Old 03-05-2008, 04:16 AM   #1
BustedTruck
BustedTruck's Avatar
Butt Welding help?
I just purchased my first mig welder. I have been practicing this weekend on a piece of scrap. I am trying to butt weld panels, but I always seem to burn through when I just tack together. I have tried turning the heat & wirespeed down. I am still having problems. Good thing this is scrap, because I need a lot more practice before welding in the patch panels. EBFABMAN makes it look so easy in his videos. Anyone out there have any tips?
BustedTruck is offline   Reply With Quote
Old 03-05-2008, 04:18 AM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Thumbs up Re: Butt Welding help?
Keep Playing With The Speed And Temp Settings. Practice, Practice, Practice.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 03-05-2008, 04:20 AM   #3
shifty
Questionable
shifty's Avatar
Does your welder have a "cheat sheet" on the inside panel where you load the wire? I bought a Lincoln 175HD (as part of a Weld Pak) really cheap on eBay. Just inside the side panel, there is a chart that tells you speed and temp settings for the gauge of metal you're working on. So far, it's been pretty spot-on, but I haven't done anything major yet.
Most important thing I've found as a fellow newbie is that you absolutely MUST have a good, clean ground to attach to (remove all paint before clamping).
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-05-2008, 04:23 AM   #4
71Rat
ran out of money
71Rat's Avatar
to help welding if your burning threw, turn heat down and wire speed up and move fast..... also you shouldnt weld a long strip solid keep moving around so your heat will keep moving around and areas have time to cool.... i hope that helps
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 03-05-2008, 04:29 AM   #5
BustedTruck
Mine is a miller 175. It has the "cheat sheet" I am able to do a decent job on the thick stuff, but this thinner stuff is really difficult. I set it to the settings per the cheat sheet, but I still am burning through most of the time. I know I definatly need more practice.
Old 03-05-2008, 04:38 AM   #6
kaycee
kaycee's Avatar
I use the thin wire .025 on sheet metal .045 for the thicker stuff, helped me alot
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 03-05-2008, 04:45 AM   #7
Jered33
Keep adjusting the heat and speed, make sure it's clean. Use .030 or smaller wire, also I sometimes use a strip of copper behind the butweld it seems to help.
What gauge of metal are you welding? and what type of welder?
Jered33 is offline   Reply With Quote
Old 03-05-2008, 04:54 AM   #8
BustedTruck
I have a miller 175. I have #.023 wire. I guess it would be 14 gauge.
Old 03-05-2008, 04:58 AM   #9
griesel72
griesel72's Avatar
with some of these patch panels, you have to spot weld all of the way along, and avoid welding a "bead" as the heat will burn through, check the wire thickness and move fast, I am a welding teacher for a high school, so if you need any more help, send me a pm
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 03-05-2008, 05:29 AM   #10
smartcraig
smartcraig's Avatar
If at all possible i wouldnt try and butweld. Buy a stepping tool and over lap them. The step in the metal will help make the panel more rigid so that it wont want to warp so bad. And will be easier to weld with something behind it.
smartcraig is offline   Reply With Quote
Old 03-05-2008, 05:34 AM   #11
cdowns
cdowns's Avatar
are you using shielding gas or the fluxcore wire?//you get better results with the gas
Old 03-05-2008, 05:44 AM   #12
BustedTruck
I am using the gas. I think the butt weld looks much better when finished properly. I know it will take more timeto do it this way, but I think the end result will be better.
Old 03-05-2008, 05:59 AM   #13
LONGHAIR
The biggest problem with this thought, is you are leaving that overlapping piece that will hold water and start the rust over again. Flanging also distorts the area to be patched, so you end-up doing more work straightening it out. I would stick with butt-welds.
Are you sure about that?^^^ 14ga is well beyond what would be considered body metal. You shouldn't be burning through something that thick.
Body metal is more like 18ga-20ga depending on year of car/truck, manufacturer, or even where on the body you are replacing. 14ga is nearly twice that thick.
