Old 01-28-2008, 03:20 AM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
Project: white knight 1967 step
Well here's my build thread for a 1967 short step I bought from spraybomb and his dad Lee out of the classifieds here . I had talked on and off with them for about 2 months and finnally went and got it . I made the 4 hour drive on wendsday the 23rd . I left @ 7:30 am and got there just in time for lunch . It had rained on me most of the way up , but luckily was pretty dry at there place . I loaded up and chated with these 2 for about an hour and a half . Everything was as described and these guys are just plain into cars and are good people . Anyway it's a 250/6 , 3 on the tree , one wheel peel base model . My plans for upgrades include , 6 lug power disc conversion , power steering , built 355 v8 , th 350 2200 stall , posi unit , 2 and 4 ( or something along those lines ) drop , and A/C intall . The 6 runs really good . I changed the oil , repaired the choke cable , and repaired some chaffed wires for lighting and heat blower already . it needs a door and a fender , but the rockers and cab corners are solid . Here are a few pictures . I'll try and keep them coming with updates , as i would like to drive this to the Houston area meet coming up .
hotrod 80 is offline   Reply With Quote
Old 01-28-2008, 03:30 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Project: white knight 1967 step
Nice score......
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-28-2008, 05:58 AM   #3
kyull67
kyull67's Avatar
That looks solid! Always good to have more '67 stepsides on the board.
kyull67 is offline   Reply With Quote
Old 01-29-2008, 01:46 AM   #4
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
That Truck would Loook Nice with a Shop Logo on Door's , Dropped & Left as Is...........
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 01-29-2008, 10:22 AM   #5
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Sweet ride. Are you going to keep the spare tire rear fender? I think those look pretty cool. Keep us updated. Nice to see another '67 short-step getting redone!
D
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 01-30-2008, 01:21 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
Toomanytoys I like the look it has now , but unfortunately that is not an option . Im less than 2 miles from Galveston bay so that surface rust will turn into a real mess pretty quick . I've got to paint it .
Richard the spare will stay on the bed . My short term plans are to find a 5th ralley wheel and tires for it .
This weeks project will be the 6 lug disc brake conversion . The brake are not working so this will be first on the list . I bought 1989 chevy spindle assembly and 1978 booster and master cylinder . I have the 3/4 ton lower arms and all new ball joints and tie rod ends for the swap . I will follow that up with a rear brake rebuild , and a manual proportioning valve for the rear brakes . I will have new tires put on the painted rims tommorow . I also have located 3 center caps and the tire guy says he has the 4th one . Also got the power steering box cleaned up tonight . The donor truck I got the control arms off of has the door and fender I need . Here is the brake stuff for the swap
Old 01-30-2008, 01:25 PM   #7
1LoC10
Insert Title Here
1LoC10's Avatar
looks nice.... looks like a nice red one in the background too
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 01-31-2008, 01:38 PM   #8
custom72c20
custom72c20's Avatar
Nice and clean. Just the way I like my trucks. Good luck on the build.
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
Old 02-12-2008, 01:57 PM   #9
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Bump !!!
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-13-2008, 01:22 PM   #10
hotrod 80
mini truck racer
hotrod 80's Avatar
O.K. The power 6 lug disc brake conversion is done , so it has brakes now . I put a turbo muffler on it so my wife will let me run it . The 6 cylinder HEI conversion is done and I bought another carb off a board member as mine still has a stumble to it after the rebuild . I am doing body work right now , as it is sceduled to go to the body shop on friday for new gm pure white base / clear job . Fixed the gas gauge , Adjusted the shift linkage , removed old floor mat and vacuumed in the cowl . Looked like a birds nest in there . Pulled the old plywood bed floor out . Removed the windshield . Pulled the 71/72 front bumper off . Basically preping it for paint . I also found a front sway bar today . The motor will eventually ( it's at the machine shop ) be a .030 350 chevy . This is a roller cam 1 pc rear seal block . I have forged flat tops for it . The heads are a over the counter 1969/1970 double hump , these are the heads you would get if you ordered a performance package with your new Camaro back them they would have come in the trunk with intake , carb , and headers . They have never been installed and have assesery holes . I bought a comp hydraulic roller , it's 208/218 @ .050 and 495/.503 lift . Holley 600 , weiand dual plane intake , and HEI dist . I bought a van tilt from another member . Had a turbo 350 out of a 69 Camaro and a 2200 stall . A buddy of mine just bought a truck like ours and it had new headers on it ( he's going big block ) so I got those . I have all the parts , I just got to find time to assemble this thing . My wife has the camara with her at Disney in Orlando , so i'll get some progress pics up within the next couple of days as she gets home tonight . I drove a 1969 short fleet for about 4 years and wish I would have never sold it .
