Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-15-2008, 02:57 PM   #1
Super73
Super73's Avatar
Pics of my adjustable rear control arm brackets
Thought I'd share some truck porn.. I made these from 3" 3/16 wall square tube. Radius drilled the holes so the rear would not move forward when using the upper holes. I then cut off one end. Ground the stock rivitheads off two at a time and knocked them out. I then redrilled the holes with a 7/16 bit as the rivits were just shy of that. Once out, I took the stock brackets and set them inside the new ones. They fit inside perfectly. Lines them up and drilled the holes out in my mill (drill press would be fine). Installed them and this is what you see..
Now I need to set pinion angle. As I figured every hole up is 1* of pinion change. I'll now how they work with in the next week or two..
Super73 is offline   Reply With Quote
Old 02-15-2008, 10:22 PM   #2
57sailplane
57sailplane's Avatar
Re: Pics of my adjustable rear control arm brackets
you do realize that you are transfering more weight to the front.. it a good idea though. if i may ask did you use tubing and what size? i my make me a pair...
57sailplane is offline   Reply With Quote
Old 02-15-2008, 11:11 PM   #3
Outlaw72
Hay Team!!
Outlaw72's Avatar
Nice....looks easy enough. I think the only thing I would have done differently, is weld them in.
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 02-15-2008, 11:17 PM   #4
Super73
Super73's Avatar
57, second sentence "I made these from 3" 3/16 wall square tube."
I agree raising the anti-squat line will tend not let the front lift as much. How ever, the new front spring I have in the front, even with the shock on the 70/30 setting, I am still toping out my 6" of suspension travel and unloading the tires. I'm hoping this does 2 things:
1) Slows down the front rise some, Once topped out the front end has no where to go but down.
2) As it seperates the rear and lifts the body, I'm hoping it puts more force in to the rear tires and hook it a little better.
Outlaw,
I thought about welding them but I also thought, what if they don't work like expect and need to go the other way (down) do to me hitting the tires too hard right now. Welding them and unwelding them in not that much fun...
Old 02-15-2008, 11:45 PM   #5
Outlaw72
Hay Team!!
Outlaw72's Avatar
Oh....I was thinking you already had them right where you wanted them. In any case I like it...it's adjustable and having adjustable suspension components will always let you fine tune.
I will still let you make me a set and send em to me
Old 02-16-2008, 12:26 AM   #6
Super73
Super73's Avatar
I thought about offering that service to some of you racers.. Charge you the price of a:
18" of square tube
3/4" drill bit
7/16 drill bit
12 pack of "this weeks" favorit beer
Old 02-16-2008, 12:45 AM   #7
Outlaw72
Hay Team!!
Outlaw72's Avatar
Dang you're expensive j/k
BTW Super....I found the trick to the axle studs. There is a moroso 3 in stud you buy from summit and then open the axle holes with a 9/16 drill bit.
http://store.summitracing.com/partde...5&autoview=sku
Old 02-16-2008, 01:31 AM   #8
Super73
Super73's Avatar
I was thinking the bit's could be reused several times.. So maybe I could reduce the drill bit price to $5 towards bits, the tube and 12 pack
Thanks for the heads up on the studs. Have you drilled the axles yet? Curious to know how they came out and how long you were'a'drillin..
Old 02-16-2008, 01:37 AM   #9
Outlaw72
Hay Team!!
Outlaw72's Avatar
No...I'm gunna do it on Saturday. I'm gunna buy 2 bits and use a drill press. I will let you know how it turns out.
Old 02-16-2008, 01:47 AM   #10
Super73
Super73's Avatar
Please let me know how it works.. I don't know that I can get the axles in my mill and don't have a drill press. Hmmm, to bad axles are heavier than the brackets, we could have worked a trade...
Old 02-16-2008, 01:50 AM   #11
Outlaw72
Hay Team!!
Outlaw72's Avatar
Surely somebody you know has a drill press? I'm sure it could be done with an air drill. I just want my hols to be as straight as possible. That didn't sound right :/
Old 02-16-2008, 09:44 AM   #12
Super73
Super73's Avatar
Well, first try at one of my favorite ghost roads, small 2 second burn out, 1/2 throttle to load the suspension and quickly rolling in to it cut a 1.903 which is my best 60' even better than what the G-tech reported at the track (1.912). I also have 11* of timing pulled out of the motor right now.
Old 02-16-2008, 10:21 PM   #13
Couch
Daily Driver
Couch's Avatar
if this all goes well i might wanna reserve a set. not like im that far from you anyways.
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 02-19-2008, 12:35 AM   #14
57sailplane
i definatly will be making me a set. nice work.. you no you have almost remade a 3 point. of course your not the first to do this there is someone else on here that made a set a while back but this set looks much easier to make.. again nice work.
Old 02-19-2008, 12:50 AM   #15
Super73
Super73's Avatar
I did see that someone here made a set. His though focused on lower holes vs upper holes. But Before I saw his, I had the thought and had alreadry started my radius drilling ect.
What do you mean by 3-point?
Old 02-19-2008, 08:52 AM   #16
57sailplane
3 link sorry...
Old 02-19-2008, 09:27 AM   #17
Super73
Super73's Avatar
Did you say 3-link?? This is my 73 Camaro.
The truck arms would have to be modified to be a true 3-link even with the upper link. You would not be able to adjust pinion agle with the rear bolted to the control arms. Also the 3rd link right now would actually bind the suspension due to the rear being bolted to the control arms and the rear not beaing able to rotate with the 3rd link attached.
RW or LW bump would be fine but both tires in a bump together I think would be real stiff.
Old 02-19-2008, 12:51 PM   #18
57sailplane
you are correct... i no its a far cry from a 3 link but with the adjustability that you are adding with the pinion shims and all its a far cry from stock. i was thinking ladder bar not 3 link. again my bad..
Old 02-19-2008, 10:28 PM   #19
Super73
Super73's Avatar
Ladder bar for sure.. That's how I look at the truck arm set up. It's a 52" ladder bar
Old 02-21-2008, 09:01 AM   #20
57sailplane
have you had a chance to hot lap this set up yet?....
Old 02-21-2008, 09:21 AM   #21
Super73
Super73's Avatar
I have only got to test it a few times. The best G-tech at the track was a 1.912 really being a 1.87. Previous to the spring, Converter, tire and RC adjuster I was cutting 2.2-2.2 60's on my test road. I have pulled a 1.903, 1.909 and a 1.914... There were a couple of high 1.9's and a few 2.x's in there trying to see how I need to throttle it.
There is more in it but I think I need to find the sweet spot with the shocks and what hole they need to be in.
Old 02-21-2008, 12:16 PM   #22
Couch
Daily Driver
Couch's Avatar
you must be burnin tire pretty bad. i cut a 2.0 60' on 295/50 street tires.but then again that was with way less power than you make. so traction wasnt an issue for me. i couldve hooked in the rain with that engine
Old 02-22-2008, 09:12 AM   #23
57sailplane
thats what i was wondering are you burning the tires off still. is it better or worse..
Old 02-22-2008, 09:47 AM   #24
Super73
Super73's Avatar
It's better but yes, I am still spinning the tires. It's .15-.2 better with the 4 changes mentioned. I loosened up the front shocks again to the 90/10and took it for a quick spin. It feels better but my G-tech lost power on that run. I'll be trying it again soon after I swap the manual steering box back in.
These ET streets were at a buddies house and he bought them used. I'm not sure how old they really are. I'm wondering if they have lost some of their softness.
Old 06-30-2008, 08:03 AM   #25
djracer
djracer's Avatar
did you ever get to play with this setup at the track?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
