB 350/T5 Dropped on 20's Soon to be Bagged and Injected 84 C35 Crew Cab Dually. 454/400 Dropped a lot. Instagram: mmmdropp |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: Project 7deuce
Its not 2012 yet and yes hot august nights is this weekend...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Re: Project 7deuce
Yeah I don't know why I read that as 2011, but apparently I did. I'm hoping to roll my 74 square on the Powertour in 2012, since I don't think the squares are welcome at Hot August Nights yet.
She's comin along man! Almost makes me want to build a 67-72
PROJECT 7DEUCE
Re: Project 7deuce
Been busy on the truck and some other misc projects and heres some pics....Got my new bed end cap installed just needs to be welded together it ook forever to get all the body lines straight...Next work will be getting the crease out of the bedside and then on to the back cab wall that was pushed in.. Next time Im just going to get a new bedside as it would have been a whole lot easier.
PROJECT 7DEUCE
Re: Project 7deuce
Getting this panel to line up right was a pain in the ass to say the least.. I sanded off all the paint and bondo off both the bedside and taillight cap. I then measured about 5000 time and cut very little off at a time untill it fit somewhat good..
PROJECT 7DEUCE
Re: Project 7deuce
Just some random shots of getting her in the final resting place..
PROJECT 7DEUCE
Re: Project 7deuce
Some of my cuts are not very straight but it gets the job done.. I 1st started out by tack welding to the tailgate and then got out my fancey harbor freight body alignment clamps and went to town....
Re: Project 7deuce
I want that hood set up....
My build thread for Project TiC TaC/Jazzmin Oh Yeahhh Cheap work is never good and good work is never cheap. Lesson = learn to do it all the right way on your own. ![]() SqueegeeMan |
Sofa King Crazy!!
Re: Project 7deuce
You are a better man than me, I would never attempt that! It is looking good though! I need to swing by this thread more often.
Re: Project 7deuce
looking good. i need to repair the same area on my passenger side.
Re: Project 7deuce
I can see now there isn't nothing you can't accomplish, and not enough is said of somebody that just tackles a job and gets it done no matter how hard it might seem.
I'm sure your enjoying the process.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
Re: Project 7deuce
This is one sweet build, the works looks amazing!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
#15 |
PROJECT 7DEUCE
Re: Project 7deuce
Thanks guys the bedside is almost ready for mud work but I am still hammer and dollying the metal the get it as straight as possible.. Looks for updates today...
#16 |
Still Learning
Re: Project 7deuce
Very nice work sectioning the bedside! That takes some skills to get it right. Looking forward to an update.
#17 |
Re: Project 7deuce
WOW..I think the sayin of "You ain't skeered" fits here!
#18 |
PROJECT 7DEUCE
Re: Project 7deuce
So I'm a little late with the updates had a huge party at the house last night. So I didn't get as much done as I wanted to but here we go.. The e fans went in for the last time used all stainless hardware and some double sided foam that was sticky on one side and soft on the other. I used this to form a cushion between the fan shroud and radiator. I gotta thank sams60gmc for helping me make the shroud months ago.. You can see how dirty my engine compartment is from other work going on in the shop so I have detailing the motor back out on my list of things to do.. You can also see my sorry ass power steering lines that need to be addressed asap..
#19 |
PROJECT 7DEUCE
Re: Project 7deuce
Finally found the chevy only sticker and threw it on thanks dino... While I was shopping for stainless bolts I figured what the hell the powersteering box looks like she could use some bling so i picked up some stainless cap screws to help it tie into the rest of the engine compartment.
#20 |
PROJECT 7DEUCE
Re: Project 7deuce
Amost there...
#21 |
PROJECT 7DEUCE
Re: Project 7deuce
I replaced my nasty looking motor mount stand bolts with these stainless cap heads.
#22 |
PROJECT 7DEUCE
Re: Project 7deuce
Old power steering lines replaced with custom made stainless lines from frankstrucks up in Washington...For 100 bucks these things are sweet and they polish out real well..
#23 |
Still Learning
Re: Project 7deuce
#24 |
Under Construction
Re: Project 7deuce
Nice work, and progress... keep at it....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#25 |
![]() Join Date: Mar 2011
Re: Project 7deuce
Moving right along....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
