03-02-2008, 08:05 PM | #1 |
Watts link info
Anyone running a watts link with bags ? Love to know your opinions .
Thanks . 67 short wide
1955 Chevy 2 door Wagon 1967 Short Wide BAGGED Gone to someone else 1953 Shop truck Clipped and Snipped sold 1951 GMC Bagged and patina |
03-03-2008, 02:54 AM | #2 |
Re: Watts linkinfo
Started on mine this week havnt finished it yet.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
03-03-2008, 05:20 AM | #3 | |
Hollister, CA.
Re: Watts linkinfo
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 03-03-2008 at 05:23 AM. |
03-03-2008, 09:35 AM | #4 |
Re: Watts link info
That's great news . I will lookinto getting one . From what you are saying it should solve my problem without cutting my truck . Any opinons on which one . I have seen the KP one , it is well within my skill set to intall . The crazy thing is the one from Totaly polished is the same money , and yes it is fully polished unit . but welding and some skills I dont have are needed .
The other question is I cant seem to find contact info on the KP site to find out how much clearance i need from my dif to the fuel cell which i have mounted between the rails . Anyone know / Thanks again
03-03-2008, 10:05 PM | #5 |
Hollister, CA.
Re: Watts link info
The KP unit is a quality product that will bolt-up to the 12-bolt.
I didn't know the TP was the same price....nice piece there too. Regardless, the watts is the way to go !!! Let me know if I can be of more assistance.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
03-04-2008, 02:53 AM | #6 |
Re: Watts link info
can someone give me a link to a site that has the info on the watts link. i am interested if it is a true bolt in kit for my 69. thanks
03-04-2008, 03:18 AM | #7 |
Re: Watts link info
kp components
totally polished speedwaymotors Some guys have used this one, but you'll have to do some fabricating to make it fit. Last edited by jlaird; 03-04-2008 at 03:23 AM. |
03-04-2008, 03:35 AM | #8 |
Re: Watts link info
I put the KP link in my blazer this weekend. I had to modify the crossmember in front of the gas tank. and extend the flexible brake line. crossmember mod should not be needed on a truck from what I've been told.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
03-04-2008, 03:37 AM | #9 |
Re: Watts link info
FYI, KP link is not totally bolt on if your frame is not boxed. You need to weld a plate on the frame (box it in) on each side.
03-04-2008, 05:51 AM | #10 |
Re: Watts link info
03-04-2008, 07:39 AM | #11 |
Re: Watts link info
Did installing that KP setup totally eliminate your side to movement . I have 1 " or less tire clearance at ride hieght .
03-04-2008, 07:40 AM | #12 |
Re: Watts link info
Do you have a watts link in your own truck ?
03-04-2008, 07:50 AM | #13 | |
Re: Watts link info
When I called about the adjustable panhard bar they said that there was only 1/2 inch of side to side movement throughout the travel. The watts should be much less if any.
03-04-2008, 07:56 AM | #14 |
Re: Watts link info
thanks for the response , good luck next weekend . How much was the kit ?
03-04-2008, 08:19 AM | #15 | |
Hollister, CA.
Re: Watts link info
Absolutely none !! CHeck out this F-150 I did a while ago... This thing has 23" wheels, with less than 1/8" clearance on the side where the fender radius start to drop down. Bagged, with custom cantilevers and watts link No rubbing...constant axle locating thru ENTIRE suspension travel... - - - - - - Sorry for the Ford pics....not my truck...not my style of doors...but thats what the customer wanted...money is money !!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 03-04-2008 at 08:22 AM. |
03-04-2008, 08:33 AM | #16 |
Re: Watts link info
In the new Sport Truck they have a article about how to properly set up a watts link and panhard bar... I referred to it a couple times. Like at half travel the "pivot arm" should be just a little off center and the watts link bars should be horizontal with the ground... I didnt know that.. I dunno it was very helpful to me though
03-04-2008, 09:07 AM | #17 | |
Re: Watts link info
03-04-2008, 09:16 AM | #18 | |
Hollister, CA.
Re: Watts link info
03-04-2008, 03:52 PM | #19 |
Re: Watts link info
April '08... Green and blue fullsize GMC on the cover and a chick in a red shirt.
03-04-2008, 06:57 PM | #20 |
Re: Watts link info
Chief thanks for the clearity . Do you believe with my adjustable panhard bar that I would be safe for clearance . Like i said I have nearly an inch on both sides at one point in the suspension travel . But maybe I am just not adjusting it properly .I am going to order the KP unit if need be but would appreciate your opinion before spending that $ .
I am going to get that Sport Truck Article right away and see if that gives me some info as well . Thanks again .
03-04-2008, 08:04 PM | #21 |
Hollister, CA.
Re: Watts link info
If you have a whole inch on both sides, then I think you would be fine with just a panhard bar.
Center it a ride height, and away you go.
03-04-2008, 08:26 PM | #22 |
Re: Watts link info
As soon as the snow is gone that will be my plan , thanks again . I hope you dont mind if I keep your contact for future info .
03-06-2008, 08:03 AM | #23 |
Hollister, CA.
Re: Watts link info
No problem....Have a good day
03-06-2008, 08:36 AM | #24 |
Re: Watts link info
minus 14 degrees and snowing here , trying to work in the garage to center the panhard bar , it is a short one not the long one . frkn feezn
I think I need to wait until I can get this truck on a drive on hoist to do this set up . Thank's again .
03-06-2008, 08:58 AM | #25 |
chevy only
Re: Watts link info
here is my kp 6 link
CHEVY ONLY... Nothin Else ! |