LONGHAIR is offline   Reply With Quote
Old 03-05-2008, 06:07 AM   #14
Husker
Husker's Avatar
When I did my Jeep CJ I tried butt welding, got a crimper where it stepped distorts the metal a bit, but what I found worked the best was I cut strips about an 1" or so wide popped holes in the body where I was welding and spot welded the strip on the inside then positioned the new piece I was repairing and spotted it in place. Then I stitched the two pieces together with the backing strip in place. Worked great actually added more support. I Herculined the inside so you can't even notice how I did unless you look close.
Hope this helps
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 03-05-2008, 06:19 AM   #15
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
Another "trick" like state above is to place copper behind the weld. The copper also draws the heat off the area quickly acting like a heat sink. If you cant get copper flatbar, aluminum works ok too. I made some heat sinks out of the bottoms of old pots I got from the dump. It helped me alot. In some places, I've gotten pretty good at filling holes by quickly "tapping" the trigger like in a series of spot welds but not allowing the heat to build up. I've filled holes as big as 3/8" doing that. Dont know if anything helps but figured it couldt hurt to share an idea.
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 03-05-2008, 06:21 AM   #16
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Try not holding the welding tip not as close to your work. I use to burn through a lot untill I held the welding tip a little farther away from the work. You will need a faster speed on the wire too. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 03-05-2008, 06:21 AM   #17
clay68c10
clay68c10's Avatar
Keep practicing with the thicker stuff until it starts to look nice, then step down to thinner metal. You'll get a good feel for welding on the easier metal and then you'll have the skill to fine-tune on the smaller stuff.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 03-05-2008, 06:44 AM   #18
shifty
Questionable
shifty's Avatar
I went out and bought these to help while shaving my heater stuff: http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
I still haven't used them yet, but have a feeling they'll come in handy.
To practice before the final work, I will cut a little 2"x2" section out of the main piece I'm working on, and try to weld it back in. If all goes well, I'm going to do the main section.
It helps to watch someone else do it first, I found. I used the Trucks! TV (Copperhead) TV show to help me.
Most of the guys I see on TV just hold the tip of the gun about 1/4" of the panel, touch the wire to it, trigger for 2-3 seconds, then move to the other side, repeat, move to the other side, repeat, always staying stationary, then just connect the dots all the way around, clean up with a flapwheel and done.
But I'm not speaking from experience. I haven't gotten there yet (STILL).
Old 03-05-2008, 07:13 AM   #19
Shane
Shane's Avatar
Screw eastwood co ... go to harbor freight you can get a bag of 6 or 8 panel clips for like $5
Shane is offline   Reply With Quote
Old 03-05-2008, 08:28 AM   #20
chip46wis
My 2 cents---as a certified pipe welder I had a rough time going from heavy wall pipe where too much heat isnt a real problem to welding sheet metal.You need to speed up more than likely---look at factory wire feed welds-they are not pretty as a rule more of a thick here thin there situation.I usually go for 1/4 3/8 before letting it cool completly then restarting or going to a different area.
chip46wis is offline   Reply With Quote
Old 03-05-2008, 08:59 AM   #21
shifty
Questionable
shifty's Avatar
I found this out when I went for the balljoint press the other day. Forgot to mention it. It's the same chinese made crap either way.
Old 03-05-2008, 09:08 AM   #22
Husker
Husker's Avatar
Using .023 Wire will help alot.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 03-05-2008, 09:34 AM   #23
Shane
Shane's Avatar
same identical panel clips ... but $25 cheaper.
Old 03-05-2008, 08:36 PM   #24
shifty
Questionable
shifty's Avatar
OW! MY PRIDE!
(Mine came free when I ordered a copper magnetic backing plate for hole filling )
Old 03-05-2008, 08:40 PM   #25
Premium72
Premium72's Avatar
how this is the srap your using. it might be buring through because its to thin. it the scrap the same thickness as the patch and sheetmetal? turn that sucker alllll the way down to the lowest and start there. good luck .
Premium72 is offline   Reply With Quote
