11-24-2007, 07:12 PM | #1 |
Grease Monkey
Lifting my 72' K20
1972 Chevy Cheyenne 3/4 4x4
Custom 12" Lift Kit Whiplash Springs ProComp Shocks ProComp Brakelines Superlift Hardware Custom Crossover steering OEM 2WD Steering Box Ford 4WD Pitman Arm Custom DOM Tubing Tie Rod with Hime Joints Passenger Steering Arm ProComp Dual Steering Stabilizer Wheels & Tires Mickey Thompson Classic II 17x9 8 Lug Interco IROCK Swampers 39.5x13.5x17LT Before: During: That is where it sits for now. Tomorrow I will finish lifting the front. Then the steering. Have a great Turkey Day!! |
11-24-2007, 07:31 PM | #2 |
Re: Lifting my 72' K20
wow those springs look beefy, thats what i call going from mild to wild in a short time, yall dont have any lift laws in cali? anyways becareful working under there and enjoy your new hi life, looks great
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
11-24-2007, 09:13 PM | #3 |
Ridin',looks good.Is there any advantage to running the 4x2 steering box,or is it required for the crossover steering?
11-24-2007, 09:40 PM | #4 | |
Grease Monkey
It is required due to having to rotate your pitman arm 90 degrees.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
11-25-2007, 12:06 AM | #5 |
K5Camper
Looks awesome! The 2wd box is needed when using x-over steering. The stock 4wd box swings front to back, where as the 2wd box swings side to side.
Since the point of x-over steering is to have the drag link connect to the pass side knuckle, the only way to do it is with a 2wd box swinging side to side.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
11-25-2007, 04:31 PM | #6 |
Looking great - haven't heard of those springs yet. Will look forward to hearing what you think of them.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
11-25-2007, 05:01 PM | #7 |
Aluminum slot wheels rule...
looks great, makes me want to lift my truck.
11-25-2007, 06:10 PM | #8 | |
BTW your truck looks AWESOME!!!!!!!!! -Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
11-25-2007, 11:20 PM | #9 |
Grease Monkey
Update...
My Dad and I finished putting the top of the motor back together this morning (had blown head gaskets). I also bought new grade 8 bolts for the leaf springs. So this is where I am tonight... I got the front suspension all ripped apart... This last is just to show how high the truck is! Holy crap it is tall, I didn't even realize it until I saw the picture. I'm 5'8". Just in case you are wondering, the cross member is 27" from the ground. Still legal!
11-25-2007, 11:46 PM | #10 |
Guess it won't be going into the garage any more..
11-26-2007, 09:34 AM | #11 |
wow...what a difference.... looks good...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
11-26-2007, 10:02 AM | #12 |
KEEP ON TRUCKIN'
Looks good with the lift. Keep us posted.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
11-26-2007, 09:08 PM | #13 |
Grease Monkey
Josh (brother-in-law) and I finally finished the front today. Man does it look great. It sits at 27 3/4" from the ground to the cross member.
I still have the steering to do, including the steering stablizers, and torque everything.
11-26-2007, 11:09 PM | #14 |
Looks way cool.
11-26-2007, 11:22 PM | #15 |
KEEP ON TRUCKIN'
Looks real good sitting way up in the air.
11-27-2007, 12:13 AM | #16 |
sweet jesus that looks good!!!
i found the whiplash website...did you use the 73-80's 12" kit or have some custom springs made? did you have to do any modifications to the frame, or anything else, to get these to fit?
1970 C20 now a K30 1986 3+3 Dually Last edited by Matt72blaze; 11-27-2007 at 12:19 AM. |
11-27-2007, 01:46 AM | #17 |
Grease Monkey
I did use the springs from the 73-87's 12" kit, but they were custom springs. Whiplash normally runs an 8" spring and 4" block in the rear. Robert at Whiplash hooked me up with some custom 12" rears that were 4-5" shorter. 73-87' springs are 49" long where 67-72' are 42"long. The shackle took care of the extra few inches. As far as modifications the only thing I did was trimmed the bushing sleeve. It kept binding on the spring hanger. I can't remember off hand, what the spring width is on the 73-80's, but the front bushing was a little on the wide side as well, but I got it to fit.
11-27-2007, 03:25 AM | #18 |
Looks good . That rear spring hanger for the front in the pic it looks like the eye of the spring is resting on the frame is it just the pic?
Earl 68 2500 4x4 GMC Burb |
11-27-2007, 11:22 AM | #19 |
Grease Monkey
No its has an inch or two between the spring and the frame.
11-27-2007, 12:22 PM | #20 |
Lookin good! What gears are you going to run?
11-27-2007, 01:15 PM | #21 |
Grease Monkey
I am going to be building a Chevy 3/4 Dana 60 with a Detroit Locker and 5.13 gears. Same goes for the front except I haven't decided whether I want to keep my Dana 44 or go to a Dana 60.
11-28-2007, 12:22 AM | #22 |
Grease Monkey
Here are some better picture I took this morning...
11-28-2007, 12:37 AM | #23 |
Do you have 4:56s in it now? with that eaton rear you have i would think you have 4:56 gears in it. you may find out if you do a lot of on road driving you dont like the 5.13 there great for trails but to steep for the road. I have 38s and 4:56s and doing 65 is pushing it hard. I can only do 70 down hill with a strong wind. what trans are you using ? I have a sm465 so no over drive for me.
11-28-2007, 12:39 AM | #24 |
KEEP ON TRUCKIN'
That looks real good. I think your brake line needs to be a little longer. Get one long enough to get a 4" loop in it. Just my opinion.
11-28-2007, 06:59 AM | #25 |
is your truck grey or primer?