Old 02-13-2008, 01:49 PM   #11
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sweet !!!
It has brakes ??? you do know those are overrated right ???
Sinister
Killer
Old 02-13-2008, 09:55 PM   #12
Joe67
67 is sold
Looks like a nice truck to start with for sure
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 02-17-2008, 12:29 PM   #13
hotrod 80
mini truck racer
hotrod 80's Avatar
Here's were i'm at .
It did not make it to the body shop today . I delayed it for a week . I was able to save the drivers door .
Disc brake conversion is done . Body work continues . I'll try and post a few more pictures later .
Old 02-17-2008, 12:33 PM   #14
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
AAAAAAHHHHH !!!!!
The Patina... it's gone !!!!
Well I hope it looks good once painted, the patina on it was kinda messed up anyhow cuz of the body damage
Can't wait to see it on the road
Sinister
Killer
Old 02-17-2008, 12:35 PM   #15
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Did you get new tires & paint those wheels ???
And why is your tie rod upside down ???
Hows the hood, you get it fixed ???
Sinister
Killer
Old 02-17-2008, 01:33 PM   #16
hotrod 80
mini truck racer
hotrod 80's Avatar
Wheels are the same , just fresh paint and newer style center caps
The spindles are 1989 7200# 6 lug 3/4 ton and use the same year tie rod end.
The hood still needs some work . I bought a 78' Z-28 scoop for it to cover the dents in the center feature . I 'll post some pictures so you can get an idea of what im tring to do .
Old 02-17-2008, 01:53 PM   #17
Richard8971
Hey if you ever decide to sell it....
Sherlock Holmes
Old 02-17-2008, 01:53 PM   #18
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Ok, Sounds good
Sinister
Killer
Old 02-18-2008, 09:39 AM   #19
hotrod 80
mini truck racer
hotrod 80's Avatar
Here are a couple more .
This is kinda the the way I am planning on doing the hood . Opinions on this are valued . It is a 1978 Z-28 hood scoop .
And my other project .
Old 02-18-2008, 09:46 AM   #20
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
My opinion is that I WANT THAT CAMARO !!!!
And that hood scoop is gonna be cool
Sinister
Killer
Old 02-19-2008, 08:34 PM   #21
Joe67
67 is sold
More info on this '68
Old 02-19-2008, 11:01 PM   #22
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Roland, remind me what it takes to do the brake conversion if you will
Matt
Sinister
Killer
Old 02-20-2008, 07:09 AM   #23
hotrod 80
mini truck racer
hotrod 80's Avatar
Joe , it's a 1968 Camaro RS . 327 , 4-speed , 3.31 10 bolt . This is the car i have always wanted . I have to many projects .
1978 Chevy luv
1968 Camaro RS
1967 c-10
1949 3100 5 window
Here is the camaro motor
The luv
Ya'll know about the C-10 . Here's the 49'
The disc brake conversion is the one in the FAQ section . 3/4 ton lower arms with 90' lower ball joint , 90' 7200 # 6 lug rotors , spindles , and calipers . 90' 1/2 ton upper ball joints in stock upper arms and 90' tie rods with es2020r inner tie rod ends .
Old 02-23-2008, 09:23 PM   #24
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Bump for progress !!!
Sinister
Killer
Old 02-23-2008, 09:27 PM   #25
hotrod 80
mini truck racer
hotrod 80's Avatar
Well it's offically in paint prison . He quoted me a super price to replace the rocker , so i'm gonna let them do the metal work . I disassembled the truck and did 2 weeks of prep and block sanding . I also bought a used hood for it off of Craigslist . I'm still doing the Z-28 scoop on the other hood and having it painted . The interior will also be repainted factory blue with GM pure white base coat / clear coat . The core support and frame will be semi gloss black and the bumper , grill and headlight trim will match the wheels . The side mirrors will be painted body color with black mirror heads . It is supposed to be out friday the 29th so it'll be on the trailer for the Houston meet if they meet there own deadline . I'll try and get pictures of it in the various stages of paint .
