Old 02-02-2008, 01:11 PM   #1
cj66c10
what gas tank are you running?
My tank has rust in it, wanting to see what options are out there. thanks
cj66c10 is offline   Reply With Quote
Old 02-02-2008, 05:31 PM   #2
ryan913
Re: what gas tank are you running?
I am running a '65-'66 Mustang tank in my short bed '63. Worked out great!
ryan913 is offline   Reply With Quote
Old 02-02-2008, 08:52 PM   #3
64GMCHorsepower
Justified!
I've got a fuel cell under the bed....
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 02-02-2008, 09:35 PM   #4
psychorodder
psychorodder's Avatar
Summit 16 gallon fuel cell mounted between frame under bed.
psychorodder is offline   Reply With Quote
Old 02-02-2008, 11:46 PM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
I picked up the blazer tank at the one of the Goodguys show from www.truckandcarshop.com .. You can use this link to see it in the frame. I have not driven the truck yet and I do not have the fill hooked up yet. What you see in the picture is what I have done. http://s49.photobucket.com/albums/f2...t=000_0345.jpg
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-03-2008, 12:44 AM   #6
forcedinduction
forcedinduction's Avatar
21 gallon Blazer tank kit from LMC. Comes with everything needed including the sender. I know there are cheaper parts out there, but the "kit" made it really easy with no running around. For 200 clams, it's tough to beat. Here's the link.
http://www.lmctruck.com/icatalog/cbe/full.asp?page=67
forcedinduction is offline   Reply With Quote
Old 02-03-2008, 01:48 AM   #7
truckn'
truckn''s Avatar
Just ordered 21 gallon rear mount kit from LMC. I'll let you know how it turns out.
truckn' is offline   Reply With Quote
Old 02-03-2008, 06:14 AM   #8
thekid54
I'm also running a Mustang tank on my truck. I've got the late '60s version which is 20-22 gallons, I can't remember.
thekid54 is offline   Reply With Quote
Old 02-03-2008, 07:22 AM   #9
1974k5blazer
i'm running a budweiser keg! polished!
1974k5blazer is offline   Reply With Quote
Old 02-03-2008, 07:37 AM   #10
leftcoast66
leftcoast66's Avatar
Just a RCI fuel cell in the bed.
leftcoast66 is offline   Reply With Quote
Old 02-03-2008, 09:21 AM   #11
TR65
TR65's Avatar
Stainless tank from Rick's Hot Rod Shop, with intank EFI pump. Two senders, one for stock gages and one for computer. Expensive but good work.
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 02-03-2008, 09:32 AM   #12
ryan913
That is a really nice set up TR65! Looks great!
Old 02-03-2008, 01:57 PM   #13
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Any of you have pics of the Stang tank install ??
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 02-03-2008, 03:58 PM   #14
wild one
Registered.........
wild one's Avatar
A fuel tank out of a 1977 blazer, 30 gallon capacity
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 02-04-2008, 03:34 AM   #15
thekid54
It worked on my truck because I made the frame wider behind the notch to match the rest of the frame.
Old 02-04-2008, 06:45 AM   #16
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
That install looks good.....I like where the fill ends up too.
Where is the fuel delivery located ??
Here is the tank we used on my customers '67....a little too pricey for me.....I really like the 'stang tank though !!!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 02-04-2008, 06:53 AM   #17
baddawg65
baddawg65's Avatar
I bought an aluminum from Brothers. I had to notch the mounting plates for the leaf sprig hangers. Used stainless for plumbing to the frame mounted fuel pump and filter.
baddawg65 is offline   Reply With Quote
Old 02-04-2008, 07:01 AM   #18
LILRED66
LILRED66's Avatar
Nice work baddawg65. Quality workmanship.
LILRED66 is offline   Reply With Quote
Old 02-04-2008, 07:40 AM   #19
56 chevy_man
nobody has tried a 96-98 vortec tank for fit by any chance have they? Would like to keep the tank and fuel pump when I do a vortec install.
Jordon
Vermilion, Alberta, Canada
56 lwb stepside
66 lwb BBW
66 swb parts truck
56 chevy_man is offline   Reply With Quote
Old 02-04-2008, 10:06 AM   #20
thekid54
ChiefRocka- the fuel delivery is in the front, facing the diff. cover.
Old 02-04-2008, 10:22 AM   #21
Woogeroo
I'm still running the stock behind the seat tank in my '65.
-W
Woogeroo is offline   Reply With Quote
Old 02-04-2008, 10:52 AM   #22
fuelpump
fuelpump's Avatar
-W
Me too
fuelpump is offline   Reply With Quote
Old 02-04-2008, 03:14 PM   #23
Captainfab
60-66 Nut
I haven't but I believe the ones in the Blazer/Tahoe and the Suburban will be too wide to fit the older frames. I have plans of installing a '96 Vortec in my '66 C20 also. One idea I had was to possibly install the sender and pump unit from a Blazer/Tahoe or Suburban into a '69-'72 Blazer tank. I just haven't gotten around to comparing the depths of the two. If that doesn't work I'll just build a tank.
Which tank do you have?
Old 02-05-2008, 12:58 AM   #24
ryan913
The 66 mustang tank is very easy to install. Just bolts to the bottom of the frame and does not hang low at all. It does not use straps and you can buy one for around a hundred bucks. They also make an after market in the tank fuel pump for fuel injection.
http://cgi.ebay.com/ebaymotors/64-65...ayphotohosting
Old 08-21-2008, 11:28 AM   #25
fast64chevy
I am trying to find more info on this mustang tank swap mentioned above. I have heard the frame has to be widened? Do you have any pics?
fast64chevy is offline   Reply With Quote
